    OpenWeatherForecast
    9 Posts 3 Posters 1.4k Views 3 Watching
      seramik
      Hi, i’ve just replace my old “MMM-NOAA3” with “MMM-OpenWeatherForecast”
      and i’ve already got a trouble :
      I’ve got another module “MMM-RAIN-MAP” who used to work very well, but this one doesn’t appear any more
      i’ve tried several places in the screen, but no way
      At the start of the mirror, I saw my rain map display (for 1or 2 second) but it desappear when the other one comes
        sdetweil @seramik
        @seramik at one time there was a collision between this module and others
        try my fork instead. no change to config
        https://github.com/sdetweil/MMM-OpenWeatherMapForecast
          seramik
          It works :D
          I hope it will be a nice day for you as it will be for me, now
          Thank you a lot
            croc_dad72
            Just added this to mine, but nothing is showing up, just says loading? Any Ideas? Or does it take a while for the key to work?
            Thanks!
              sdetweil @croc_dad72
              @croc_dad72 should be immediate.
              what is just added ‘this’
                croc_dad72 @sdetweil
                @sdetweil well I must have done something wrong somewhere, cause it just says loading, and my api key works fine on the default module? And by “this” I meant I added your fork. Sorry I should have been more clear.
                  @croc_dad72 which key do you have? onecall , 3.0 , which you have to give a credit card for, or some prior 2.5
                  if you look ok in the mm startup messages do you see any reported error? 401 maybe
                    @sdetweil this is my start up? I only see two lines that say “error” but doesn’t seem to have an explanation? I don’t know what im looking for forsake though?
                      @croc_dad72
                      should say
                      openweathermapforecast error ???
                      whatever the error is
