    pm2 no longer launching MM
    38 Posts 3 Posters 17.9k Views 3 Watching
      sdetweil @JMac
      @JMac so, I would do this
      pm2 stop all
      npm start
      does it run correctly?
      you MAY have to update pm2, its just an app too…
      depending on how old it was
      see the pm2 --help
      for the command to do its update
      J 1 Reply Last reply
        JMac @sdetweil
        @sdetweil when I run npm start from the MM folder I get:
        magicmirror@2.23.0 start
        sh: 1: ./node_modules/.bin/electron: not found
          sdetweil @JMac
          @JMac ok, do this
          what device is this on? pi3?
          rm -rf node_modules/electron
          npm install electron@22.3.4
          npm start
          please advise
            JMac @sdetweil
            @sdetweil this is on a 3b+.
            when running npm install I’m now back to an error for ENOTEMPTY for node_modules/ansi-escapes.
            it says directory not empty.
            I think it wants it renamed no_modules/.ansi-escapes-TiTd7xs1
              sdetweil @JMac
              @JMac ok, try this
              rm package-lock.json
              npm start
                JMac @sdetweil
                @sdetweil after running the npm install now getting a different ENOTEMPTY for nodes_modules/basic-auth.
                Same issue of directory not empty
                  sdetweil @JMac
                  @JMac weird, this makes no sense
                    JMac @sdetweil
                    @sdetweil I’m away with work until Friday but obviously want to try and get to the bottom of this.
                    I’ll likely end up moving the mirror to somewhere way closer to the WiFi router.
                    Will this stay open until the end of the week?
                    Out of curiosity when launching via pm2 should it (in the little box that pops up in terminal) mention fork?
                    S 2 Replies Last reply
                      sdetweil @JMac
                      @JMac this will stay open til u close it…
                      yes, that is the linux term for starting an independent process
                        sdetweil @JMac
                        @JMac I would rename the existing mm folder
                        and then run install again, use my script
                        to help move the modules and config, I’d use my backup/restore scripts
                        https://github.com/sdetweil/MagicMirror-backup-restore
                        backup before rename, restore after reinstall
                          JMac
                          may sound like a daft question but how do I rename the magicmirror folder? I’ve run your back up (hopefully).
                            sdetweil @JMac
                            @JMac in Linux the rename command is mv
                            cd ~
                            mv MagicMirror newname
                              JMac
                              sorry to sound extremely daft, but what should I be renaming it? Is there a preferred name or one which makes most sense?
                                sdetweil @JMac
                                @JMac any name that works for you, you are just making room for the installer which is hard coded to use MagicMirror, and will abort if that folder is already created
                                  JMac
                                  once a new name is picked can it later be changed back to magicmirror just to keep everything standard?
                                  Also, when you say,
                                  mv magicmirror newname, I’m guessing the newname bit is actually what I want to call it, or do I put the new name after?
                                  I’ve got a terrible feeling I’ll have to start the whole thing again which I definitely won’t look forward to.
                                    sdetweil @JMac
                                    @JMac new name is whatever u want to call it
                                    it looks like there is a mess, and you are reinstalling.
                                    my backup and restore scripts can capture your config and modules and let you out then back onto a new MagicMirror
                                    but, by saving the folder anything not handled can be recovered
                                      JMac
                                      made the name change and started the install.
                                      How long should the install take? After installing the helper tools it’s got about half way across the screen on updating packages and hasn’t moved for about 10 minutes, prior to that it was pretty quick. I tried to use the arrow keys on my keyboard to move up the terminal window a little and have ^[[A[ and ^[[C[ in the list, is this an issue?
                                        sdetweil @JMac
                                        @JMac depends on how much updating is required… there is a little => arrow moving at the bottom
                                          JMac
                                          yea that’s the little widget that wasn’t moving all that much for a good while, low and behold not 2 minutes after posting it starting carrying on. I tried to come and delete the pending post but you got in there pretty quick with the reply.
                                          once this has run do I need to run your update code or will this be the most current version of MM?
                                            sdetweil @JMac
                                            @JMac this is the most current version… we update versions every 3 months…
                                            if you try update and its the same as current, it just exists, after writing a log message to that effect
                                            upgrade is a two step process… I don’t want to mess anything up…
                                            so, running script with no parms, tests, and sees if there are any issues you need to know about… code that you changed that might be overwritten, …
                                            and if you are happy (or resolved all the issues) , then adding the parm
                                            apply
                                            and running again will DO the upgrade
