    mouse pointer in MM
    3 Posts 2 Posters 1.0k Views 2 Watching
    • A
      alphanet
      After installing my MagicMirror, I cannot see the mouse pointer any more inside the mirror.
      I would like to make it visible when needed to point elements … and to make it invisible again after that, if possible.
      Which command should I use to do this ?
      I thank you very much in advance for your help.
      alphanet
        sdetweil @alphanet
        @alphanet typically on a ‘mirror’ on the wall, you wouldn’t want to see the cursor, so it is turned off in main.css
        you can turn it back on by adding
        html {
               cursor: unset;
        to your ~/MagicMirror/css/custom.css
        if it does not exist, create it
        then add, and restart magicmirror
        A 1 Reply Last reply
        • A
          alphanet @sdetweil
          Thank you very much for this css solution to my question concerning the cursor.
          This is exactly what I was looking for in order to manage it as I wish.
          Greetings !
