    Black screen on HMDI output, content on remote browser
    25 Posts 3 Posters 13.1k Views 3 Watching
      sdetweil @MikeBishop
      @MikeBishop can u reflash bullseye and use my install script?
      M 1 Reply Last reply
        MikeBishop @sdetweil
        That’s actually how I installed this instance to begin with. However, I’ve narrowed my instance of the problem down.
        The node_helper for the module I wrote, MMM-Powerwall, has an async start() function. In previous MM versions, the startup code didn’t wait on async start functions to finish, and my init finished not long after MM started. This version includes the fix to wait for async modules to finish starting. I’ve confirmed that my start() function is running to the end, and MM does write
        [21.01.2023 14:30.25.915] [LOG]   Sockets connected & modules started ...
        …to the log, but apparently something about waiting on the module breaks the electron browser. If I hack the module to look synchronous, like so:
        start: /*async*/ function () {
        		this.asyncStart()
        asyncStart: async function () {
        …everything starts right up. Something about the timing or threading of waiting for modules to complete is making the electron launch fail, I think.
        My next step will be to make a module that does nothing but has an async node_helper and see if I can repro the issue with that.
        @chris_d, any chance that you’re also using a module with an async start function?
        M S C 3 Replies Last reply
          MikeBishop @MikeBishop
          Okay, I think I have a clean repro of the issue in https://github.com/MikeBishop/MMM-asyncdeath – the synchronous start function produces this in the logs and loads normally:
          [21.01.2023 14:55.02.692] [LOG]   Synchronous start-up -- all is well
          [21.01.2023 14:55.02.693] [LOG]   Sockets connected & modules started ...
          [21.01.2023 14:55.03.235] [LOG]   Launching application.
          The async start function produces this in the logs and fails:
          [21.01.2023 14:52.54.143] [LOG]   About to break by using await
          [21.01.2023 14:52.54.884] [LOG]   Launching application.
          [21.01.2023 14:52.56.512] [LOG]   Sockets connected & modules started ...
          Note the reversed order of “Launching application” and “modules started”. Seems feasible this could also happen with a synchronous module startup that takes a long time, but I haven’t tested that.
            @MikeBishop great work
            can you post your findings to issue
            https://github.com/MichMich/MagicMirror/issues/2487
            I reopened it
              chris_d @MikeBishop
              @MikeBishop I’m running MMM-Calendar3 and the default modules only.
