    MMM-Face-Reco-DNN
    26 Posts 4 Posters 18.3k Views 5 Watching
      sdetweil @Parvez
      @Parvez sorry, no idea…
      • ParvezP
        Parvez
        @sdetweil Thank you for your help…
        Parvez Ahmed
          jimbydude @Parvez
          @Parvez hi,
          I took a fork of SMAI that uses recoDNN an doesn’t require any external python running (recoDNN does that), i also detail training.
          https://github.com/jimbydude/MMM-AI-Face-Login
          Cheers
            Seregeth @jimbydude
            i have done all to import my fotos. i worked all along without any error.
            is it possible to test the importet Foto set?
            As i set up the Module, i will not recognice me. Is it possible to test anyway?
              sdetweil @Seregeth
              @Seregeth I do not know. this would have to be provided by the OCV (Open computer vision)
              code, not ours
                Seregeth @sdetweil
                Thank you very much for the feedback.
                I almost thought so. But maybe someone knows, so I can narrow down where my mistake is.
                If it’s because the person isn’t recognised, it’s different than if I’ve set a parameter incorrectly.
                  sdetweil @Seregeth
                  @Seregeth the module hasn’t been supported for a number of years, and I don’t remember any debugging assistance provided
                    Seregeth @sdetweil
                      sdetweil @Seregeth
                      @Seregeth I think you posted this to the wrong topic
                      has nothing to do with face reco
                        Seregeth @sdetweil
                        I have now managed to get the module to recognise me. Following this nice success, I now wanted to add other people to it.
                        But that is no longer possible, the process always stops:
                        I start:
                        python3 encode.py -i …/dataset/ -e encodings.pickle -d hog
                        then comes:
                        [INFO] quantifyng faces…
                        [INFO] processing image 1/17 - …/dataset/Pauline/img01.jpg
                        Killed
                        I then tried deleting the first image (img01.jpg) once and trying again. It worked better then, but it still broke. This time, image img01.jpg came first, then image img04.jpg, then Killed.
                        What could be the reason that the process is no longer executed?
                          sdetweil @Seregeth
                          @Seregeth the images are not the right quality or size?
                            Seregeth @sdetweil
                            Maybe, but i took the images the same way like the first ones.
                            I will try to edit the fotos an will run again
                              Seregeth @sdetweil
                              you have been right, it seems, taht the pictures were too big. i shrink them and it worked
