    MMM-EveryNews is not loading anything
    7 Posts 2 Posters 1.7k Views 2 Watching
      JeanMichelC
      Re: MMM-EveryNews is not loading anything
      I disabled all modules to try to debug this issue but still could not get any news loaded and no errors using rpm start dev.
      It says “Anyone’s presents…”
      I don’t have any Google modules loaded.
        sdetweil @JeanMichelC
        @JeanMichelC yeh, no error is reported… do this
        edit the node_helper.js and
        change this
        }, (error, response, body) => {
                    if (!error && response.statusCode == 200) {
                            var result = JSON.parse(body).articles;
                            this.sendSocketNotification('NATGEO_RESULT', result);
        to this
                    if (!error) {
                        if(response.statusCode == 200) {
                        } else {
                             console.error(this.name+" status failed=",response.statusCode)
                    } else {
                        console.error(this.name+" error=",error)
        with a bad api key I see on the console now
        [11.01.2023 12:45.23.391] [ERROR] MMM-EveryNews status failed= 401
        using the config provided in the module readme
          JeanMichelC
          I edtited node_helper.js in this folder MagicMirror/js and could not find the code you asked me to change. The only reference I found that checking the response return code 200 is
          NodeHelper.checkFetchStatus = function (response) {
          // response.status >= 200 && response.status < 300
          if (response.ok) {
          return response;
          } else {
          throw Error(response.statusText);
            JeanMichelC
            I was looking in the wrong folder, I found it in the MMM-EveryNews folder, making changes now
              JeanMichelC
              @sdetweil said in MMM-EveryNews is not loading anything:
                     if (!error) {
                          } else {
                      } else {
              I get a Bad Request 400 response code, any idea?
              This is the entry in the config.js file
              disabled: false,
              module: ‘MMM-EveryNews’,
              position: ‘top right’,
              source: “msnbc”, // any source from https://newsapi.org/sources. // Up to 10 at once
              scroll: true, // description scroll or static
              scrollSpeed: “3”, // if scroll is true
              apiKey: “xxxxxxxxxxxxxxxxxxxxxxxx”, // free API key from https://newsapi.org/register
              useHeader: true, // False if you don’t want a header
              header: “Over 30,000 News Sources!”, // Any text you want. useHeader must be true
              maxWidth: “350px”,
              animationSpeed: 3000, // fade speed
              rotateInterval: 5 * 60 * 1000,
              I tested the API key on NewsAPI site and it worked fine
                @JeanMichelC no… my guess is that the api has changed and the module has not been updated.
                the author is currently not available.
                but, see the comments in issue 5
                https://github.com/mykle1/MMM-EveryNews/issues/5
                  JeanMichelC
                  Thanks Sam for pointing me to issue#6, I applied the changed and now it’s working! I really appreciate your help.
