    MM in Container config lost after Container Stop/Start
    15 Posts 3 Posters 7.3k Views 3 Watching
      sdetweil @asdf303
      @asdf303 maybe @karsten13 will check this topic out
      • karsten13K Offline
        karsten13 @sdetweil
        my project is documented here https://khassel.gitlab.io/magicmirror/
        I don’t know the portainer setup and for further investigation we need to see
        • full log
        • your docker-compose.yml or the docker run ... command
        • full config.js
        Please remove any secrets before publishing here.
          asdf303 @karsten13
          @karsten13 Thank you for asking.
          Please find all my stuff below
          As mentioned above, it loads correctly and runs the configuration correctly on the first start.
          Everything is fine.
          But if the container is started/stopped in Portainer, it seems to not be able to find a correct config.js, as you can see in the log.
          The only way to get it running is, i stop the container, remove the stack in Portainer, then navigate to /data/compose in the host system, manually delete all the data there (i use Winscp). Then i re-install everything (including e.g. the mmm-localtransport addon) acc. to the book, modify the config.js to what you can see below.
          let config = {
          	address: "0.0.0.0", 	// Address to listen on, can be:
          	port: 8080,
          	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
          	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.178.1/24"], 	// Set [] to allow all IP addresses
          	ipWhitelist: [], 	// Set [] to allow all IP addresses
          	language: "de",
          	locale: "en-US",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          					displaySeconds: false,
          					displayType: "digital",
          					clockBold: false,
          			header: "Was passiert heute?",
          				fade: false,
          				timeFormat: 'absolute',
          				dateFormat: '24',
          				getRelative: 24,
          				fetchInterval: 3600000,
          					// der Abfallkalender
                                                        	symbol: "trash",
                                                 		url: "webcal://XXX"
          					//private calendar
          						symbol: "home",
                					 	url: "XXX",
                  					auth: {
          							user: "XXX",
          							pass: "XXX",
          							method: "basic"
          			module: "compliments",
          			position: "lower_third"
          			module: "weather", //aktuelles Wetter
          			//header: "aktuelles Wetter",
          				fade: false,
          				type: "current",
          				locationID: "XXX",  //ID from http://www.openweathermap.org/help/city_list.txt
          				apiKey: "XXX",
          				roundTemp: true,
          				maxNumberOfDays: 2,
          			module: "weather", //Vorhersage
          			header: "Vorhersage",
          				fade: false,
          				type: "forecast",
          				apiKey: "xxx",
          				roundTemp: true,
          				maxNumberOfDays: 4,
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "Tagesschau",
          						url: "https://www.tagesschau.de/xml/rss2"
          				showSourceTitle: false,
          				showPublishDate: false,
          				wrapTitle: false,
          		module: 'MMM-LocalTransport',
          		header: 'Bus nach XXX',
          		position: 'bottom_right',
          			api_key: 'xxxx',
          			origin: 'xxxx',
          			destination: 'xxxx',
          			maximumEntries: 3,
          			displayArrival: false,
          			displayWalkType: 'none',
          			updateInterval: 60,
          			displayStationLength: -1,
          Here is the docker-compose.yml, copied from your project, unchanged:
          version: '3'
          services:
            magicmirror:
              container_name: mm
              image: karsten13/magicmirror:latest
              ports:
                - "8080:8080"
              volumes:
                - ../mounts/config:/opt/magic_mirror/config
                - ../mounts/modules:/opt/magic_mirror/modules
                - ../mounts/css:/opt/magic_mirror/css
              restart: unless-stopped
              command:
                - npm
                - run
                - server
          and finally, the log after RE-starting the container.
          > magicmirror@2.22.0 server
          > node ./serveronly
          [17.02.2023 13:35.40.960] [LOG]   Starting MagicMirror: v2.22.0
          [17.02.2023 13:35.40.962] [LOG]   Loading config ...
          [17.02.2023 13:35.40.964] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read properties of undefined (reading 'module')
          [17.02.2023 13:35.40.965] [ERROR] Whoops! There was an uncaught exception...
          [17.02.2023 13:35.40.967] [ERROR] TypeError: Cannot read properties of undefined (reading 'module')
              at /opt/magic_mirror/js/app.js:220:34
              at loadConfig (/opt/magic_mirror/js/app.js:81:4)
              at App.start (/opt/magic_mirror/js/app.js:212:3)
              at Object.<anonymous> (/opt/magic_mirror/serveronly/index.js:4:5)
              at Module._compile (node:internal/modules/cjs/loader:1226:14)
              at Module._extensions..js (node:internal/modules/cjs/loader:1280:10)
              at Module.load (node:internal/modules/cjs/loader:1089:32)
              at Module._load (node:internal/modules/cjs/loader:930:12)
              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
              at node:internal/main/run_main_module:23:47
          [17.02.2023 13:35.40.967] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [17.02.2023 13:35.40.967] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          copy default modules to host ...
          copy css files to host ...
          chown modules and config folder ...
          timezone is Europe/Berlin
          start magicmirror
            karsten13 @asdf303
            @asdf303
            must be something with the portainer setup.
            What is strange is the order in the log file, I would expect the last lines beginning with copy default modules to host ... at the top.
            One thing you can try is to change restart: unless-stopped to restart: never in the docker-compose.yml, may 2 containers are started when portainer stops the one running.
              asdf303 @karsten13
              @karsten13 thank you, i will try next time, will take 2…3 days, maybe
                asdf303 @asdf303
                update: if the module: ‘MMM-LocalTransport’, module is disabled, it works.
                Strange thing:
                • the module works on my raspi electron installation.
                • it does not in the container.
                  I will keep you updated.
                  karsten13 @asdf303
                  @asdf303
                  this module is not really maintained, it relies on an outdated dependency (request) which was removed from mm core a long time ago.
                  If it runs on your pi the mm installation there is very old or you installed request manually. See this topic for more info.
                    asdf303 @karsten13
                    @karsten13 indeed, the installation has been running for ~5 years now.
                    I know this is none of your business, but do you might have a recommendation for a up-to-date module where i can run the same features? (naming a start and destination bus stop in google maps and getting the next connections displayed?)
                    i scrolled through all of the 3rd party modules and there are many many of them, but none of them seems to be customizable to my home town. I live within VGN area in Germany, but there is no plugin really supporting this and i am definetly lacking the skills to create such a plugin by myself.
                      sdetweil @asdf303
                      @asdf303 just install the missing library
                        karsten13 @sdetweil
                        as sam already said you can fix this, for more info see https://khassel.gitlab.io/magicmirror/faq/#error-cannot-find-module-request
                          sdetweil @karsten13
                          @karsten13 and note there are other libs as well
                            asdf303 @sdetweil
                            @sdetweil @karsten13 thanks a lot for your advice!
                            finally, there was only one package missing
                            npm install request
                            did the job for me.
                            :folded_hands_medium-light_skin_tone:
