    MMM-Touch
    36 Posts 7 Posters 27.3k Views 10 Watching
    • MrCoffeeM
      MrCoffee @sdetweil
      @sdetweil Thanks I didn´t know these commands. Unfortunately I use it installed by docker and headlless on a other device.
        sdetweil @MrCoffee
        @MrCoffee yeh, skip docker til you get it working…
        MrCoffeeM 1 Reply Last reply
        • MrCoffeeM
          MrCoffee @sdetweil
          @sdetweil I just tried ctrl-shift-i with a working mirror. On the tab console I could see a css error, but everything works.
          Then i added the onNotification code. Still the same. no mirror starting, and on the console tab there is no error. it ends with “initializing MagicMirror”.
          But nothing happens.
            sdetweil @MrCoffee
            @MrCoffee ok, then it must be back on the terminal window where i started MM
            either there is a module missing
            a syntax error
            or some fatal problem in the front end (mmm-touch.js)
            • MrCoffeeM
              MrCoffee @sdetweil
              @sdetweil Ok. The module MMM-Touch can create a detailed log (says the config). But it is not written where I can find it:-) Is there a common place for it?
                sdetweil @MrCoffee
                @MrCoffee no idea… either in the module folder or MM folder…
                but if there is a fatal error, it probably cant write the logs
                • MrCoffeeM
                  MrCoffee @sdetweil
                  @sdetweil Ok. I see. So I will have to ask gfischershaw.
                  Thx
                    3squaremirror
                    can someone provide me with an example of Executing methods of module?
                    i’d like to create a swipe up and swipe down to hide and unhide a module. thank you.
                    S M 2 Replies Last reply
                      sdetweil @3squaremirror
                      @3squaremirror can u be more specific, execute methods of a module?
                      3 1 Reply Last reply
                        MMRIZE @3squaremirror
                        @3squaremirror
                        I have not tested yet, but you can get a concept. (I’ll assume you are using default configuration and mode)
                          gestureCommands: {
                            "default": {
                              "SWIPE_UP_1" : (commander) => {
                                commander.getModules().forEach((m) => {m.show()})
                              "SWIPE_DOWN_1" : (commander) => {
                                commander.getModules().forEach((m) => {m.hide()})
                        Swiping up with one finger would reveal modules.
                        Swiping down with one finger would hide modules.
                        But in the real world, some modules are protected with lock string from hiding/showing,
                          3squaremirror @MMRIZE
                          @MMRIZE I saw that in the example in the GitHub page. I’m confused on where to specify which module to hide/show. Thanks.
                            3squaremirror @sdetweil
                            @sdetweil to hide and show a specific module.
                              @3squaremirror i understood that part…
                              I think @MMRIZE answered
                                @sdetweil I’m not clear on where to specify the module I want to hide/show. Can you help me understand? Thank you.
                                  @3squaremirror i believe @MMRIZE provided code to hide all, and you could have a list (or only one) module name to match for hiding/showing
                                    @3squaremirror
                                      let clock = commander.getModule('clock')
                                      clock.hide()
                                    https://github.com/gfischershaw/MMM-Touch/wiki/Manual#command
                                      @MMRIZE THANK YOU! much appreciated.
                                        3squaremirror
                                        one other question. I’m trying to make use of the onIdle function to activate a screensaver page in my MMM-pages.
                                        from Pages’s github
                                        SHOW_HIDDEN_PAGE	String	MMM-pages will switch to the provided hidden page name.
                                        from Touch’s github
                                        // will send a TOUCH_IDLE_TRIGGERED notification
                                        onIdle: "TOUCH_IDLE_TRIGGERED",
                                        I’ve successfully got the Touch module to send a notification based on the onIdle timer. I just don’t know how to specify my Page’s screensaver page along with the payload.
                                        "SHOW_HIDDEN_PAGE", 'screenSaver'
                                        my code for each module
                                                module: 'MMM-pages',
                                        	disabled: false,
                                            classes: 'default everyone',
                                                        modules:
                                                            [[ "MMM-DateOnly", "clock2" ],
                                        			[ "MMM-OpenWeatherMapForecast", "clock" ],
                                                    [ "calendar", "clock" ],
                                        			[ "clock", "MMM-Wallpaper" ]
                                                        fixed: [ "weather", "MMM-page-indicator", "MMM-SimpleLogo" ],
                                                        hiddenPages: {
                                                            "screenSaver": [ "MMM-Wallpaper", "MMM-FlipClock" ],
                                                            "admin": [ "MMM-ShowMeSystemStatsModule", "MMM-AnOnScreenMenuModule" ],
                                            module: "MMM-Touch",
                                            position: "top_bar",
                                            disabled: false,
                                            debug: false,
                                            useDisplay: false,
                                        	autoMode: false,
                                            defaultMode: "default",
                                          threshold: {
                                            idle_ms: 3000, // Idle time (in milliseconds) after which the defined "onIdle" notification / callback function should be triggered
                                          onIdle: ("SHOW_HIDDEN_PAGE", 'screenSaver'),
                                                gestureCommands: {
                                                    default: {
                                                        TAP_1: (commander) => {
                                                            commander.sendNotification("USER_PRESENCE", true);
                                                        PRESS_1: (commander) => {
                                                        TAP_2: (commander) => {
                                                            commander.sendNotification("LOAD_NEXT_WALLPAPER", true);
                                                          let clock = commander.getModule('MMM-OpenWeatherMapForecast')
                                                          clock.show()
                                                          clock.hide()
                                                        SWIPE_UP_2: (commander) => {
                                                            commander.sendNotification("SHOW_HIDDEN_PAGE", "screenSaver");
                                                        SWIPE_DOWN_2: (commander) => {
                                                            commander.sendNotification("LEAVE_HIDDEN_PAGE");
                                                        SWIPE_LEFT_1: (commander) => {
                                                            commander.sendNotification("PAGE_INCREMENT", null);
                                                        SWIPE_RIGHT_1: (commander) => {
                                                            commander.sendNotification("PAGE_DECREMENT", null);
                                          @3squaremirror
                                          Currently, MMM-Touch’s onIdle notification or function couldn’t carry the payload value.
                                          One solution would be modifying the source. It is not so difficult. Just a few lines are needed for that. Then make a PR and wait to be accepted by the module owner.
                                          The real issue is… The module owner - @gfischershaw seems not to manage this module any more. As an original developer of this module, I feel some responsibility. Maybe I should get back from this unmaintained situation. (I’m not sure what to do yet.)
                                          Second solution would be the conjunction with MMM-NotificationTrigger module. It could chain/translate one notification to other notifications. So you can relay TOUCH_IDLE_TRIGGERED to {SHOW_HIDDEN_PAGE, 'screenSaver'} . See that. Or I think there would be some equivalent modules somewhere.
                                            @MMRIZE thank you for responding, that works well.
