    modules
    23 Posts 2 Posters 7.7k Views 2 Watching
      pat59
      Hello
      after an update I do not find on my mirror 3 modules out of 5 installed how to view them thank you
        sdetweil @pat59
        @pat59 you need to look at the output of npm start, or use pm2 logs --lines=nnn
        nnn is some number bigger than 15
        did u run the auth program after you fixed the credential file?
          sdetweil @pat59
          @pat59 can u explain more?
          do not find?
            pat59
            by setting up a module at startup black screen (electron) I made an upgrade of electron the mirror started but there are hidden modules. check the MM logs for more detail:.
            sorry i am a newbie thank you.
            my best wishes for 2023
              sdetweil @pat59
              @pat59 black screen
              see
              https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1
                pat59
                20230124_190715.jpg 20230124_190715.jpg good evening here I am back after
                abscence I am always at the same point 3 modules d displayed out of 5 planned!20230124_185102.jpg 20230124_190715.jpg
                  sdetweil @pat59
                  @pat59 show the output of the startup messages, where u do npm start
                  also reminder that names are case sensitive in Linux,
                  and show the config of one missing module,
                  blank out any apikey, or pii
                    pat59
                    voila after npm start
                    magicmirror@2.22.0 start
                    [24.01.2023 20:30.45.948] [LOG] Starting MagicMirror: v2.22.0
                    [24.01.2023 20:30.45.965] [LOG] Loading config …
                    [24.01.2023 20:30.45.999] [LOG] Loading module helpers …
                    [24.01.2023 20:30.46.430] [LOG] Initializing new module helper …
                    [24.01.2023 20:30.46.433] [LOG] Module helper loaded: MMM-Remote-Control
                    [24.01.2023 20:30.46.480] [LOG] Initializing new module helper …
                    [24.01.2023 20:30.46.483] [LOG] Module helper loaded: MMM-Saint
                    [24.01.2023 20:30.46.487] [LOG] No helper found for module: alert.
                    [24.01.2023 20:30.46.508] [LOG] Initializing new module helper …
                    [24.01.2023 20:30.46.510] [LOG] Module helper loaded: updatenotification
                    [24.01.2023 20:30.46.513] [LOG] No helper found for module: MMM-FlipClock.
                    [24.01.2023 20:30.46.516] [LOG] No helper found for module: clock.
                    [24.01.2023 20:30.47.290] [LOG] Initializing new module helper …
                    [24.01.2023 20:30.47.292] [LOG] Module helper loaded: calendar
                    [24.01.2023 20:30.47.310] [LOG] Initializing new module helper …
                    [24.01.2023 20:30.47.311] [LOG] Module helper loaded: MMM-BME280
                    [24.01.2023 20:30.47.312] [LOG] No helper found for module: MMM-OpenmapWeather.
                    [24.01.2023 20:30.47.314] [LOG] No helper found for module: MMM-WiFiPassword.
                    [24.01.2023 20:30.47.421] [LOG] Initializing new module helper …
                    [24.01.2023 20:30.47.423] [LOG] Module helper loaded: newsfeed
                    [24.01.2023 20:30.47.424] [LOG] All module helpers loaded.
                    [24.01.2023 20:30.47.826] [LOG] Starting server on port 8080 …
                    [24.01.2023 20:30.47.844] [WARN] You’re using a full whitelist configuration to allow for all IPs
                    [24.01.2023 20:30.47.880] [ERROR] Whoops! There was an uncaught exception…
                    [24.01.2023 20:30.47.893] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                    at Server.setupListenHandle [as _listen2] (node:net:1432:16)
                    at listenInCluster (node:net:1480:12)
                    at doListen (node:net:1629:7)
                    at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
                    code: ‘EADDRINUSE’,
                    errno: -98,
                    syscall: ‘listen’,
                    address: ‘0.0.0.0’,
                    port: 8080
                    [24.01.2023 20:30.47.894] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [24.01.2023 20:30.47.895] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [24.01.2023 20:30.48.740] [LOG] Launching application.
                    [1778:0124/203050.294017:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                    [1807:0124/203050.622575:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                      sdetweil @pat59
                      @pat59
                      code: ‘EADDRINUSE’,
                      errno: -98,
                      syscall: ‘listen’,
                      address: ‘0.0.0.0’,
                      port: 8080
                      that means something else is running using that address port combination
                      usually this means starting another mm instance without stopping the prior one.
                        pat59
                        Hello
                        I couldn’t get it to work, so I started all over again.
                        now it works , i installed googlephotos and i get error message ,so it can not open google account browser to get code thanks for your help.
                        pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node generate_token_v2.js
                        (node:3448) UnhandledPromiseRejectionWarning: Error: The provided keyfile does not define a valid
                        redirect URI. There must be at least one redirect URI defined, and this sample
                        assumes it redirects to ‘http://localhost:3000/oauth2callback’. Please edit
                        your keyfile, and add a ‘redirect_uris’ section. For example:
                        “redirect_uris”: [
                        “http://localhost:3000/oauth2callback”
                        at authenticate (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/@google-cloud/local-auth/build/src/index.js:51:15)
                        at generate (/home/pi/MagicMirror/modules/MMM-GooglePhotos/generate_token_v2.js:13:24)
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GooglePhotos/generate_token_v2.js:27:1)
                        at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                        at startup (internal/bootstrap/node.js:283:19)
                        (node:3448) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
                        (node:3448) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                        pi@rasp
                          sdetweil @pat59
                          @pat59 ok. it tells u the problem and how to work around it. did u do that?
                            pat59 @sdetweil
                            @sdetweil Hello and thank you for your feedback.
                            no nothing do I can not understand what I have to do sorry thank you
                              sdetweil @pat59
                              @pat59
                              “redirect_uris”: [
                              the keyfile is the thing u downloaded from google
                                pat59
                                yes, I did download a file that I renamed credential.js and placed in the googlePhotos module of the magicmirror.
                                that’s good what you’re talking about thank you
                                  sdetweil @pat59
                                  @pat59 did u edit the file and add the missing info?
                                  if u do not understand the English text, translate it into your native language
                                    pat59
                                    no, I haven’t changed anything. Simply downloaded client ID and client secret code then placed in the googlephotos module.
                                    I will try to find by searching and come back to you if I do not find I thank you in advance thank you my friend
                                      pat59
                                      I understand that it is necessary to modify the credential.js key by adding redirect_uris but I do not see where the site is.
                                      {“installed”:{“client_id”:“315406544684-crlbfk6kon4bel61nkcpj59dt6s352dm.apps.googleusercontent.com”,“project_id”:“magicmirror-376414”,“auth_uri”:“https://accounts.google.com/o/oauth2 /auth”,“token_uri”:“https://oauth2.googleapis.com/token",“auth_provider_x509_cert_url”:“https://www.googleapis.com/oauth2/v1/certs”,“client_secret”:"GOCSPX -nqP06oYf_sZqPBlPJEw_hceNZhy2”}}
                                        sdetweil @pat59
                                        @pat59 yes, YOU have to add it along side the others
                                        or go back to Google and add it there and download again
                                          pat59
                                          Good morning
                                          ok I will look at this during the day, I would say thank you again for your patience.
                                          thank you my friend
                                            pat59
                                            Good morning .
                                            does the location of the https://localhost redirect uri have a specific place in the API key, thank you
                                            Cordially
                                              sdetweil @pat59
                                              @pat59 not specific. but I recommend you go back to the Google console and add it there, and download the file again
