    help with OpenWeatherForecast
    12 Posts 2 Posters 4.7k Views 3 Watching
    • G Offline
      gembob @sdetweil
      @sdetweil sorry for the long delay in my reply; I made the change as recommended and I’m still having the same issue, just a constant Loading screen for weather
        sdetweil @gembob
        @gembob i used your config and my api key and it worked ok
        • G Offline
          gembob @sdetweil
          @sdetweil - well that’s frustrating! Would my best bet now be to try a new api key? Any other basic steps I could try that I might have screwed up?
            sdetweil @gembob
            @gembob I don’t know
            I cloned
            did npm install in the module folder
            copied your config to my config.js
            added my apikey
            and ran
            no other changes
            G 2 Replies Last reply Reply Quote 0
            • G Offline
              gembob @sdetweil
              @sdetweil ok, thanks for testing it out for me.
              • G Offline
                gembob @sdetweil
                I wiped and started over, and still having issues getting it to display like you are. I used by api key with the standard weather modules and it appears to work so I think I’m doing something wrong elsewhere. What do you do with the two existing weather modules that are in the config file by default, weather and weather forecast? Do you leave them, delete them?
                  sdetweil @gembob
                  @gembob I can do either… for this test I disabled them
                  • G Offline
                    gembob @sdetweil
                    @sdetweil Ok, thanks again for the assistance
