    EADDRINUSE: address already in use 127.0.0.1:8090
    9 Posts 2 Posters 3.0k Views 2 Watching
    • T Offline
      theaddies
      When I boot up the MagicMirror I will get a blank screen with a cursor. The message in the log is the following. If I simply change the port to anything else, 8080 then the mirror boots up fine. If I get the error I switch it back to 8090 and it goes away again. I have nothing running on the machine. It is a raspberry pi II with only MagicMirror. TIA
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      0|MagicMir | [19.02.2023 07:55.11.006] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8090
      0|MagicMir |     at Server.setupListenHandle [as _listen2] (node:net:1432:16)
      0|MagicMir |     at listenInCluster (node:net:1480:12)
      0|MagicMir |     at GetAddrInfoReqWrap.doListen [as callback] (node:net:1629:7)
      0|MagicMir |     at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:111:8) {
      0|MagicMir |   code: 'EADDRINUSE',
      0|MagicMir |   errno: -98,
      0|MagicMir |   syscall: 'listen',
      0|MagicMir |   address: '127.0.0.1',
      0|MagicMir |   port: 8090
      0|MagicMir | }
      0|MagicMir | [19.02.2023 07:55.11.008] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [19.02.2023 07:55.11.010] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|MagicMir | [2472:0219/075514.107308:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [2505:0219/075514.639247:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
        sdetweil @theaddies
        @theaddies that means something is using the port , maybe you have two instances of mm trying to run
        do
        pm2 status
        are there 2 apps defined?
        • T Offline
          theaddies @sdetweil
          @sdetweil Thanks for the reply. I think I did have 2 instances at one time, but I deleted the other one. It does not show up on pm2 status. Is there anything else to remove? Thansk.
            @theaddies look for running processes
            pm2 stop all
            ps -ef | grep node
            or
            ps -ef | grep npm
            T 2 Replies Last reply Reply Quote 0
            • T Offline
              theaddies @sdetweil
              @sdetweil I found /usr/bin node serveronly.
              is that the culpirit?
              • T Offline
                theaddies @sdetweil
                @sdetweil I suppose this makes sense but I killed it and it immediately restarted. I don’t know how to remove it.
                  sdetweil @theaddies
                  @theaddies you must have added it as part of the manual install instructions
                  do the reverse to take it out…
                  • T Offline
                    theaddies @sdetweil
                    @sdetweil thanks for the reply but I have no idea what I see did
                      sdetweil @theaddies
                      @theaddies sorry. no idea myself.
                      I gave up long ago trying to remember the 900 different ways to auto start things on the myriad different platforms.
