not possible to update my MM
@RIKKO14 that’s not a node/npm notice bits magicmirror update notice.
run the upgrade script
it’s a two step process
once as test to inform you of any issues
once as not test to DO the upgrade -
thank you
@RIKKO14 did u solve this problem?
Hello @sdetweil , my MM is update but the same message stile to the top of my screen.
I’m not home until Wednesday so for now I left it like that… -
@RIKKO14 ok, then we shall look at it then. because that message is there, the update was not successful
ok, thank you.
