    PIR and config.js
    16 Posts 3 Posters 6.9k Views 4 Watching
    • N6NGN
      N6NG @shall_
      @shall_ Although it might help others if you don’t mind posting it here…
      Dennis
      • N6NGN
        N6NG
        I never saw an example of what the config.js would look like to have the vcgencmd be used to turn the screen on and off. Would someone post a part of a config.js with this in use so I can get a look at how it would be used? I would appreciate it.
        Thanks all
        Dennis
          sdetweil @N6NG
          @N6NG edit the node_hekper.js and see what it does. change as u see fit
          N6NGN 1 Reply Last reply
          • N6NGN
            N6NG @sdetweil
            @sdetweil Use the whole node_helper.js except as I modify it? The only thing I would modify would be the sensor pin number… All else would stay the same?
            • N6NGN
              N6NG @N6NG
              @N6NG Do I modify it where it is or do I copy it into the config.js ? If I modify it where it is and change the sensor pin what would I put in the config.js?
                sdetweil @N6NG
                @N6NG said in PIR and config.js:
                all you are doing is changing the vcgencmd string
                exec(“…”)
                then everything else is normal in config.js
                pin and commandType (I didn’t look at the module doc)
                • N6NGN
                  N6NG @sdetweil
                  @sdetweil Ok Sam… thanks I’ll give it a try and see how it does… will let you know…
                  Dennis
                  • N6NGN
                    N6NG @N6NG
                    @N6NG When I put the
                    exec (“/usr/bin/vcgencmd display_power 0”, null);
                    in the config.js I get an error. When I run npm run config:check it says that line has an Unexpected token
                    Dennis
                    S 2 Replies Last reply
                      sdetweil @N6NG
                      @N6NG be careful copy/paste, the forum without code marker uses the slanted. single and double quotes. used by word processing apps
                      JavaScript expects the upright versions
                      • N6NGN
                        N6NG @sdetweil
                        @sdetweil I typed it in straight from the keyboard… No copy and paste at all… Still the still the same error…
                        Dennis
                          sdetweil @N6NG
                          @N6NG that doesn’t go on config.js, it goes in the node_helper.js to replace what it already does, if it’s different.
                          • N6NGN
                            N6NG @sdetweil
                            @sdetweil Oh… ok… thanks… I’ll do that.
                            Dennis
