    MMM-OpenAI
    24 Posts 4 Posters 15.0k Views 4 Watching
      MMRIZE @Rags
      @Rags
      I’ll update the modules with more kind error messages in 1-2days. Plz wait a little
        MMRIZE
        1.2.0 (2022-03-06)
        • ADDED : More kind error message (in the terminal console, the display, telegram, and the dev-console)
        • ADDED : Token usage on success in TEXT and CHAT.
        • FIXED : Reducing default max_token for chat. (Too many token limit may cause the error unexpected)
        120_1
        120_2
          MMRIZE @Rags
          @Rags
          I found it was token usage issue. I think I fixed it with the new update.
            Rags @MMRIZE
            @MMRIZE @MMRIZE
            Thanks for the update. Yes now it works fine. I am not getting "something is wrong’ messages, but prompts about the token lengths whenever they exceed.
            Thanks. I hope there will be voice integration soon.
            M R 2 Replies Last reply Reply Quote 0
              MMRIZE @Rags
              @Rags
              I will not implement Voice-feature into this module directly by myself.
              But I believe other existing voice-related modules could be used together already.
                MMRIZE
                @Rags
                Speech example: Conjunction with MMM-GoogleTTS, now it can speak.
                https://youtu.be/daWuSfQc5Ns
                postProcessing: (helper, resp) => {
                  let choice = resp.response?.choices[0]
                  if (choice) helper.sendNotification('TTS_SAY', choice?.message?.content ?? choice?.text)
                S R 2 Replies Last reply Reply Quote 0
                  sdmydbr9 @MMRIZE
                  @MMRIZE a similar idea has crossed my mind. Using a Hotword detector like the one used in google assignment module to activate a listener for voice and ask for voice input and then using the input provided, get the transcript of the audio using the whisper api or something similar to get the transcript… pass on the transcript as a content in the OPENAI_REQUEST notification and then SHOW_ALERT or just read it out loud using the MMM-GoogleTTS. Just a rough sketch. I’m sure someone out here will come up with more convincing and better ideas.
                  S M 2 Replies Last reply Reply Quote -1
                    sdetweil @sdmydbr9
                    @sdmydbr9 use a GoogleAssistant recipe
                    see it’s recipies folder
                      MMRIZE @sdmydbr9
                      @sdmydbr9
                      I have a few already, like MMM-Hotword or MMM-Clap, and some…
                      Anyway new OpenAI’s Whisper looks so interesting, So I’ll make it as a STT module in a few days, hope so.
                        sdmydbr9 @sdetweil
                        @sdetweil I just meant it as a similar approach, I don’t actually want to implement the whole assistant module.
