    MMM-network-signal coloring the icon
    8 Posts 4 Posters 1.4k Views 4 Watching
      alphanet @Bursucel
      @Bursucel
      Thank you very much for your reply.
      Here’s the 58 line of the MMM-network-signal .js file :
      connStatus.style = “text-align:center;font-size:0.65”;
      Should I add a key:value like : color:#00FF00 ->
      connStatus.style = “text-align:center;font-size:0.65;color:#00FF00”;
      Thank you in advance for your confirmation.
      S A 2 Replies Last reply Reply Quote 0
        sdetweil @alphanet
        @alphanet never edit the code. u can do this in custom.css
        sometimes there is a class to override, sometimes not, but you can use html tag names, IDs …
        see
        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1673214232124
          alphanet @alphanet
          @alphanet
          Thank you very much for your reply and recommandation sdetweil.
          Your link seems very interesting and should help me to learn plenty of things about the Magic Mirror and to solve the color of MMM_network-signal.
          • plainbrokeP Offline
            plainbroke
            Wish I could figure out the CSS stuff. Sometimes it seems so simple and others I have no clue how to even begin.
              sdetweil @plainbroke
              @plainbroke use my link above, its really very easy to use… KNOWing what to SET things too is the hard part…
              its a whole nother language all its own…
              selecting the element is the key, and then applying the style to that element…
              this is the selector cheat-sheet I like to use
              https://www.w3schools.com/cssref/css_selectors.php
              this is the set of things to the left of { in the thing in custom.css
              .modulename .class  div >ul {
                 color: blue;
              so leading dot means class name
              no dot means html tag img, div, span ul, li, table, tr, whatever
              leading # means id
               <div id="something"
              #something
              then u can find children or anyhow…
              the dev window tool will allow you select the content element u want, and see the css tree on the right column.
              css is inheritance based…
              main.css is the base
              module provided css is next, (may replace/override) prior instances
              then custom.css is last , always wins (well, sometimes!)
              so the right column is base at the bottom and then things on top of it…
              each ‘thing’ will tell u where it came from (file, main.css, modulename.css, or custom.css
              you can type new styles in the top right window,click, type color enter and then u will be in the value side and there will be a dropdown of possible predefined values…
              you can control anything and everything from here
              and then you can copy paste everything in that top box to custom.css and then u put the selector wrapper around it…
                @plainbroke the other thing is positioning
                there are two modes relative and absolute
                a web page is layed out with 0 in the top left corner (0,0) (or right in rtl languages)
                in relative mode, content is positioned RELATIVE to the containing element it is in
                text in a div , if centered, is in the center of the div space, wherever it is.
                there are different measurement types
                pixels, physical (absolute)
                els(element size), content relative (size of text)
                %, shape relative. (size of div)
                vh/vw% - size of the visible page h= height w= width
                pixels is easy but if the screen size changes, the pixels don’t.
                in absolute mode, everything is relative to the 0,0 corner.
                by default content is top down , FIFO.
                first in, first out.
                but you can use flex to change the preference from vertical to horizontal. and which end is the start or end.
                and then there is grid. yikes!
                fonts and colors and shadings and animations (fade and zoom and transparency!)
