    Black screen on HMDI output, content on remote browser
    25 Posts 3 Posters 9.2k Views 3 Watching
      chris_d
      I have recently updated and rebuilt my MM installation.
      I can browse to my MM via a remote web browser and things display fine, however on the HDMI output of the PI itself I just have a black screen.
      In the logs I see,
      [1502:0115/164948.881957:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      [1538:0115/164949.052412:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
      [1507:0115/164949.107262:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      I wonder if anyone might be able to point me in the right direction.
        sdetweil @chris_d
        @chris_d maybe turn off GPU useage
        in the place where u start MM do
        export ELECTRN_DISABLE_GPU=1
        before the npm start line
        if using pm2, that is ~/MagicMirror/installers/mm.sh
        to test , if using pm2, then
        pm2 stop all
        npm start
        if it works, update the mm.sh
        and then pm2 start all
          chris_d @sdetweil
          @sdetweil That didn’t seem to work. It did eliminate any errors on startup, but the screen remainis blank.
          the command to start in mm.sh is
          DISPLAY=:0 npm start
            sdetweil @chris_d
            @chris_d yes, so you would ad the export before the
            DISPLAY… npm start line…
            so, lets try something else
            stop magicmirror
            then
            ./node_modules/.bin/electron
            does electron window come up?
              chris_d @sdetweil
              No. I get ./node_modules/.bin.electron: No such file or directory
                sdetweil @chris_d
                @chris_d sorry typo in my instructions, a dot instead of a slash… see and try again
                  chris_d @sdetweil
                  The platform failed to initialize.Missing X server or $DISPLAY
                    sdetweil @chris_d
                    @chris_d you are running the full desktop os, right? text/cli mode doesn’t work, unless u want to run server only and view from somewhere else.
                      chris_d @sdetweil
                      @sdetweil I am running the full desktop. yes.
                      This used to work but following a Magic Mirror and pi system update it no longer does.
                      I can see the desktop on boot up, but when pm2 runs the mirror then I get the blank screen.
                        sdetweil @chris_d
                        @chris_d
                        which pi os?
                        lsb_release -a
                        how did u open that terminal window?
