pm2 no longer launching MM
38 Posts 3 Posters 8.4k Views 3 Watching
    JMac
    Hey guys, frequent searcher of this forum but this issue is the first which has me completely stuck and not able to solve with lots of Googling.
    MY MM prompted an update last week, which I did following the update guidance on the main builder site. Part way through the update failed, I had to go away for the bank holiday here in the UK and I’m now picking it back up.
    As per the title I launch the magicmirror in terminal using pm2 start mm.sh (it’s always worked) it says it’s done but then the MM never actually launches.
    when I check the pm2 logs I get an error around a directory no being empty and the node_module engine.io needing renaming.
    any thoughts on sorting this? I don’t know if this is just the first hurdle or the only reason the MM is no longer launching.
    I don’t have a programming background so please be gentle.
    Cheers.
    S 1 Reply Last reply Apr 13, 2023, 6:54 PM Reply Quote 0
      sdetweil @JMac
      @JMac which way did u upgrade? manual, git pull, or my script?
      I see that you used the manual method, do this
      sudo rm -rf node_modules
      npm install --omit=dev
      J 1 Reply Last reply Apr 16, 2023, 11:17 AM Reply Quote 0
        JMac @sdetweil
        @sdetweil Thanks for your reply, your helping of others has helped me out endlessly with this project.
        I run the npm install then get an error ENOTEMPTY around /home/pi/MagicMirror/node_modules/ansi-escapes.
        saying the directory isn’t empty.
        S 1 Reply Last reply Apr 16, 2023, 11:45 AM Reply Quote 0
          sdetweil @JMac
          @JMac and u erased the node_modules folder ( the rm -rf)
          J 2 Replies Last reply Apr 16, 2023, 12:43 PM Reply Quote 0
            JMac @sdetweil
            @sdetweil yes ran all three lines you posted.
              JMac @sdetweil
              @sdetweil Sorry to double reply, I ran the last 2 again and they worked ok, right up until the very end of the npm install when I got an ERR_SOCKET_TIMEOUT.
              I’m assuming this is a wifi strength issue as the position of this mirror means it struggles at times.
              S 1 Reply Last reply Apr 16, 2023, 12:54 PM Reply Quote 0
                sdetweil @JMac
                @JMac yeh, everything is very network dependent…
                I ended up installing a mesh wifi system to be able to put an access point near where my hall mirror is
                J 1 Reply Last reply Apr 16, 2023, 2:36 PM Reply Quote 0
                  JMac @sdetweil
                  @sdetweil Managed to run it a second time and everything seems happy, however, the pm2 start mm.sh still isn’t launching the MM itself.
                  Is there any other way to launch the mirror, or a way to check why it’s suddenly lost function (it was always happy launching and stopping the MM) ?
                  S 1 Reply Last reply Apr 16, 2023, 2:38 PM Reply Quote 0
                    sdetweil @JMac
                    @JMac so, I would do this
                    pm2 stop all
                    npm start
                    does it run correctly?
                    you MAY have to update pm2, its just an app too…
                    depending on how old it was
                    see the pm2 --help
                    for the command to do its update
                    J 1 Reply Last reply Apr 16, 2023, 3:01 PM Reply Quote 0
                      JMac @sdetweil
                      @sdetweil when I run npm start from the MM folder I get:
                      magicmirror@2.23.0 start
                      sh: 1: ./node_modules/.bin/electron: not found
                      S 1 Reply Last reply Apr 16, 2023, 3:45 PM Reply Quote 0
                      • 1 / 4
                      1 / 4
