    MM in Container config lost after Container Stop/Start
    15 Posts 3 Posters 6.8k Views 3 Watching
      asdf303
      Hi all,
      I sucessfully setup a container from
      https://github.com/bastilimbach/docker-MagicMirror
      in server mode only.
      i put in my config, everything runs well.
      But: If i restart the container in portainer (click stop, click start), it starts, complains about config not to be found and restarts.
      If i take a look into my host data at /data/compose/mounts/config, everything is still there but log complains about not finding a config
      I have been running a MM installation on a raspberry pi for years, so it seems to be somehow container related. I am new to virtualization things, so please forgive my ignorance.
      Anyone any Ideas?
      Thank you in advance
      log snippet:
      [14.02.2023 15:26.10.982] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read properties of undefined (reading 'module')
      [14.02.2023 15:26.10.983] [ERROR] Whoops! There was an uncaught exception...
      [14.02.2023 15:26.10.986] [ERROR] TypeError: Cannot read properties of undefined (reading 'module')
          at /opt/magic_mirror/js/app.js:220:34
          at loadConfig (/opt/magic_mirror/js/app.js:81:4)
          at App.start (/opt/magic_mirror/js/app.js:212:3)
          at Object.<anonymous> (/opt/magic_mirror/serveronly/index.js:4:5)
          at Module._compile (node:internal/modules/cjs/loader:1226:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1280:10)
          at Module.load (node:internal/modules/cjs/loader:1089:32)
          at Module._load (node:internal/modules/cjs/loader:930:12)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
          at node:internal/main/run_main_module:23:47
      [14.02.2023 15:26.10.986] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [14.02.2023 15:26.10.986] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        asdf303 @sdetweil
        @sdetweil @karsten13 thanks a lot for your advice!
        finally, there was only one package missing
        npm install request
        did the job for me.
        :folded_hands_medium-light_skin_tone:
          sdetweil @asdf303
          @asdf303 that docker image is no longer supported, I suggest moving to the one from @karsten13
          https://hub.docker.com/r/karsten13/magicmirror/
            asdf303 @sdetweil
            @sdetweil thank you for your comment.
            Actually, my link above is wrong. My fault. Sorry.
            I am already using the image
            karsten13/magicmirror:latest.
            So, any further ideas?
              sdetweil @asdf303
              @asdf303 maybe @karsten13 will check this topic out
              • karsten13K Offline
                karsten13 @sdetweil
                my project is documented here https://khassel.gitlab.io/magicmirror/
                I don’t know the portainer setup and for further investigation we need to see
                • full log
                • your docker-compose.yml or the docker run ... command
                • full config.js
                Please remove any secrets before publishing here.
                  asdf303 @karsten13
                  @karsten13 Thank you for asking.
                  Please find all my stuff below
                  As mentioned above, it loads correctly and runs the configuration correctly on the first start.
                  Everything is fine.
                  But if the container is started/stopped in Portainer, it seems to not be able to find a correct config.js, as you can see in the log.
                  The only way to get it running is, i stop the container, remove the stack in Portainer, then navigate to /data/compose in the host system, manually delete all the data there (i use Winscp). Then i re-install everything (including e.g. the mmm-localtransport addon) acc. to the book, modify the config.js to what you can see below.
                  let config = {
                  	address: "0.0.0.0", 	// Address to listen on, can be:
                  	port: 8080,
                  	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                  	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.178.1/24"], 	// Set [] to allow all IP addresses
                  	ipWhitelist: [], 	// Set [] to allow all IP addresses
                  	language: "de",
                  	locale: "en-US",
                  	timeFormat: 24,
                  	units: "metric",
                  			module: "alert",
                  			module: "updatenotification",
                  			position: "top_bar"
                  			module: "clock",
                  					displaySeconds: false,
                  					displayType: "digital",
                  					clockBold: false,
                  			header: "Was passiert heute?",
                  				fade: false,
                  				timeFormat: 'absolute',
                  				dateFormat: '24',
                  				getRelative: 24,
                  				fetchInterval: 3600000,
                  					// der Abfallkalender
        symbol: "trash",
                                                         		url: "webcal://XXX"
                  					//private calendar
                  						symbol: "home",
                        					 	url: "XXX",
                          					auth: {
                  							user: "XXX",
                  							pass: "XXX",
                  							method: "basic"
                  			module: "compliments",
                  			position: "lower_third"
                  			module: "weather", //aktuelles Wetter
                  			//header: "aktuelles Wetter",
                  				fade: false,
                  				type: "current",
                  				locationID: "XXX",  //ID from http://www.openweathermap.org/help/city_list.txt
                  				apiKey: "XXX",
                  				roundTemp: true,
                  				maxNumberOfDays: 2,
                  			module: "weather", //Vorhersage
                  			header: "Vorhersage",
                  				fade: false,
                  				type: "forecast",
                  				apiKey: "xxx",
                  				roundTemp: true,
                  				maxNumberOfDays: 4,
                  			module: "newsfeed",
                  			position: "bottom_bar",
                  				feeds: [
                  						title: "Tagesschau",
                  						url: "https://www.tagesschau.de/xml/rss2"
                  				showSourceTitle: false,
                  				showPublishDate: false,
                  				wrapTitle: false,
                  		module: 'MMM-LocalTransport',
                  		header: 'Bus nach XXX',
                  		position: 'bottom_right',
                  			api_key: 'xxxx',
                  			origin: 'xxxx',
                  			destination: 'xxxx',
                  			maximumEntries: 3,
                  			displayArrival: false,
                  			displayWalkType: 'none',
                  			updateInterval: 60,
                  			displayStationLength: -1,
                  Here is the docker-compose.yml, copied from your project, unchanged:
                  version: '3'
                  services:
                    magicmirror:
                      container_name: mm
                      image: karsten13/magicmirror:latest
                      ports:
                        - "8080:8080"
                      volumes:
                        - ../mounts/config:/opt/magic_mirror/config
                        - ../mounts/modules:/opt/magic_mirror/modules
                        - ../mounts/css:/opt/magic_mirror/css
                      restart: unless-stopped
                      command:
                        - npm
                        - run
                        - server
                  and finally, the log after RE-starting the container.
                  > magicmirror@2.22.0 server
                  > node ./serveronly
                  [17.02.2023 13:35.40.960] [LOG]   Starting MagicMirror: v2.22.0
                  [17.02.2023 13:35.40.962] [LOG]   Loading config ...
                  [17.02.2023 13:35.40.964] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read properties of undefined (reading 'module')
                  [17.02.2023 13:35.40.965] [ERROR] Whoops! There was an uncaught exception...
                  [17.02.2023 13:35.40.967] [ERROR] TypeError: Cannot read properties of undefined (reading 'module')
                  [17.02.2023 13:35.40.967] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [17.02.2023 13:35.40.967] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  copy default modules to host ...
                  copy css files to host ...
                  chown modules and config folder ...
                  timezone is Europe/Berlin
                  start magicmirror
                    karsten13 @asdf303
                    @asdf303
                    must be something with the portainer setup.
                    What is strange is the order in the log file, I would expect the last lines beginning with copy default modules to host ... at the top.
                    One thing you can try is to change restart: unless-stopped to restart: never in the docker-compose.yml, may 2 containers are started when portainer stops the one running.
                      asdf303 @karsten13
                      @karsten13 thank you, i will try next time, will take 2…3 days, maybe
                        asdf303 @asdf303
                        update: if the module: ‘MMM-LocalTransport’, module is disabled, it works.
                        Strange thing:
                        • the module works on my raspi electron installation.
                        • it does not in the container.
                          I will keep you updated.
                          karsten13 @asdf303
                          @asdf303
                          this module is not really maintained, it relies on an outdated dependency (request) which was removed from mm core a long time ago.
                          If it runs on your pi the mm installation there is very old or you installed request manually. See this topic for more info.
                            asdf303 @karsten13
                            @karsten13 indeed, the installation has been running for ~5 years now.
                            I know this is none of your business, but do you might have a recommendation for a up-to-date module where i can run the same features? (naming a start and destination bus stop in google maps and getting the next connections displayed?)
                            i scrolled through all of the 3rd party modules and there are many many of them, but none of them seems to be customizable to my home town. I live within VGN area in Germany, but there is no plugin really supporting this and i am definetly lacking the skills to create such a plugin by myself.
                              sdetweil @asdf303
                              @asdf303 just install the missing library
                                karsten13 @sdetweil
                                as sam already said you can fix this, for more info see https://khassel.gitlab.io/magicmirror/faq/#error-cannot-find-module-request
                                  sdetweil @karsten13
                                  @karsten13 and note there are other libs as well
                                    asdf303 @sdetweil
                                    npm install request
                                    did the job for me.
