    fresh install MM2.1 with this error
    1 Posts 1 Posters 1.2k Views 1 Watching
      codyli2002hk
      /usr/lib/node_modules/npm/node_modules/glob/node_modules/fs.realpath/index.js:1
      (function (exports, require, module, __filename, __dirname) {
      SyntaxError: Invalid or unexpected token
      at Object.exports.runInThisContext (vm.js:76:16)
      at Module._compile (module.js:542:28)
      at Object.Module._extensions…js (module.js:579:10)
      at Module.load (module.js:487:32)
      at tryModuleLoad (module.js:446:12)
      at Function.Module._load (module.js:438:3)
      at Module.require (module.js:497:17)
      at require (internal/module.js:20:19)
      at Object. (/usr/lib/node_modules/npm/node_modules/glob/glob.js:44:10)
      at Module._compile (module.js:570:32)
      What’ s wrong? I need help from an expert!
      Thank you
