    MM Update gemacht, jetzt geht nichts mehr :-(
    4 Posts 3 Posters 694 Views 2 Watching
      robiv8
      Habe diverse Module Upgedatet und dann versehentlich auch auf das MagicMirror Update geklickt. (Remote Seite).
      Nun geht nix mehr. Bekomme ich das wieder hin oder muß ich alles Neu Installieren.?
      Danke
      Robi
      /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
      0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1035:19)
      0|MagicMir |     at require (node:internal/modules/cjs/helpers:102:18)
      0|MagicMir |     at bindings (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/bindings/bindings.js:112:48)
      0|MagicMir |     at /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:7:31
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:15:3)
      0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1141:14)
      0|MagicMir |     at Module._extensions..js (node:internal/modules/cjs/loader:1196:10)
      0|MagicMir |     at Module.load (node:internal/modules/cjs/loader:1011:32)
      0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:846:12)
      0|MagicMir |     at f._load (node:electron/js2c/asar_bundle:2:13330)
      0|MagicMir | (Use `electron --trace-warnings ...` to show where the warning was created)
      0|MagicMir | [09.04.2023 00:33.45.888] [ERROR] (node:1587) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
      0|MagicMir | MESA-LOADER: failed to retrieve device information
      0|MagicMir | MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
      0|MagicMir | failed to load driver: kms_swrast
      0|MagicMir | MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
      0|MagicMir | failed to load swrast driver
      0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      0|MagicMir | [09.04.2023 00:41.07.509] [ERROR] (node:1918) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
      0|MagicMir | was compiled against a different Node.js version using
      0|MagicMir | NODE_MODULE_VERSION 106. This version of Node.js requires
      0|MagicMir | NODE_MODULE_VERSION 110. Please try re-compiling or re-installing
      0|MagicMir | the module (for instance, using `npm rebuild` or `npm install`).
      0|MagicMir |     at process.func [as dlopen] (node:electron/js2c/asar_bundle:2:1822)
      0|MagicMir |     at Module._extensions..node (node:internal/modules/cjs/loader:1226:18)
      0|MagicMir |     at Object.func [as .node] (node:electron/js2c/asar_bundle:2:1822)
      0|MagicMir | [09.04.2023 00:41.07.509] [ERROR] (node:1918) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
        sdetweil @robiv8
        @robiv8 use my fork
        https://github.com/sdetweil/MMM-Navigate
        git clone,
        npm install as usual
        no changes to code or config
        please advise
          sdetweil @robiv8
          @robiv8 yes, the onoff lib used by this module, and buttons, and pir… has to match the electron version…
          but the way the author did it doesn’t work anymore
          givee a few hours and I’ll provide a link to a fixed module
            sdetweil @robiv8
            @robiv8 use my fork
            git clone,
            please advise
              robiv8 @sdetweil
              dear @sdetweil
              Thank you very much.
              It worked like a charm.
              I wish you happy Easter
