    MMM-EveryNews is not loading anything
    8 Posts 5 Posters 1.6k Views 5 Watching
      alee961
      I can’t get MMM-EveryNews to work. I have the API key, but it just displays “AnyNews Presents”.8ad5e7ab-03d1-49fc-bef4-d2f3dfdcf6f3-image.png
        Mykle1 Project Sponsor Module Developer @alee961
        @alee961 said in MMM-EveryNews is not loading anything:
        I assure you, the module is working. Have you checked that your api is entered correctly? Please start MM using the command npm start dev. Check the console tab in the window that opens for errors (in red) and report them here.
                disabled: false,
                  module: 'MMM-EveryNews',
                  position: 'bottom center',
                    source: 'bbc-news,cbs-news,fox-news,nbc-news,national-geographic',      // any source from https://newsapi.org/
                    scroll: true,                                  // description scroll or static
                    scrollSpeed: "3",                              // if scroll is true
                    apiKey: 'Make sure this is correct',    // free API key from https://newsapi.org/register
                    useHeader: true,                               // False if you don't want a header
                    header: "Over 30,000 News Sources!",           // Any text you want. useHeader must be true
                    maxWidth: "350px",
                    animationSpeed: 3000,                          // fade speed
                    rotateInterval: 5 * 60 * 1000,
          Dimasua
          My MMM-EveryNews is not loading when Google Maps module is running. When I stop Google Maps, than MMM-EveryNews works again.
            I read that the issue was with Google Maps and has been corrected by user @sdetweil
            • cowboysdudeC Offline
              cowboysdude Module Developer
              @sdetweil thanks for fixing @Mykle1 screw up LOL
                sdetweil @Mykle1
                @Mykle1 GoogleMapsTraffic
                  Yah, he was just messing with me :-)
                  cowboysdudeC 1 Reply Last reply Reply Quote 1
                    cowboysdude Module Developer @Mykle1
                    @Mykle1 LOL
