    Alt Key Doesn't Open Menu
    21 Posts 5 Posters 8.7k Views 5 Watching
    • F Offline
      Fifteen15Studios
      I recently had to re-do my entire setup. I re-installed Raspbian and MM. When all is said and done, MM loads properly, all modules work, but pressing the Alt key doesn’t seem to do anything. I posted on Reddit but the only person to respond says that they experienced the same thing. Just like me, the Alt key worked fine until a fresh install. Any idea why this is happening or how to fix it?
      If it matters, it’s running on a Pi 3B, using pm2 to start MM. I also tried using the sample config file, and it did the same thing.
      https://www.reddit.com/r/MagicMirror/comments/12k0jj5/alt_key_doesnt_work/
        sdetweil @Fifteen15Studios
        @Fifteen15Studios try alt-spacebar
        • F Offline
          Fifteen15Studios @sdetweil
          @sdetweil That opened this menu
            @Fifteen15Studios what menu were you talking about?
            mm is a browser app, so that is it’s frame’s menu,
            I have never seen anything else
            • F Offline
              @sdetweil It used to pop down the browser’s menu. With a File, Tools, etc. I could get it to show developer mode from that menu, and more.
                @Fifteen15Studios I guess electron must have changed its behavior.
                  @Fifteen15Studios I see how to do the disable in code, but we don’t do that.
                  window.removeMenu()
                  I do not see any mention of changing the default behavior or how to enable it
                  F karsten13K 2 Replies Last reply Reply Quote 0
                  • F Offline
                    @sdetweil It only seemed to happen with a fresh install. I had an older version installed that I just continuously updated for months and never had this issue. But with a fresh install, behavior is different. Maybe there’s something that changed in the install script that causes it?
                    • karsten13K Online
                      karsten13 @sdetweil
                      @sdetweil said in Alt Key Doesn't Open Menu:
                      we are using frame: false in electronOptions
                        @Fifteen15Studios well, we upgraded the to a newer version of electron. everyone keeps changing things…
