    MMM-CalendarExt3
    12 Posts 4 Posters 5.2k Views 4 Watching
      bruteforce @sdetweil
      @sdetweil I added “background-color: var(–calendarcolor);” to the .CX3.event block to make all events look the same as the full day events. As far as I can tell, that pulls the color I specify for each calendar in the config file. I’m not finding a way to specify the text color for each calendar.
        sdetweil @bruteforce
        @bruteforce well, i had it right, but wrong words
        .CX3 .calendar_mytest {
             color:blue;
        i n the dev window with that element selected
        calendar config entry
                                                        url:"...",
                                                        color: 'red'
        note the thing highlighted to the right…
        background-color same as cal color,
        color is reverse...(white)
          @bruteforce
          in css , the thing to the left of {
          is called the selector clause
          it ALWAYS selects ALL of whatever
          so --calendarcolor is ALWAYS the same
          but prefixing w .calendar_name
          eliminates all other entries which do NOT have the same class applied
            MMRIZE
            ‘–oppositeColor’ CSS variable is that. It would be decided as white or black by calculation with the lighteness of ‘–calendarColor’ automatically. Anyway, mid-range color would be the issue.
            You can specify special event with this CSS selector;
            .CX3 .event.fullday.CALENDAR_NAME,
            .CX3 .event.multiday.CALENDAR_NAME {
              background-color: var(--calendarColor);
              color: black; /* whatever you want */
            • V Offline
              videogame95 @sdetweil
              @sdetweil Hi I’m a beginner to css. Do I only change it in custom css?
              Thank-you for any help
                sdetweil @videogame95
                @videogame95
                ALL of your changes for css go in custom.css
                ALL of your config goes in config.js
                never edit any of the distributed files, MM or module… as they would break updates…
                • V Offline
                    @videogame95 I’m sorry. none of that makes sense
                    what is googlecalendar, and what does your phone have to do w that?
                    3 events?
                    Google assistant and phone ‘contact’ won’t connect?
                    web connection w Jarvis?
                    trying to change the board (border?) around text ?
                    • V Offline
                      Hi sorry when I had my old googleassistant install
                      I could ask it what my daughters name and it new
                      And answer is Megan etc.
                      With the new bugsonuent .fr googleassistant
                      It say I have give permission in my phone if ask the same question. I have turning all my setting in phone give it the permission. But it not working .
                      I used Bugsounet.ft default configuration setting what sets up activation word as javis
                      Any help thanks
                        @videogame95 the GoogkeAssistant author has asked us not to provide support for his modules here.
