    MMM-Touch
    36 Posts 7 Posters 26.8k Views 10 Watching
    • MrCoffeeM Offline
      MrCoffee @sdetweil
      @sdetweil I just tried ctrl-shift-i with a working mirror. On the tab console I could see a css error, but everything works.
      Then i added the onNotification code. Still the same. no mirror starting, and on the console tab there is no error. it ends with “initializing MagicMirror”.
      But nothing happens.
        sdetweil @MrCoffee
        @MrCoffee ok, then it must be back on the terminal window where i started MM
        either there is a module missing
        a syntax error
        or some fatal problem in the front end (mmm-touch.js)
        MrCoffeeM 1 Reply Last reply Reply Quote 0
        • MrCoffeeM Offline
          MrCoffee @sdetweil
          @sdetweil Ok. The module MMM-Touch can create a detailed log (says the config). But it is not written where I can find it:-) Is there a common place for it?
            sdetweil @MrCoffee
            @MrCoffee no idea… either in the module folder or MM folder…
            but if there is a fatal error, it probably cant write the logs
            • MrCoffeeM Offline
              MrCoffee @sdetweil
              @sdetweil Ok. I see. So I will have to ask gfischershaw.
              Thx
              • 3 Offline
                3squaremirror
                can someone provide me with an example of Executing methods of module?
                i’d like to create a swipe up and swipe down to hide and unhide a module. thank you.
                  sdetweil @3squaremirror
                  @3squaremirror can u be more specific, execute methods of a module?
                  3 1 Reply Last reply Reply Quote 0
                    MMRIZE @3squaremirror
                    @3squaremirror
                    I have not tested yet, but you can get a concept. (I’ll assume you are using default configuration and mode)
                      gestureCommands: {
                        "default": {
                          "SWIPE_UP_1" : (commander) => {
                            commander.getModules().forEach((m) => {m.show()})
                          "SWIPE_DOWN_1" : (commander) => {
                            commander.getModules().forEach((m) => {m.hide()})
                    Swiping up with one finger would reveal modules.
                    Swiping down with one finger would hide modules.
                    But in the real world, some modules are protected with lock string from hiding/showing,
                    • 3 Offline
                      3squaremirror @MMRIZE
                      @MMRIZE I saw that in the example in the GitHub page. I’m confused on where to specify which module to hide/show. Thanks.
                      • 3 Offline
                        3squaremirror @sdetweil
                        @sdetweil to hide and show a specific module.
                          @3squaremirror i understood that part…
                          I think @MMRIZE answered
                          • 3 Offline
                            @sdetweil I’m not clear on where to specify the module I want to hide/show. Can you help me understand? Thank you.
                              @3squaremirror i believe @MMRIZE provided code to hide all, and you could have a list (or only one) module name to match for hiding/showing
                                @3squaremirror
                                  let clock = commander.getModule('clock')
                                  clock.hide()
                                https://github.com/gfischershaw/MMM-Touch/wiki/Manual#command
                                • 3 Offline
                                  @MMRIZE THANK YOU! much appreciated.
                                  • 3 Offline
                                    3squaremirror
                                    one other question. I’m trying to make use of the onIdle function to activate a screensaver page in my MMM-pages.
                                    from Pages’s github
                                    SHOW_HIDDEN_PAGE	String	MMM-pages will switch to the provided hidden page name.
                                    from Touch’s github
                                    // will send a TOUCH_IDLE_TRIGGERED notification
                                    onIdle: "TOUCH_IDLE_TRIGGERED",
                                    I’ve successfully got the Touch module to send a notification based on the onIdle timer. I just don’t know how to specify my Page’s screensaver page along with the payload.
                                    "SHOW_HIDDEN_PAGE", 'screenSaver'
                                    my code for each module
                                            module: 'MMM-pages',
                                    	disabled: false,
                                        classes: 'default everyone',
                                                    modules:
                                                        [[ "MMM-DateOnly", "clock2" ],
                                    			[ "MMM-OpenWeatherMapForecast", "clock" ],
                                                [ "calendar", "clock" ],
                                    			[ "clock", "MMM-Wallpaper" ]
                                                    fixed: [ "weather", "MMM-page-indicator", "MMM-SimpleLogo" ],
                                                    hiddenPages: {
                                                        "screenSaver": [ "MMM-Wallpaper", "MMM-FlipClock" ],
                                                        "admin": [ "MMM-ShowMeSystemStatsModule", "MMM-AnOnScreenMenuModule" ],
                                        module: "MMM-Touch",
                                        position: "top_bar",
                                        disabled: false,
                                        debug: false,
                                        useDisplay: false,
                                    	autoMode: false,
                                        defaultMode: "default",
                                      threshold: {
                                        idle_ms: 3000, // Idle time (in milliseconds) after which the defined "onIdle" notification / callback function should be triggered
                                      onIdle: ("SHOW_HIDDEN_PAGE", 'screenSaver'),
                                            gestureCommands: {
                                                default: {
                                                    TAP_1: (commander) => {
                                                        commander.sendNotification("USER_PRESENCE", true);
                                                    PRESS_1: (commander) => {
                                                    TAP_2: (commander) => {
                                                        commander.sendNotification("LOAD_NEXT_WALLPAPER", true);
                                                      let clock = commander.getModule('MMM-OpenWeatherMapForecast')
                                                      clock.show()
                                                      clock.hide()
                                                    SWIPE_UP_2: (commander) => {
                                                        commander.sendNotification("SHOW_HIDDEN_PAGE", "screenSaver");
                                                    SWIPE_DOWN_2: (commander) => {
                                                        commander.sendNotification("LEAVE_HIDDEN_PAGE");
                                                    SWIPE_LEFT_1: (commander) => {
                                                        commander.sendNotification("PAGE_INCREMENT", null);
                                                    SWIPE_RIGHT_1: (commander) => {
                                                        commander.sendNotification("PAGE_DECREMENT", null);
                                      @3squaremirror
                                      Currently, MMM-Touch’s onIdle notification or function couldn’t carry the payload value.
                                      One solution would be modifying the source. It is not so difficult. Just a few lines are needed for that. Then make a PR and wait to be accepted by the module owner.
                                      The real issue is… The module owner - @gfischershaw seems not to manage this module any more. As an original developer of this module, I feel some responsibility. Maybe I should get back from this unmaintained situation. (I’m not sure what to do yet.)
                                      Second solution would be the conjunction with MMM-NotificationTrigger module. It could chain/translate one notification to other notifications. So you can relay TOUCH_IDLE_TRIGGERED to {SHOW_HIDDEN_PAGE, 'screenSaver'} . See that. Or I think there would be some equivalent modules somewhere.
                                      • 3 Offline
                                        @MMRIZE thank you for responding, that works well.
