    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 721.4k Views 57 Watching
      chris1971
      Thanks for the Info. Hope that the switch to Open Weather will be smooth. Long time ago that I have modified something on the mirror…
        sdetweil @chris1971
        @chris1971 @BKeyport
        there is a replacement API. same parns
        just different url
        was posted here in the last few months.
        no time to search right now
        karsten13K 1 Reply Last reply
        • karsten13K
          karsten13 @sdetweil
          http://pirateweather.net
          C 1 Reply Last reply
            chris1971 @karsten13
            @karsten13
            I tried a new API Token from pirateweather for OpenWeather - but the module is not loading. Do I have to do some other changes next to the API?
            The token is valid until April 22nd. Do I have to renew the token every month?
              sdetweil @chris1971
              @chris1971 pirate weather is the dark sky replacement.
              openweather has a different API token
                chris1971 @sdetweil
                pirateweather is another module next to openweather? Sorry for the dumb question…
                Then I will try to go with Openweather acc. the description…
                  sdetweil @chris1971
                  @chris1971 no. pirateweather.net provides an API that looks like the dark sky API.
                  so the dark sky module could be made to work again
                    chris1971 @sdetweil
                    @sdetweil this would be cool. Will try and give a feedback soon.
                      chris1971
                      I tried several API tokens from Pirateweather without success… But the old DarkSky APi is working again - I assume it will work only until March31st… :disappointed_face:
                        sdetweil @chris1971
                        @chris1971 you would have to change the dark sky module to use the pirate weather url too
                          chris1971
                          Do you have additional information what to change?
                          Thx
                            sdetweil @chris1971
                            @chris1971 no, but the pirateweather.net site would probably tell you
                              chris1971
                              Tried to install MMM-OpenWeatherForecast acc. the description and got a lot of errors during installation:
                              npm ERR! Linux 4.9.41-v7+
                              npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “install”
                              npm ERR! node v6.12.0
                              npm ERR! npm v3.10.10
                              npm ERR! path /home/pi/MagicMirror/modules/MMM-OpenWeatherForecast/node_modules/.staging/@iarna/cli-64fafd25
                              npm ERR! code ENOENT
                              npm ERR! errno -2
                              npm ERR! syscall rename
                              npm ERR! enoent ENOENT: no such file or directory, rename ‘/home/pi/MagicMirror/modules/MMM-OpenWeatherForecast/node_modules/.staging/@iarna/cli-64fafd25’ -> ‘/home/pi/MagicMirror/modules/MMM-OpenWeatherForecast/node_modules/npm/node_modules/@iarna/cli’
                              npm ERR! enoent This is most likely not a problem with npm itself
                              npm ERR! enoent and is related to npm not being able to find a file.
                              npm ERR! enoent
                              npm ERR! /home/pi/MagicMirror/modules/MMM-OpenWeatherForecast/npm-debug.log<
                              After modification of the config and npm start I got a black screen and had to reset the system by disconnection from power supply. Any recommendations?
                                sdetweil @chris1971
                                @chris1971 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                WAY downlevel…
                                should be node 16 and npm 8
                                use my install script, it sets up everything…
                                see https://github.com/sdetweil/MagicMirror_scripts
                                  chris1971
                                  I only have to type <“$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”> in the command line and the Update will be done automatically? No changes to the existing System?
                                    sdetweil @chris1971
                                    @chris1971 no type, just copy paste ( use ssh VM from desktop/laptop)
                                    but still it’s a two part process, check by default, advise, make no changes
                                    then rerun with Parm at the end to DO the upgrade
                                    if you are ALREADY at the latest release, it will abort, unless that Parm is force
                                    • BerkSmash1984B
                                      BerkSmash1984
                                      Awesome module! Question for you: I am using MMM-Wallpaper and some of the text can be hard to read during certain wallpapers. I looked in the MMM-OpenWeatherForecast.css file but did not see an obvious place to change the color for the text highlighted in the red boxes below. I would like to set them to white (#FFFFFF). Can you tell me where in that css to set that? Thanks for your help!
                                        sdetweil @BerkSmash1984
                                        @BerkSmash1984 I do not know … but you can find out thru using the developers console
                                        see
                                        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1679584458559
                                        BerkSmash1984B 1 Reply Last reply
                                        • BerkSmash1984B
                                          BerkSmash1984 @sdetweil
                                          Thank you! I will dig into it via the dev console
                                          BKeyportB 1 Reply Last reply
                                          • BKeyportB
                                            BKeyport Module Developer @BerkSmash1984
                                            @BerkSmash1984
                                            It uses the defaults from MagicMirror for grey text. I use:
                                            root {
                                            	--color-text: #DDD;
                                            	--color-text-dimmed: #666;
                                            	--color-text-bright: #fff;
                                                  --color-background: #000;
                                            /* Originals:
                                              --color-text: #999;
                                            BKeyportB BerkSmash1984B 3 Replies Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
