    Black screen on HMDI output, content on remote browser
    25 Posts 3 Posters 9.3k Views 3 Watching
      chris_d @sdetweil
      @sdetweil That didn’t seem to work. It did eliminate any errors on startup, but the screen remainis blank.
      the command to start in mm.sh is
      DISPLAY=:0 npm start
        sdetweil @chris_d
        @chris_d yes, so you would ad the export before the
        DISPLAY… npm start line…
        so, lets try something else
        stop magicmirror
        then
        ./node_modules/.bin/electron
        does electron window come up?
          chris_d @sdetweil
          No. I get ./node_modules/.bin.electron: No such file or directory
            sdetweil @chris_d
            @chris_d sorry typo in my instructions, a dot instead of a slash… see and try again
              chris_d @sdetweil
              The platform failed to initialize.Missing X server or $DISPLAY
                sdetweil @chris_d
                @chris_d you are running the full desktop os, right? text/cli mode doesn’t work, unless u want to run server only and view from somewhere else.
                  chris_d @sdetweil
                  @sdetweil I am running the full desktop. yes.
                  This used to work but following a Magic Mirror and pi system update it no longer does.
                  I can see the desktop on boot up, but when pm2 runs the mirror then I get the blank screen.
                    sdetweil @chris_d
                    @chris_d
                    which pi os?
                    lsb_release -a
                    how did u open that terminal window?
                      chris_d @sdetweil
                      @sdetweil said in Black screen on HMDI output, content on remote browser:
                      lsb_release -a
                      Distributor ID: Raspbian
                      Description: Raspbian GNU/Linux 10 (buster)
                      Release: 10
                      Codename: buster
                      I am using ssh to remote into the pi
                      The following thread seems similar, but does not offer a solution
                      https://forum.magicmirror.builders/topic/17211/having-trouble-with-launch-perhaps-display-value?page=1
                        sdetweil @chris_d
                        @chris_d interesting. I ssh into my mirror systems all the time and never have trouble.
                        do
                        pm2 stop all
                        npm start >somefile.txt 2>&1
                        wait til the black screen
                        ctrl-c in the ssh terminal
                        then nano somefile.txt, scroll down
                        see if there are any errors reported…
                        the package.json will set DISPLAY if not set
