    Black screen on HMDI output, content on remote browser
    25 Posts 3 Posters 10.7k Views 3 Watching
      chris_d
      I have recently updated and rebuilt my MM installation.
      I can browse to my MM via a remote web browser and things display fine, however on the HDMI output of the PI itself I just have a black screen.
      In the logs I see,
      [1502:0115/164948.881957:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      [1538:0115/164949.052412:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
      [1507:0115/164949.107262:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      I wonder if anyone might be able to point me in the right direction.
        sdetweil @chris_d
        @chris_d maybe turn off GPU useage
        in the place where u start MM do
        export ELECTRN_DISABLE_GPU=1
        before the npm start line
        if using pm2, that is ~/MagicMirror/installers/mm.sh
        to test , if using pm2, then
        pm2 stop all
        npm start
        if it works, update the mm.sh
        and then pm2 start all
          chris_d @sdetweil
          @sdetweil That didn’t seem to work. It did eliminate any errors on startup, but the screen remainis blank.
          the command to start in mm.sh is
          DISPLAY=:0 npm start
            sdetweil @chris_d
            @chris_d yes, so you would ad the export before the
            DISPLAY… npm start line…
            so, lets try something else
            stop magicmirror
            then
            ./node_modules/.bin/electron
            does electron window come up?
              chris_d @sdetweil
              No. I get ./node_modules/.bin.electron: No such file or directory
                sdetweil @chris_d
                @chris_d sorry typo in my instructions, a dot instead of a slash… see and try again
                  chris_d @sdetweil
                  The platform failed to initialize.Missing X server or $DISPLAY
                    sdetweil @chris_d
                    @chris_d you are running the full desktop os, right? text/cli mode doesn’t work, unless u want to run server only and view from somewhere else.
                      chris_d @sdetweil
                      @sdetweil I am running the full desktop. yes.
                      This used to work but following a Magic Mirror and pi system update it no longer does.
                      I can see the desktop on boot up, but when pm2 runs the mirror then I get the blank screen.
                        sdetweil @chris_d
                        @chris_d
                        which pi os?
                        lsb_release -a
                        how did u open that terminal window?
                          chris_d @sdetweil
                          @sdetweil said in Black screen on HMDI output, content on remote browser:
                          lsb_release -a
                          Distributor ID: Raspbian
                          Description: Raspbian GNU/Linux 10 (buster)
                          Release: 10
                          Codename: buster
                          I am using ssh to remote into the pi
                          The following thread seems similar, but does not offer a solution
                          https://forum.magicmirror.builders/topic/17211/having-trouble-with-launch-perhaps-display-value?page=1
                            sdetweil @chris_d
                            @chris_d interesting. I ssh into my mirror systems all the time and never have trouble.
                            do
                            pm2 stop all
                            npm start >somefile.txt 2>&1
                            wait til the black screen
                            ctrl-c in the ssh terminal
                            then nano somefile.txt, scroll down
                            see if there are any errors reported…
                            the package.json will set DISPLAY if not set
                              chris_d @sdetweil
                              pm2 stop all
                              Errors are:
                              [2883:0119/213451.321388:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                              [2916:0119/213451.509005:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                                sdetweil @chris_d
                                @chris_d in from to the npm start line do
                                export ELECTRON_DISABLE_GPU=1
                                and rerun…
                                  chris_d @sdetweil
                                  No error now, but still a black screen
                                    sdetweil @chris_d
                                    @chris_d on the black screen press ctrl-shift-i to open the developers window, then select the console tab and scroll up for any errors usually red text
                                      MikeBishop @sdetweil
                                      I’m having what appears to be the same problem – HDMI is black (but apparently happy from the log output), while browser access is fine. I can’t get the dev tools to come up in Electron; perhaps unsurprisingly, the browser dev tools don’t show any errors that weren’t there on my old instance.
                                        sdetweil @MikeBishop
                                        @MikeBishop are you also running on buster?
                                          sdetweil @chris_d
                                          @chris_d try npm start dev to open dev window on startup
                                          also can u try the npm start on the pi desktop, not over ssh?
                                            Bullseye, looks like. Whatever’s in the newest RPi OS release, anyway.
                                            For the moment, I’ve swapped back to the other SD card that’s working. System’s been a little flaky the last few days, figured I’d try a fresh install on a new card in case that’s starting to go; hit this issue on the new one. When I have a few minutes to pull the Pi from the mirror and bring it back to my desk, I’ll give npm start dev a try on the newer one.
