    Compliments region size
    17 Posts 2 Posters 6.2k Views 2 Watching
    • 0
      0livia
      Good morning magic guys :)
      The thing is that the mirror is up an’ running now, but have a little frontend issue. Screenshot has been attached.
      As in the subject I need to modify the size of the compliments region, or need to modify the font size. Do not know yet. So need a little brainstorming to find out what would be the best thing to do.
      I have read the css thingy and what i understand is that, i need to modify the css file. Someone wrote it earlier that i need to use a custom css and not the main css.
      What I would like to achive is that the compliments module need to be smaller or the fonts.
      Anyone out there who can light the shed?Screenshot at 2022-12-29 10-45-35.png
      0 1 Reply Last reply
      • 0
        0livia @0livia
        I modified the custom css, reduced from 66% to 55% and the compliments module gone. :)
        here is the custom css
        * Beware that properties cannot be unitless, so for example write '--gap-body: 0px;' instead of just '--gap-body: 0;'
         * MIT Licensed.
        /* Uncomment and adjust accordingly if you want to import another font from the google-fonts-api: */
        /* @import url('https://fonts.googleapis.com/css2?family=Poppins:wght@100;300;400;700&display=swap'); */
        :root {
          --color-text: #999;
          --color-text-dimmed: #666;
          --color-text-bright: #fff;
          --color-background: black;
          --font-primary: "Roboto Condensed";
          --font-secondary: "Roboto";
          --font-size: 20px;
          --font-size-small: 0.75rem;
          --gap-body-top: 60px;
          --gap-body-right: 60px;
          --gap-body-bottom: 60px;
          --gap-body-left: 60px;
          --gap-modules: 30px;
        .region.lower.third {
          top: 55%;
          sdetweil @0livia
          @0livia the compliments module provides a configuration option for changing the style of the text
          so you don’t have to do a custom css entry
          also css override for a specific module you would do
          .modulename  .classname {
              style_setting:value;
          for compliments this might look like override value of xlarge class)
          .compliments  .xlarge {
                font-size: 20px;
          • 0
            0livia @sdetweil
            @sdetweil Thank you!
            It’s just do not work :(
            I have modified the config js and the module gone with the below config
            			module: "compliments",
            			position: "lower_third",
            				classes: "thin"
            I even tried with the custom css and still do not work. and the module is missing
            • 0
              0livia @0livia
              @0livia what ever i change in the config js is not working. I give up.
              From backup I copied back the original config js and now it is not working even with the correct config js file. Why so complicated? :(
              • 0
                0livia @0livia
                @0livia this config.js file was working as you can see the screenshot above.
                /* MagicMirror² Config Sample
                 * By Michael Teeuw https://michaelteeuw.nl
                 * MIT Licensed.
                 * see https://docs.magicmirror.builders/configuration/introduction.html
                 * and https://docs.magicmirror.builders/modules/configuration.html
                let config = {
                	address: "localhost", 	// Address to listen on, can be:
                	port: 8080,
                	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                	language: "hu",
                	locale: "hu-HU",
                	timeFormat: 24,
                	units: "metric",
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			header: "US Holidays",
                						symbol: "calendar-check",
                						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                			module: "weather",
                				type: "current",
                				locationID: "3044475", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                				apiKey: "87546dddc88d456621701a4e2a8340bbc"
                			module: "weather",
                			header: "Weather Forecast",
                				type: "forecast",
                				locationID: "2024058", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                				apiKey: "65863ddc88d785401a4e2a8340bbc"
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "HVG TECH TUDOMÁNY HÍREK",
                						url: "http://hvg.hu/rss/tudomany"
                						title: "BBC VILÁG HÍREK",
                						url: "http://feeds.bbci.co.uk/news/world/rss.xml"
                						title: "TELEX HÍREK",
                						url: "https://telex.hu/rss"
                				showSourceTitle: true,
                				showPublishDate: true,
                				broadcastNewsFeeds: true,
                				broadcastNewsUpdates: true
                       module: "MMM-network-signal",
                           // Configuration of the module goes here
                        module: 'MMM-Futar',
                        position: 'top_center',
                        header: 'Szigetszentmiklós -> Csepel Szent Imre tér',
                        stopId: 'BKK_044033',
                        routeId: 'BKK_2380',
                        stopId: 'BKK_044034',
                        routeId: 'BKK_0380',
                        header: 'Ráckeve -> Közvágóhíd',
                        stopId: 'BKK_F04614',  // Ráckeve
                        routeId: 'BKK_H6',
                        position: "top_center",
                        header: 'Közvágóhíd -> Ráckeve',
                        stopId: 'BKK_F04613',  // Közvágóhíd
                        routeId: 'BKK_H6',
                • 0
                  0livia @0livia
                  @0livia So yeah gave up, i m not a programer, just only love computers. This mirror thingy is good project but it is for only people who are programers, or have plenty of time to mucking about the settings and working out things. Unfortunately I have not got that much time. So yeah compliments is a good feature but without it, the mirror works for my parents with the important info displayed on it. The mirror is hanging on the wall now and leave it like as it is.
                    sdetweil @0livia
                    @0livia the default classes provide 3 different settings
                    size
                    stroke size
                    color
                    xlarge
                    thin
                    bright
                    u only set 1, thin.
                    why so hard, mm is a web page, using std html and styles. and every module does their own thing.
                    good or bad, the tools are detailed and cover a large area of configurability.
                    there are people that spend their entire careers working on ‘good’ look and feel.
                    • 0
                      0livia
                      @sdetweil yes i set one thing which would be enough i do not needed anything just reduce the size that is it.
                      yes maybe it is a standard webpage i do not argue all i say is that it is complacated, brackets, dots, etc etc a lot of silly things which makes the mirror crash if too much dots etc etc
                      that is why i said that it is good for programers, and people with plenty of time.
                      As a noon programer, the details are not very informative to a R1 user even if it is covered. For example no proper example just look at the image what you upload. I would not have clue if you did not write an example how to use. I respect for those ppl, but why so hard to write the documetation with examples for stupid users like me.
                      I built the mirror in 2017 it was working ok and not needed any help to make it work,than an upgrade came which crashed the mirror. (like windows :D ) My parents asked me to repair the mirror, but have no time to debug things. So the end of the year i reinstalled the whole thing, and it is just a chaos for me, ’ cos whatever module I tried to install all goes wrong started with the futar, now it is the compliments thing, and see there is still no solution what the hack is going on. But it s a standard webpage :)
                      See the config file above - it was all working, I copied back the config and still no joy. So you canot say that this a standrd webpage, it is more than that as it uses electron ,node and so on. This thing needs to make it easier to configure, or set things. What is obvious for a programer is not obvious for stupid user who would like to use it and even donate the project. Because it is complicated and spending time on it and gives no joy, it makes me angry and just give up :)
                        sdetweil @0livia
                        @0livia yes it’s a challenge to build and maintain.
                        sadly the mmm-futar module author hasn’t updated his module to match MagicMirror changes from 2 years ago.
                        • 0
                          0livia @sdetweil
                          @sdetweil yes it is nothing wrong with building and maintaining as long as it is straight forward (like linux) but as i said it is not straight forward.
                          Anyway do you know what could be the problem now, as my mirror has the original working config js which worked until i started to make changes to the complement module? It is not even showing up on the screen. no error message nothing, so the config file should be ok, but why there is not showing up the module?
                          Maybe this is a bug?
                            sdetweil @0livia
                            @0livia not a bug.
                            we removed some libraries that were discontinued. many module developers didn’t know how to describe their module dependencies, so they didn’t.
                            futar has this problem
                            now mm crashes cause the lib is missing
                            if u had used my upgrade script I would have fixed this for you.
                            I wrote this 6 releases ago to help users work around the problem(s)
                            https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1
                            • 0
                              0livia @sdetweil
                              @sdetweil thank you for the script! I do not know if it was available on that time when the update came out, so i did the upgrade as it was in TFM. And boom it crashed, i tried to figure out what was the problem even reading log files. I was ok fak it. As my parents kept asking me about the mirrror so decided to rebuild again. And the thing is this project runs a few xears now and it has not changed the “user interface” to make it easier to setup the modules. You know what, the project should develope in a better way to make this project available to ppl who do not have those programing skills. I mean it would be great for example if all the settings would be available in the modules and the user can choose what he/she activate with a toggle button or what so ever, and not playing around with config files and npm install npm start and all tha crazy stuff. As i said it is ok for programers whom actually write the modules or the core system. But if you want bormal users to participate in the project than i think it should be a good way to reduce the complicty to configure a module or install a module.
                              Anyway do we know why the compliment module gone? :)
                                sdetweil @0livia
                                @0livia why gone? bad css?
                                rename custom.css css.save
                                remove the classes from config entry
                                (do one at a time)
                                mm config easier
                                u can try my MMM-Config module which presents a form for mm and module config.
                                https://github.com/sdetweil/MMM-Config
                                but it’s not perfect, as I try to discover things not documented by module authors.
                                most of the time it’s great, but sometimes it crashes too.
                                • 0
                                  0livia @sdetweil
                                  @sdetweil no there is no custom.css file - removed
                                  config.js file has been overwritten with the working one.
                                  so basicly the config and all files are remain the same as it was working earlier.
                                  That is why i do not understand what is going on because all the working files were loaded, so the compliment should appear on screen.
                                  That is why I asked is it a kind of bug.?
                                    sdetweil @0livia
                                    @0livia I do not know…
                                    show.me the mm startup messages from npm start or pm2 logs --lines=50
                                    pm2 flush will throw away all prior messages
                                    • 0
                                      0livia @sdetweil
                                      @sdetweil i do not use pm2, when i have got time i ll give you log this is next year as im going to greece to get ddfdsking orange with the truck. So happy new year guys
