Unsolved ChatGpt intergration
@SILLEN-0 did the node helper get a response from lib?
i think the problem is with node helper not actually sending a api request because if i look in usage tab on the openai api page it should show activity but it says that it has not recieved any api requests:
but it should work! im going too look into it now and see if i can fix it. -
@SILLEN-0 as I said add console.log statements to the node helper so you can see the flow in the console output…
yea i just did that and i get this error in the console:
0|MagicMirror | [14.01.2023 13:01.03.714] [LOG] Received QUESTION notification with payload: What is the weather like today? 0|MagicMirror | [14.01.2023 13:01.03.724] [LOG] Error in getResponse: TypeError: Cannot set properties of undefined (setting 'apiKey') 0|MagicMirror | at /home/pi/MagicMirror/modules/chatgpt/node_helper.js:12:27 0|MagicMirror | at new Promise (<anonymous>) 0|MagicMirror | at Class.getResponse (/home/pi/MagicMirror/modules/chatgpt/node_helper.js:11:16) 0|MagicMirror | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/chatgpt/node_helper.js:31:18) 0|MagicMirror | at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:108:11) 0|MagicMirror | at Socket.emit (node:events:513:28) 0|MagicMirror | at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22) 0|MagicMirror | at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:614:39 0|MagicMirror | at process.processTicksAndRejections (node:internal/process/task_queues:78:11)
and this is my node_helper file:
const NodeHelper = require("node_helper"); const openai = require("openai").default; console.log(openai); module.exports = NodeHelper.create({ start: function() { console.log("Starting node helper for: " + this.name); }, // Send a message to the chatGPT API and receive a response getResponse: function(question) { return new Promise((resolve, reject) => { openai.apiKey = "XXXXXXXXXXXXXX"; openai.Completion.create({ prompt: question, temperature: 0.7 }, (error, response) => { if (error) { reject(error); } else { console.log("Received response from API: ", response); resolve(response.choices[0].text); } }); }); }, // Handle socket notifications socketNotificationReceived: function(notification, payload) { if (notification === "QUESTION") { console.log("Received QUESTION notification with payload: ", payload); this.getResponse(payload) .then((response) => { console.log("Sending RESPONSE notification with payload: ", response); this.sendSocketNotification("RESPONSE", response); }) .catch((error) => { console.log("Error in getResponse: ", error); }); } }, });
@SILLEN-0 was openainin context before the
return new Promise inside getResponse() -
@sdetweil if im honest i have no idea what you mean by that. as i said i am very bad at any sort of coding this whole thing is held up with ducktape could you try to explain more what you mean by that?
@SILLEN-0 the error says that at the time of trying to to assign the apiKey to the openai object, the openai object is null (0)
‘undefined’ here is openai,
so, I see you print the object just after the require() at the top
and ‘assume’ that you looked at the output of npm start (where console.log messages go) and are satisfied that the require(‘openai’) worked
so now to check again later
so I would add and another console.log(openai)
after the getResponse:getResponse: function(question) { // here .. is the openai object good (not null) here? return new Promise((resolve, reject) => { openai.apiKey = "XXXXXXXXXXXXXX"; // this is the statement that failed
HOLY SHIT I GOT IT TOO WORK!. ok i need to calm down i am so happy right now. so turn out i was just trying too call the everything with openai.apiKey instead of just apiKey and then i had too do somthing else i dont even remember what i did but now i got it too work and it displays on the magicmirror. but now comes the hard part. if you look in the code there is a variabele named question that the prompt uses and send too the api. and i am no expert but can you have the variable question be defined with some kind of speech too text thing?
@SILLEN-0 said in ChatGpt intergration:
i don’t know what you mean…
unless u want to capture speech and convert that to the text for openai
welcome to the problem I have highlighted since the beginning… there is no GOOD speech capture library, and nothing built in.
this is why the MMM-GoogleAssistant provides mechanisms (recipe) to use the captured text for non- google uses.
MMM-Voice uses the pocketsphinx lib, from carnegie mellon, I think this one is terrible for me, <60% accurate and I have to keep saying it over and over.
GA and most others use cloud based services (none free)
but put a filter (hotword, like ok google, or alexa) in front to keep the cost down, not convert everything.the other mirror platform I support , smart-mirror , is voice based, so your ‘plugin’ can get the text from the speech. not compatible with MM.
i have MMM-googleassistant and i have used the recipes for some other stuff but could you get that too work with chatgpt. saying somthing like "ok-google chatgpt followed by the question you want too ask and then it takes the question makes it a variable or somthing that the prompt can read and then refresh the answer on the magicmirror. also what do you mean by (none free) MMM-google assistant is free. but i think it wouldnt be a big issue having too pay for chat gpt as in all of my testing and making api calls i have only paid 0.09 usd
