    monitor power button unreachable
    9 Posts 4 Posters 1.7k Views 4 Watching
      DarrenHill @SILLEN 0
      @SILLEN-0 Would you be able to dismantle it (carefully) enough to get rear access to the button?
      I was thinking either to be able to remove and relocate it perhaps, or to solder a switch or other solution in parallel to the existing one to put that somewhere accessible?
        jturczak @SILLEN 0
        @SILLEN-0 you might try looking in the monitor setup for a power option that turns on the monitor when power is applied.
          jturczak
          @SILLEN-0 look in the monitor set up itself.
            jturczak @SILLEN 0
            @SILLEN-0 Doesn’t your MM run off a Raspberry Pi? When it powers up you should get a signal to power the monitor from the HDMI cable… check your pi settings also for autoboot
            S S 2 Replies Last reply Reply Quote 0
              sdetweil @jturczak
              @jturczak just fyi. every post from users with less than 2 reputation are reviewed before being posted on the forum. this stops all the spam we get.
                SILLEN 0 @jturczak
                @jturczak hey sorry for late reply thing were alittle bit stressful before christmas turn out i was just stupid and there was just an error in the config when the mirror didnt connect to the home network and because of that i just got a blank mirror i didnt notice that it was on but just not displaying anything. thank you so much for your help
                J 1 Reply Last reply Reply Quote 2
                  jturczak @SILLEN 0
                  @SILLEN-0 lol yeah that config file can be touchy. I’m glad you figured it out. Happy new year!
