    MMM-Face-Reco-DNN
    26 Posts 4 Posters 17.9k Views 5 Watching
      sdetweil @Parvez
      @Parvez what happens when u run the script?
      Facial Recognition Embeddings
      After you set up your dataset, we need to go to the embeddings for the recognitions. I prepared a script for that. It took a while to run on my Macbook and will take much longer on a Raspberry Pi, so if possible, use it on a computer with more power and then transfer the resulting file.
      You will find a script called encode.py in folder tools of the module. The following arguments are default:
      python3 encode.py -i ../dataset/ -e encodings.pickle -d hog
      linux us case sensitive… so Parvez is not the same as parvez
      • ParvezP Offline
        Parvez
        if any one make a vedio for me is very helpful . i will submit this project my university
        Parvez Ahmed
        • ParvezP Offline
          Parvez
          @sdetweil said in MMM-Face-Reco-DNN:
          python3 encode.py -i …/dataset/ -e encodings.pickle -d hog
          how to run this script
          Parvez Ahmed
            sdetweil @Parvez
            @Parvez
            you will find a script called encode.py in folder tools of the module
            so,
            cd tools
            • ParvezP Offline
              Parvez
              Parvez Ahmed
                sdetweil @Parvez
                @Parvez looks like it is trying to detect text in the images… don’t know why
                https://raspberrypi.stackexchange.com/questions/89231/tesseract-ocr-4-x-beta-for-raspberry-pi
                  sdetweil @Parvez
                  @Parvez dist-packages/cv2 seems pretty old… cv3 is current, cv4 is also out…
                  ParvezP 1 Reply Last reply Reply Quote 0
                  • ParvezP Offline
                    Parvez @sdetweil
                    @sdetweil ok i will download open cv3
                    Parvez Ahmed
                    • ParvezP Offline
                      Parvez
                      i can’t solve it
                      Parvez Ahmed
                        sdetweil @Parvez
                        @Parvez sorry, no idea…
                        • ParvezP Offline
                          Parvez
                          @sdetweil Thank you for your help…
                          Parvez Ahmed
                            jimbydude @Parvez
                            @Parvez hi,
                            I took a fork of SMAI that uses recoDNN an doesn’t require any external python running (recoDNN does that), i also detail training.
                            https://github.com/jimbydude/MMM-AI-Face-Login
                            Cheers
                              Seregeth @jimbydude
                              i have done all to import my fotos. i worked all along without any error.
                              is it possible to test the importet Foto set?
                              As i set up the Module, i will not recognice me. Is it possible to test anyway?
                                sdetweil @Seregeth
                                @Seregeth I do not know. this would have to be provided by the OCV (Open computer vision)
                                code, not ours
                                  Seregeth @sdetweil
                                  Thank you very much for the feedback.
                                  I almost thought so. But maybe someone knows, so I can narrow down where my mistake is.
                                  If it’s because the person isn’t recognised, it’s different than if I’ve set a parameter incorrectly.
                                    sdetweil @Seregeth
                                    @Seregeth the module hasn’t been supported for a number of years, and I don’t remember any debugging assistance provided
                                      Seregeth @sdetweil
                                        sdetweil @Seregeth
                                        @Seregeth I think you posted this to the wrong topic
                                        has nothing to do with face reco
                                          Seregeth @sdetweil
                                          I have now managed to get the module to recognise me. Following this nice success, I now wanted to add other people to it.
                                          But that is no longer possible, the process always stops:
                                          I start:
                                          then comes:
                                          [INFO] quantifyng faces…
                                          [INFO] processing image 1/17 - …/dataset/Pauline/img01.jpg
                                          Killed
                                          I then tried deleting the first image (img01.jpg) once and trying again. It worked better then, but it still broke. This time, image img01.jpg came first, then image img04.jpg, then Killed.
                                          What could be the reason that the process is no longer executed?
                                            sdetweil @Seregeth
                                            @Seregeth the images are not the right quality or size?
