Step by step guide to MagicMirror on Ubuntu 22 server?
10 Posts 2 Posters 2.2k Views 2 Watching
  • E Offline
    eqpaisley
    I’ve seen some guides for MagicMirror on linux but I am on the struggle bus trying to setup MM on a remote VPS (via SSH). Ubuntu 22 on ARM architecture. Is there a guide floating around? Has anyone done this?
    S 1 Reply Last reply Nov 26, 2022, 7:18 PM Reply Quote 1
    • S Away
      sdetweil @eqpaisley
      @eqpaisley what is a VPS ?
      but, run my script to install
      see
      E 4 Replies Last reply Nov 26, 2022, 7:21 PM Reply Quote 0
      • E Offline
        eqpaisley @sdetweil
        @sdetweil thanks! can I use this curl command?
        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
        • E Offline
          eqpaisley @sdetweil
          @sdetweil oh sorry - a vps is a remote, virtual machine. but it functions exactly like a low power (2cores 8g of ram) ARM machine.
          S 1 Reply Last reply Nov 26, 2022, 7:30 PM Reply Quote 1
          • S Away
            sdetweil @eqpaisley
            @eqpaisley does it have a local UI?
            if not, then you do
            npm run server
            to execute the server
            and then view with a browser somewhere else
            there is one install, and three different run modes
            full
            server
            client
            • E Offline
              eqpaisley @sdetweil
              @sdetweil great ty. Yeah the plan is to run this non-gui version in server mode. I’ll need to edit the config to allow remote connections from my IPs and open the right ports, etc it will be a process lol but I think I can sort it out.
              • E Offline
                eqpaisley @sdetweil
                @sdetweil could you remind me of the command to run NPM RUN SERVER in the background so it won’t quit when I close my SSH session?
                Also, if I need to re-run the server (let’s say I update the config or add a module) how do I do that?
                S 1 Reply Last reply Nov 26, 2022, 10:54 PM Reply Quote 0
                • S Away
                  sdetweil @eqpaisley
                  @eqpaisley if u setup pm2, then
                  pm2 status will show u the managed apps
                  pm2 --help will show u all the things it can do
                  pm2 start
                  pm2 restart
                  pm2 stop
                  pm2 info
                  all take the name of the app, or the number
                  if u setup pm2 q my script then it launches
                  MagicMirror/installers/mm.sh
                  change the npm start to npm run server
                  if u didn’t setup pm2, then the script on my script
                  fixuppm2.sh will do that
                  E 1 Reply Last reply Nov 26, 2022, 10:57 PM Reply Quote 0
                  • E Offline
                    eqpaisley @sdetweil
                    @sdetweil Thanks! I ended up setting up a magicmirror.service. now I use
                    sudo service magicmirror resart
                    after each tweak to my config. I have it up and running on a free oracle cloud instance and behind a reverse proxy.
                    I guess the danger there is that anyone with the URL can access it…but they’d have to guess the URL…right?
                    S 1 Reply Last reply Nov 26, 2022, 11:01 PM Reply Quote 0
                    • S Away
                      sdetweil @eqpaisley
                      @eqpaisley right
