    OpenWeatherForecast
    9 Posts 3 Posters 1.3k Views 3 Watching
      sdetweil @seramik
      @seramik at one time there was a collision between this module and others
      try my fork instead. no change to config
      https://github.com/sdetweil/MMM-OpenWeatherMapForecast
        seramik
        It works :D
        I hope it will be a nice day for you as it will be for me, now
        Thank you a lot
          croc_dad72
          Just added this to mine, but nothing is showing up, just says loading? Any Ideas? Or does it take a while for the key to work?
          Thanks!
            sdetweil @croc_dad72
            @croc_dad72 should be immediate.
            what is just added ‘this’
              croc_dad72 @sdetweil
              @sdetweil well I must have done something wrong somewhere, cause it just says loading, and my api key works fine on the default module? And by “this” I meant I added your fork. Sorry I should have been more clear.
                @croc_dad72 which key do you have? onecall , 3.0 , which you have to give a credit card for, or some prior 2.5
                if you look ok in the mm startup messages do you see any reported error? 401 maybe
                  @sdetweil this is my start up? I only see two lines that say “error” but doesn’t seem to have an explanation? I don’t know what im looking for forsake though?
                    @croc_dad72
                    should say
                    openweathermapforecast error ???
                    whatever the error is
