    MMM-Face-Reco-DNN
    26 Posts 4 Posters 10.3k Views 5 Watching
    • ParvezP Offline
      Parvez
      but its do not work.
      Parvez Ahmed
      • ParvezP Offline
        Parvez
        Parvez Ahmed
          sdetweil @Parvez
          @Parvez what happens when u run the script?
          Facial Recognition Embeddings
          After you set up your dataset, we need to go to the embeddings for the recognitions. I prepared a script for that. It took a while to run on my Macbook and will take much longer on a Raspberry Pi, so if possible, use it on a computer with more power and then transfer the resulting file.
          You will find a script called encode.py in folder tools of the module. The following arguments are default:
          python3 encode.py -i ../dataset/ -e encodings.pickle -d hog
          linux us case sensitive… so Parvez is not the same as parvez
          • ParvezP Offline
            Parvez
            if any one make a vedio for me is very helpful . i will submit this project my university
            Parvez Ahmed
            • ParvezP Offline
              Parvez
              @sdetweil said in MMM-Face-Reco-DNN:
              python3 encode.py -i …/dataset/ -e encodings.pickle -d hog
              how to run this script
              Parvez Ahmed
                sdetweil @Parvez
                @Parvez
                you will find a script called encode.py in folder tools of the module
                so,
                cd tools
                • ParvezP Offline
                  Parvez
                  Parvez Ahmed
                    sdetweil @Parvez
                    @Parvez looks like it is trying to detect text in the images… don’t know why
                    https://raspberrypi.stackexchange.com/questions/89231/tesseract-ocr-4-x-beta-for-raspberry-pi
                      sdetweil @Parvez
                      @Parvez dist-packages/cv2 seems pretty old… cv3 is current, cv4 is also out…
                      ParvezP 1 Reply Last reply Reply Quote 0
                      • ParvezP Offline
                        Parvez @sdetweil
                        @sdetweil ok i will download open cv3
                        Parvez Ahmed
