    Keep having same error
    7 Posts 2 Posters 1.9k Views 2 Watching
      svencarree
      Can someone help this newbie with what I’m doing wrong:
      magicmirror@2.21.0 start
      [20.11.2022 19:53.11.052] [LOG] Starting MagicMirror: v2.21.0
      [20.11.2022 19:53.11.058] [LOG] Loading config …
      [20.11.2022 19:53.11.068] [LOG] Loading module helpers …
      [20.11.2022 19:53.11.077] [LOG] No helper found for module: alert.
      [20.11.2022 19:53.11.105] [LOG] Initializing new module helper …
      [20.11.2022 19:53.11.108] [LOG] Module helper loaded: updatenotification
      [20.11.2022 19:53.11.111] [LOG] No helper found for module: clock.
      [20.11.2022 19:53.11.492] [LOG] Initializing new module helper …
      [20.11.2022 19:53.11.494] [LOG] Module helper loaded: calendar
      [20.11.2022 19:53.11.498] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
      Require stack:
      • /home/svencarree/MagicMirror/modules/MMM-BMW-OW/node_helper.js
      • /home/svencarree/MagicMirror/js/app.js
      • /home/svencarree/MagicMirror/js/electron.js
      • /home/svencarree/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      [20.11.2022 19:53.11.499] [LOG] Loading module helpers …
      [20.11.2022 19:53.11.500] [LOG] No helper found for module: alert.
      [20.11.2022 19:53.11.501] [LOG] Initializing new module helper …
      [20.11.2022 19:53.11.502] [LOG] Module helper loaded: updatenotification
      [20.11.2022 19:53.11.502] [LOG] No helper found for module: clock.
      [20.11.2022 19:53.11.503] [LOG] Initializing new module helper …
      [20.11.2022 19:53.11.504] [LOG] Module helper loaded: calendar
      [20.11.2022 19:53.11.506] [ERROR] App threw an error during load
      [20.11.2022 19:53.11.509] [ERROR] Error: Cannot find module ‘request’
      Require stack:
      • at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
        at n._resolveFilename (node:electron/js2c/browser_init:245:1105)
        at Module._resolveFilename (/home/svencarree/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:785:27)
        at c._load (node:electron/js2c/asar_bundle:5:13343)
        at Module.require (node:internal/modules/cjs/loader:1012:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object. (/home/svencarree/MagicMirror/modules/MMM-BMW-OW/node_helper.js:9:17)
        at Module._compile (node:internal/modules/cjs/loader:1118:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1173:10)
        [20.11.2022 19:53.11.512] [ERROR] Whoops! There was an uncaught exception…
        [20.11.2022 19:53.11.517] [ERROR] Error: Cannot find module ‘request’
        Require stack:
        at Module._extensions…js (node:internal/modules/cjs/loader:1173:10) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [
        ‘/home/svencarree/MagicMirror/modules/MMM-BMW-OW/node_helper.js’,
        ‘/home/svencarree/MagicMirror/js/app.js’,
        ‘/home/svencarree/MagicMirror/js/electron.js’,
        ‘/home/svencarree/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
        undefined
        [20.11.2022 19:53.11.520] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [20.11.2022 19:53.11.520] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [20.11.2022 19:53.11.933] [LOG] Launching application.
        MESA-LOADER: failed to retrieve device information
        MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: kan gedeeld objectbestand niet openen: Toegang geweigerd (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
        failed to load driver: kms_swrast
        MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: kan gedeeld objectbestand niet openen: Toegang geweigerd (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
        failed to load swrast driver
      S 2 Replies Last reply
        sdetweil @svencarree
        @svencarree see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1
          @sdetweil you replied to the topic you deleted
          1. find the message
          2. get the name of the missing library (???)
          3. look in the module folder for package.json
            4 if it does NOT exist, create it
            w the
            npm init -y
            command
          4. npm install ??? (from step 2)
            svencarree
            Hahaha sorry for the inconvinience! In the folder *MMM0BMW-OW’ there is a ‘package.json’ file. But at step 2 and 4 I really don’t know wich library is missing.
              @svencarree see the messages u posted to start this topic. just before either indent is the message you are looking for
                svencarree
                Thanks for the time and patience! But I’m still not finding it but I’m a real newbie…
                @svencarree said in Keep having same error:
                Require stack:
                Require stack:
                requireStack: [
                undefin
                This looks for me as the report of the error. But i’m not seeing wich library I should install under step 4 with npm install…
