    MMM-Face-Reco-DNN
    26 Posts 4 Posters 18.3k Views 5 Watching
      sdetweil @Parvez
      @Parvez
      you will find a script called encode.py in folder tools of the module
      so,
      cd tools
      • ParvezP
        Parvez
        Parvez Ahmed
          sdetweil @Parvez
          @Parvez looks like it is trying to detect text in the images… don’t know why
          https://raspberrypi.stackexchange.com/questions/89231/tesseract-ocr-4-x-beta-for-raspberry-pi
            sdetweil @Parvez
            @Parvez dist-packages/cv2 seems pretty old… cv3 is current, cv4 is also out…
            ParvezP 1 Reply Last reply Reply Quote 0
            • ParvezP
              Parvez @sdetweil
              @sdetweil ok i will download open cv3
              Parvez Ahmed
              • ParvezP
                Parvez
                i can’t solve it
                Parvez Ahmed
                  sdetweil @Parvez
                  @Parvez sorry, no idea…
                  • ParvezP
                    Parvez
                    @sdetweil Thank you for your help…
                    Parvez Ahmed
                      jimbydude @Parvez
                      @Parvez hi,
                      I took a fork of SMAI that uses recoDNN an doesn’t require any external python running (recoDNN does that), i also detail training.
                      https://github.com/jimbydude/MMM-AI-Face-Login
                      Cheers
                        Seregeth @jimbydude
                        i have done all to import my fotos. i worked all along without any error.
                        is it possible to test the importet Foto set?
                        As i set up the Module, i will not recognice me. Is it possible to test anyway?
                          sdetweil @Seregeth
                          @Seregeth I do not know. this would have to be provided by the OCV (Open computer vision)
                          code, not ours
                            Seregeth @sdetweil
                            Thank you very much for the feedback.
                            I almost thought so. But maybe someone knows, so I can narrow down where my mistake is.
                            If it’s because the person isn’t recognised, it’s different than if I’ve set a parameter incorrectly.
                              sdetweil @Seregeth
                              @Seregeth the module hasn’t been supported for a number of years, and I don’t remember any debugging assistance provided
                                Seregeth @sdetweil
                                  sdetweil @Seregeth
                                  @Seregeth I think you posted this to the wrong topic
                                  has nothing to do with face reco
                                    Seregeth @sdetweil
                                    I have now managed to get the module to recognise me. Following this nice success, I now wanted to add other people to it.
                                    But that is no longer possible, the process always stops:
                                    I start:
                                    python3 encode.py -i …/dataset/ -e encodings.pickle -d hog
                                    then comes:
                                    [INFO] quantifyng faces…
                                    [INFO] processing image 1/17 - …/dataset/Pauline/img01.jpg
                                    Killed
                                    I then tried deleting the first image (img01.jpg) once and trying again. It worked better then, but it still broke. This time, image img01.jpg came first, then image img04.jpg, then Killed.
                                    What could be the reason that the process is no longer executed?
                                      sdetweil @Seregeth
                                      @Seregeth the images are not the right quality or size?
                                        Seregeth @sdetweil
                                        Maybe, but i took the images the same way like the first ones.
                                        I will try to edit the fotos an will run again
                                          Seregeth @sdetweil
                                          you have been right, it seems, taht the pictures were too big. i shrink them and it worked
