    pm2 no longer launching MM
    38 Posts 3 Posters 14.9k Views 3 Watching
      sdetweil @JMac
      @JMac and u erased the node_modules folder ( the rm -rf)
        JMac @sdetweil
        @sdetweil yes ran all three lines you posted.
          JMac @sdetweil
          @sdetweil Sorry to double reply, I ran the last 2 again and they worked ok, right up until the very end of the npm install when I got an ERR_SOCKET_TIMEOUT.
          I’m assuming this is a wifi strength issue as the position of this mirror means it struggles at times.
            sdetweil @JMac
            @JMac yeh, everything is very network dependent…
            I ended up installing a mesh wifi system to be able to put an access point near where my hall mirror is
              JMac @sdetweil
              @sdetweil Managed to run it a second time and everything seems happy, however, the pm2 start mm.sh still isn’t launching the MM itself.
              Is there any other way to launch the mirror, or a way to check why it’s suddenly lost function (it was always happy launching and stopping the MM) ?
                sdetweil @JMac
                @JMac so, I would do this
                pm2 stop all
                npm start
                does it run correctly?
                you MAY have to update pm2, its just an app too…
                depending on how old it was
                see the pm2 --help
                for the command to do its update
                  JMac @sdetweil
                  @sdetweil when I run npm start from the MM folder I get:
                  magicmirror@2.23.0 start
                  sh: 1: ./node_modules/.bin/electron: not found
                    sdetweil @JMac
                    @JMac ok, do this
                    what device is this on? pi3?
                    rm -rf node_modules/electron
                    npm install electron@22.3.4
                    npm start
                    please advise
                      JMac @sdetweil
                      @sdetweil this is on a 3b+.
                      when running npm install I’m now back to an error for ENOTEMPTY for node_modules/ansi-escapes.
                      it says directory not empty.
                      I think it wants it renamed no_modules/.ansi-escapes-TiTd7xs1
                        sdetweil @JMac
                        @JMac ok, try this
                        rm package-lock.json
                        npm start
                        • 1 / 4
