    New Installation don´t work
    13 Posts 2 Posters 5.1k Views 2 Watching
    • X
      xeroxu
      I started a new installation with the guide, but when I came to the point : npm run install-mm
      I get the Error message: command not found.
      What is wrong?
        sdetweil @xeroxu
        @xeroxu ah, you didn’t copy the line exactly as it was on GitHub…
        when u have the mouse over the line to copy, a little box will appear to copy the text
        it should be
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
        this uses curl to download the text. and then bash to execute it
        X 1 Reply Last reply
          sdetweil @xeroxu
          @xeroxu after you did the
          git clone
          did you
          cd MagicMirror
          my automated script install might help, see
          • X
            xeroxu @sdetweil
            yes did
            git clone & cd MagicMirror
            I´ll gonna try your script
            Thx for your answer
            I gonna repeat whats gonna happen when i tried it
            • X
              xeroxu @xeroxu
              so, now I tried the automated script ant copied :
              but also it doesn´t work, maybe my sd card is damaged?
              S X 3 Replies Last reply
                sdetweil @xeroxu
                @xeroxu can u email me the ~/install.log file so I can see what the issue is
                my email is same userid at gmail
                • X
                  xeroxu @xeroxu
                  sorry, but I can´t find the install.logfile. either in the MagicMirror directory or or the main directory of the pi.
                    sdetweil @xeroxu
                    @xeroxu this
                     ~/install.log
                    means the file
                    install.log
                    located in
                    the users home folder
                    on my pi, logged on as use pi, the home folder is
                    /home/pi
                    you can easily do
                    cd ~
                    to get there
                    the log is created ONLY from the scripted install.
                      sdetweil @xeroxu
                      @xeroxu said in New Installation don´t work:
                      you did open a terminal window and paste that command string in, right?
                      • X
                        xeroxu @sdetweil
                        @sdetweil said in New Installation don´t work:
                        /home/pi
                        yes open a terminal and put in : curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh
                        and after i press enter a lot of lines scroll down.
                        but in the home/pi/ directory is no install.log
                          sdetweil @xeroxu
                          it should be
                          • X
                            xeroxu @sdetweil
                            ah ok my fault, i‘ll try it and gonna report the results.
                            Thx for y patience
                            • X
                              xeroxu
                              It finally works :thumbs_up:
                              Thanks a lot
                                sdetweil @xeroxu
                                @xeroxu great! thanks for the follow up
