    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 721.5k Views 57 Watching
      sdetweil @chris1971
      @chris1971 no… do exacty what I said… and try again …
      look in the logs, open the developers window (crtrl-shift-i on the mm screen keyboard), select the console tab and look for red error messages…
        chris1971
        o.k. deleted the package-lock.json and node_modules folder. No change…
        In which logs do I have to look?
          sdetweil @chris1971
          @chris1971 logs, where u start MM and in the developers window as described in last post
            chris1971
            After some hours of installation I thought I was fine - all modules worked (but only once). komplett.JPG
            When I restarted the mirror the weather module was not loading anymore…
            I got following script after npm start:
            magicmirror@2.22.0 start
            [31.03.2023 14:13.30.165] [LOG] Starting MagicMirror: v2.22.0
            [31.03.2023 14:13.30.177] [LOG] Loading config …
            [31.03.2023 14:13.30.193] [LOG] Loading module helpers …
            [31.03.2023 14:13.30.197] [LOG] No helper found for module: alert.
            [31.03.2023 14:13.30.247] [LOG] Initializing new module helper …
            [31.03.2023 14:13.30.249] [LOG] Module helper loaded: updatenotification
            [31.03.2023 14:13.30.251] [LOG] No helper found for module: clock.
            [31.03.2023 14:13.30.480] [LOG] Initializing new module helper …
            [31.03.2023 14:13.30.481] [LOG] Module helper loaded: MMM-OpenWeatherForecast
            [31.03.2023 14:13.31.255] [LOG] Initializing new module helper …
            [31.03.2023 14:13.31.258] [LOG] Module helper loaded: calendar
            [31.03.2023 14:13.31.261] [LOG] No helper found for module: MMM-TextClock.
            [31.03.2023 14:13.31.344] [LOG] Initializing new module helper …
            [31.03.2023 14:13.31.346] [LOG] Module helper loaded: newsfeed
            [31.03.2023 14:13.31.348] [LOG] No helper found for module: MMM-RAIN-MAP.
            [31.03.2023 14:13.31.358] [LOG] Initializing new module helper …
            [31.03.2023 14:13.31.359] [LOG] Module helper loaded: MMM-GoogleMapsTraffic
            [31.03.2023 14:13.31.361] [LOG] All module helpers loaded.
            [31.03.2023 14:13.31.869] [LOG] Starting server on port 8080 …
            [31.03.2023 14:13.31.892] [WARN] You’re using a full whitelist configuration to allow for all IPs
            [31.03.2023 14:13.31.940] [ERROR] Whoops! There was an uncaught exception…
            [31.03.2023 14:13.31.961] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
            at Server.setupListenHandle [as _listen2] (node:net:1432:16)
            at listenInCluster (node:net:1480:12)
            at doListen (node:net:1629:7)
            at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
            code: ‘EADDRINUSE’,
            errno: -98,
            syscall: ‘listen’,
            address: ‘0.0.0.0’,
            port: 8080
            [31.03.2023 14:13.31.962] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [31.03.2023 14:13.31.963] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [31.03.2023 14:13.33.284] [LOG] Launching application.
            MESA-LOADER: failed to retrieve device information
            …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[1907:0331/141336.327833:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
            …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[1907:0331/141337.916643:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
            …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[1907:0331/141339.068693:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
            [31.03.2023 14:13.55.813] [LOG] Shutting down server…
            [31.03.2023 14:13.55.823] [LOG] Stopping module helper: updatenotification
            [31.03.2023 14:13.55.825] [LOG] Stopping module helper: MMM-OpenWeatherForecast
            [31.03.2023 14:13.55.836] [LOG] Stopping module helper: calendar
            [31.03.2023 14:13.55.838] [LOG] Stopping module helper: newsfeed
            [31.03.2023 14:13.55.839] [LOG] Stopping module helper: MMM-GoogleMapsTraffic
            Any advice? Thanks again…
              sdetweil @chris1971
              @chris1971 that means u have another instance of MagicMirror running already
              C 1 Reply Last reply
                chris1971 @sdetweil
                @sdetweil what does that mean? How can I fix it?
                  sdetweil @chris1971
                  @chris1971 that means something started MM, and you are trying to start it again…
                  you cannot have two copies running at the same time on the same port
                  do this
                  pm2 status
                  on one of my machines it looks like this
                   │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                   │ 0  │ MagicMirror        │ fork     │ 20   │ online    │ 0%       │ 2.4mb    │
                  is there only 1 app defined for pm2 to manage?
                    chris1971 @sdetweil
                    pi@raspberrypi:~/MagicMirror $ pm2 status
                    │ 0 │ MagicMirror │ fork │ 0 │ online │ 0% │ 2.4mb │
                    looks like this…
                    I installed your scrips and agreed both times (y/n) when I was asked to remove screensaver and start pm.
                      sdetweil @chris1971
                      @chris1971 ok, so when u need to change something you do
                      pm2 stop 0 (or pm2 stop MagicMirror), (or pm2 stop all)
                      make your change and then
                      pm2 start 0, or MagicMirror, or all
                        chris1971 @sdetweil
                        @sdetweil said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                        pm2 stop all
                        have stopped with pm2 stop all
                        pi@raspberrypi:~/MagicMirror $ pm2 stop all
                        [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                        [PM2] MagicMirror ✓
                        │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                        │ 0 │ MagicMirror │ default │ 2.22.0 │ fork │ 0 │ 0 │ 0 │ stopped │ 0% │ 0b │ pi │ disabled │
                        the started with pm2 start all
                        pi@raspberrypi:~/MagicMirror $ pm2 start all
                        [PM2] Applying action restartProcessId on app [all](ids: [ 0 ])
                        [PM2] MagicMirror ✓
                        [PM2] Process successfully started
                        │ 0 │ MagicMirror │ default │ 2.22.0 │ fork │ 2414 │ 0s │ 0 │ online │ 0% │ 2.5mb │ pi │ disabled │
                        But no changes…
                        checked the status and see only on 8080
                        pi@raspberrypi:~ $ sudo netstat -lnptu
                        Active Internet connections (only servers)
                        Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
                        tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 565/sshd: /usr/sbin
                        tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 519/cupsd
                        tcp 0 0 0.0.0.0:8080 0.0.0.0: LISTEN 1206/electron.js*
                        tcp6 0 0 ::1:3350 :::* LISTEN 539/xrdp-sesman
                        tcp6 0 0 :::22 :::* LISTEN 565/sshd: /usr/sbin
                        tcp6 0 0 ::1:631 :::* LISTEN 519/cupsd
                        tcp6 0 0 :::3389 :::* LISTEN 585/xrdp
                        udp 0 0 0.0.0.0:68 0.0.0.0:* 526/dhcpcd
                        udp 0 0 0.0.0.0:631 0.0.0.0:* 612/cups-browsed
                        udp 0 0 0.0.0.0:5353 0.0.0.0:* 376/avahi-daemon: r
                        udp 0 0 0.0.0.0:58721 0.0.0.0:* 376/avahi-daemon: r
                        udp6 0 0 :::546 :::* 526/dhcpcd
                        udp6 0 0 :::41014 :::* 376/avahi-daemon: r
                        udp6 0 0 :::5353 :::* 376/avahi-daemon: r
                          sdetweil @chris1971
                          @chris1971 correct, and it should be running correctly now
                          i never use pm2 when I am changing config
                          pm2 stop all
                          npm start
                          (ctrl-m if on same screen, to minimize)
                          look at messages
                          ctrl-c to stop
                          make changes, rinse and repeat til happy
                          then pm2 start all
                            chris1971 @sdetweil
                            @sdetweil Does that mean I have to stopp pm before I make changes in the config?
                            Module is still not loading…
                            When I remove the script for google maps from the config.js the weather module is working. When I place the script in the config.js again, the weather module is not loading.
                              sdetweil @chris1971
                              @chris1971 yes, when u make any change, you should stop MM and then then restart it…
                              as I said before, some modules impact others…
                              I fixed a similar problem in OpenWeatherMapForecast as the author was not updating it anymore
                              this is my fork with the fix https://github.com/sdetweil/MMM-OpenWeatherMapForecast
                              I would look at the messages
                              pm2 stop all
                              pm2 flush
                              pm2 start all
                              wait
                              pm2 logs --lines=100
                              or, not use pm2
                              pm2 stop all
                              npm start >somefile.txt 2>&1
                              wait
                              ctrl-c to stop MM (in the window where you did npm start )
                              then examine the contents of somefile.txt to see if there was any error that might causing the problem
                              you can also look in the MagicMirror developers window to see if there is a problem there
                              ctrl-shift-i on the running MM screen
                              and put weath in the filter field
                              this will reduce the output to modules with weath in their name
                              looking for any content in red
                                chris1971 @sdetweil
                                @sdetweil lot of stuff…
                                pi@raspberrypi:~ $ pm2 logs --lines=100
                                PM2 | 2023-03-31T16:08:12: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                PM2 | 2023-03-31T16:08:12: PM2 log: App [MagicMirror:0] online
                                /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                                0|MagicMir | [31.03.2023 16:08.20.333] [WARN] You’re using a full whitelist configuration to allow for all IPs
                                0|MagicMir | MESA-LOADER: failed to retrieve device information
                                0|MagicMir | …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2472:0331/160823.980369:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=134
                                0|MagicMir | …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2472:0331/160825.475337:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=134
                                0|MagicMir | …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2472:0331/160827.345249:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=134
                                0|MagicMir | [2512:0331/160829.375127:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                                /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                                0|MagicMir |
                                0|MagicMir | > magicmirror@2.22.0 start
                                0|MagicMir | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                                0|MagicMir |
                                0|MagicMir | [31.03.2023 16:08.18.855] [LOG] Starting MagicMirror: v2.22.0
                                0|MagicMir | [31.03.2023 16:08.18.868] [LOG] Loading config …
                                I read something about the GPU process in the forum - could this infuence the system?
                                  sdetweil @chris1971
                                  @chris1971 possibly
                                  for pm2 add the
                                  export ELECTRON_DISABLE_GPU=1
                                  to the ~/MagicMirror/installers/mm.sh
                                  before the line
                                  DISPLAY=:0 npm start
                                  for using npm start
                                  just do it once in the terminal window
                                    chris1971 @sdetweil
                                    @sdetweil still not loading…
                                    [31.03.2023 16:29.04.053] [LOG] Starting MagicMirror: v2.22.0
                                    [31.03.2023 16:29.04.077] [LOG] Loading config …
                                    [31.03.2023 16:29.04.113] [LOG] Loading module helpers …
                                    [31.03.2023 16:29.04.120] [LOG] No helper found for module: alert.
                                    [31.03.2023 16:29.04.191] [LOG] Initializing new module helper …
                                    [31.03.2023 16:29.04.194] [LOG] Module helper loaded: updatenotification
                                    [31.03.2023 16:29.04.196] [LOG] No helper found for module: clock.
                                    [31.03.2023 16:29.04.591] [LOG] Initializing new module helper …
                                    [31.03.2023 16:29.04.592] [LOG] Module helper loaded: MMM-OpenWeatherForecast
                                    [31.03.2023 16:29.05.736] [LOG] Initializing new module helper …
                                    [31.03.2023 16:29.05.740] [LOG] Module helper loaded: calendar
                                    [31.03.2023 16:29.05.754] [LOG] No helper found for module: MMM-TextClock.
                                    [31.03.2023 16:29.06.143] [LOG] Initializing new module helper …
                                    [31.03.2023 16:29.06.150] [LOG] Module helper loaded: newsfeed
                                    [31.03.2023 16:29.06.155] [LOG] No helper found for module: MMM-RAIN-MAP.
                                    [31.03.2023 16:29.06.170] [LOG] Initializing new module helper …
                                    [31.03.2023 16:29.06.172] [LOG] Module helper loaded: MMM-GoogleMapsTraffic
                                    [31.03.2023 16:29.06.173] [LOG] All module helpers loaded.
                                    [31.03.2023 16:29.06.803] [LOG] Starting server on port 8080 …
                                    [31.03.2023 16:29.06.828] [WARN] You’re using a full whitelist configuration to allow for all IPs
                                    [31.03.2023 16:29.06.884] [ERROR] Whoops! There was an uncaught exception…
                                    [31.03.2023 16:29.06.900] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                    code: ‘EADDRINUSE’,
                                    errno: -98,
                                    syscall: ‘listen’,
                                    address: ‘0.0.0.0’,
                                    port: 8080
                                    [31.03.2023 16:29.06.901] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [31.03.2023 16:29.06.902] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    [31.03.2023 16:29.08.680] [LOG] Launching application.
                                    …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2071:0331/162912.978009:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                                    …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2071:0331/162914.498526:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                                    …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2071:0331/162915.779583:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                                    [31.03.2023 16:29.37.588] [LOG] Shutting down server…
                                    [31.03.2023 16:29.37.595] [LOG] Stopping module helper: updatenotification
                                    [31.03.2023 16:29.37.596] [LOG] Stopping module helper: MMM-OpenWeatherForecast
                                    [31.03.2023 16:29.37.596] [LOG] Stopping module helper: calendar
                                    [31.03.2023 16:29.37.597] [LOG] Stopping module helper: newsfeed
                                    [31.03.2023 16:29.37.597] [LOG] Stopping module helper: MMM-GoogleMapsTraffic
                                      sdetweil @chris1971
                                      @chris1971 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                      did u do the pm2 stop all?
                                      did you use any install instructions before my script? the manual install describes how to create a service to auto start MM
                                        chris1971 @sdetweil
                                        yes - ich changed the mm.sh after stop all
                                        my method for installation:
                                        • format SD card
                                        • install Bullseye
                                        • install sudo apt-get install xrdp (to get a remote connection via remote desktop)
                                        • install your scripts including screensaver/ pm2
                                        • install the modules
                                          it worked once … I do not understand what changed after a restart…
                                          sdetweil @chris1971
                                          @chris1971 and u checked the pm2 status
                                          before doing npm start ?
                                          you don’t reboot after pm2 stop all, as t will restart MM on boot (its job)
                                            chris1971 @sdetweil
                                            @sdetweil this is the pm2 status
                                            │ 0 │ MagicMirror │ fork │ 0 │ online │ 0% │ 2.3mb │
                                            with npm start I only have a black screen in the terminal - I can see the conten in the browser with http://192.168.178.35:8080/
                                            S 3 Replies Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 10 / 13
