    Updating modules through MMM-Remote-Control
    9 Posts 2 Posters 1.9k Views 2 Watching
    • N Offline
      Nneuland
      I recently attempted to update modules through the MMM-Remote-Control module via my phone.
      I shouldnt have. Something went wrong and the mirror no longer automatically boots on start up. Is there a trick to using this feature for clean updates?
      Thanks in advance
        sdetweil @Nneuland
        @Nneuland depends on the module. all the ones that use gpio pins will need an electron-rebuild, for which the process changed.
        if u upgrade mm base, same thing. my upgrade script tries to handle all that. don’t know what remote control does, but it’s old, so probably not
        • N Offline
          Nneuland @sdetweil
          Thanks Sam. Could you share a link to your upgrade script?
            sdetweil @Nneuland
            @Nneuland https://github.com/sdetweil/MagicMirror_scripts
            install, upgrade…
            backup and restore here
            https://github.com/sdetweil/MagicMirror-backup-restore
            • N Offline
              Nneuland @sdetweil
              This is wonderful! Thank you Sam!!!
                sdetweil @Nneuland
                @Nneuland if u have already tried to upgrade the base, you can try
                upgrade w parameter
                force
                instead of
                apply
                this overrides the version check
                • N Offline
                  Nneuland @sdetweil
                  Great to know. Thank you.
                  Is https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                  for auto update
                    sdetweil @Nneuland
                    @Nneuland no auto update. in my opinion still too risky
                    • N Offline
                      Nneuland @sdetweil
                      glad I asked. Have a great day, Sam
