    MMM-PIR-Sensor-Lite does not switch HDMI off
    43 Posts 7 Posters 24.7k Views 7 Watching
    • G Offline
      grena Module Developer @dkhorse74
      @dkhorse74
      Got everything to work perfectly…
      :thumbs_up:
      The following page is very useful to test the functionality of the sensor before you implement the change to mirror config file (thanks to @sdetweil for posting the link in a different thread): https://projects.raspberrypi.org/en/projects/parent-detector/3
      Yes, You can also run the python script of the module: python3 -u ~/MagicMirror/modules/MMM-PIR-Sensor-Lite/pir.py SENSOR_PIN
      another user noticed this only worked for the 1st HDMI port on the pi4.
      Yes, I add this point of vigilance at the beginning of the readme :white_heavy_check_mark:
      S D 2 Replies Last reply Reply Quote 1
        sdetweil @grena
        @grena a more better thing would be to make a parameter for config so the user can change it without editing your code.
          dkhorse74 @grena
          @grena said in MMM-PIR-Sensor-Lite does not switch HDMI off:
          :thumbs_up: Yes, You can also run the python script of the module: python3 -u ~/MagicMirror/modules/MMM-PIR-Sensor-Lite/pir.py SENSOR_PIN
          • L Offline
            Laz
            I also have a problem displaying the flow from the MMM-RTSPStream module after turning on the screen on the motion sensor. The stream image does not return to the frame of the desired location. Was it possible to somehow defeat the image shift? I know that the module is no longer supported, but maybe who was able to find a solution? ((
            This is the kind of screen I have after the motion sensor is triggered… (((
            • V Offline
              Volkae @Laz
              @Laz
              I have exactly the same Problem using MMM-PIR-Sensor-Lite in combination with MMM-RTSPStream and even by using MMM-PIR-Sensor-Lite in combination with MMM-iFrame.
              I have no idea…
              • L Offline
                Laz
                Tell me which command to restart MagicMirror? I want to try after turning on the screen to reboot the program itself.
                Not raspberries, but mirror programs. Maybe it will help return the stream picture to the right place…?
                • L Offline
                  Laz
                  pm2 restart /home/vova/MagicMirror/installers/mm.sh
                  This command overloaded the program MM2 and returned the video stream to the right place in the RTSP frame…)
                    sdetweil @Laz
                    @Laz pm2 status
                    will show u the apps that pm2 manages
                    pm2 restart xxxx
                    where xxx is the name or the number of the row
                    pm2 restart MagicMirror
                    or
                    pm2 restart 0
                    or if u have more that one app, like I do, pm2 restart all
                    on Linux, a convention is that passing --help to a command will show u it’s options
                    pm2 --help
                    • L Offline
                      Laz @sdetweil
                      @sdetweil Thank you !!! ))))
                      • V Offline
                        Volkae @Laz
                        Maybe there is an alternative using MMM-RTSPStream for showing a live stream from the own webcam…???
                        • 3 / 3
