MMM-OpenAI
24 Posts 4 Posters 9.1k Views 4 Watching
    MMRIZE
    MMM-OpenAI
    MagicMirror module for requesting OpenAI’s API
    DISCLAIMERS :
    1. This is not a ChatGPT module; (OpenAI has not released ChatGPT API yet.). This module uses OpenAI’s API for text completion and image generation.
    2. I will not implement any voice-related features into this module directly, but if you want, you can relay those kinds of modules for your own purpose. (This module has much preparation to cooperate with other modules.)
    Screenshot
    Text Completion
    Image generation
    Features
    • Request text completions or image generation from OpenAI with detailed options
    • Activation through TelegramBot (default behaviour)
    • Activation with notification (customizable - For developing a new module or For using the current module without modification, either possible.)
    • Customizable post-process (You might not need to build an external module to handle the response for your own purpose)
    For more details
    https://github.com/MMRIZE/MMM-OpenAI
      MMRIZE
      1.1.0 (2023-03-02)
      Added : Chat API
      Chat
        Rags
        Great. Installed it and it is up and running with absolutely no effort. Thanks for this module. However, i am facing an issue of an error message “Something is wrong see the log”. So this error pops up randomly when i initiate a /chatai or a /txtai or /imgai, and i am unsure why. Is the heavy traffic of ChatGPT the reason. Also where do i check the logs.?
        M 2 Replies Last reply Mar 5, 2023, 9:42 PM Reply Quote 0
        • S sdetweil referenced this topic on Mar 5, 2023, 8:45 PM
          MMRIZE @Rags
          @Rags
          I’ll update the modules with more kind error messages in 1-2days. Plz wait a little
            MMRIZE
            1.2.0 (2022-03-06)
            • ADDED : More kind error message (in the terminal console, the display, telegram, and the dev-console)
            • ADDED : Token usage on success in TEXT and CHAT.
            • FIXED : Reducing default max_token for chat. (Too many token limit may cause the error unexpected)
            120_1
            120_2
              MMRIZE @Rags
              @Rags
              I found it was token usage issue. I think I fixed it with the new update.
              R 1 Reply Last reply Mar 7, 2023, 6:57 AM Reply Quote 0
                Rags @MMRIZE
                @MMRIZE @MMRIZE
                Thanks for the update. Yes now it works fine. I am not getting "something is wrong’ messages, but prompts about the token lengths whenever they exceed.
                Thanks. I hope there will be voice integration soon.
                M R 2 Replies Last reply Mar 7, 2023, 8:35 AM Reply Quote 0
                  MMRIZE @Rags
                  @Rags
                  I will not implement Voice-feature into this module directly by myself.
                  But I believe other existing voice-related modules could be used together already.
                    MMRIZE
                    @Rags
                    Speech example: Conjunction with MMM-GoogleTTS, now it can speak.
                    https://youtu.be/daWuSfQc5Ns
                    postProcessing: (helper, resp) => {
                      let choice = resp.response?.choices[0]
                      if (choice) helper.sendNotification('TTS_SAY', choice?.message?.content ?? choice?.text)
                    S R 2 Replies Last reply Mar 7, 2023, 7:00 PM Reply Quote 0
                      sdmydbr9 @MMRIZE
                      @MMRIZE a similar idea has crossed my mind. Using a Hotword detector like the one used in google assignment module to activate a listener for voice and ask for voice input and then using the input provided, get the transcript of the audio using the whisper api or something similar to get the transcript… pass on the transcript as a content in the OPENAI_REQUEST notification and then SHOW_ALERT or just read it out loud using the MMM-GoogleTTS. Just a rough sketch. I’m sure someone out here will come up with more convincing and better ideas.
                      S M 2 Replies Last reply Mar 7, 2023, 8:51 PM Reply Quote -1
                      1 / 3
