    MMM-Reddit "No valid posts to display"
    10 Posts 5 Posters 2.9k Views 5 Watching
    • K Offline
      kasperb
      Hi All - out of the blue, my MMM-Reddit module is displaying the following error:
      Check the console for a full description of error.
      Note that I can’t find any error in the logs, nor did I make any changes to the module.
      Could this be an outdated backend dependency or certificate? Any help troubleshooting this issue is appreciated.
      • mumblebajM Online
        @sdetweil I had a look and made some changes to the module and it is working. Created a PR but don’t know if the owner would accept as it has been 3 to 5 years since he last made any changes.
        Guys can use the below if they want:
        https://github.com/mumblebaj/MMM-Reddit
        S R K 3 Replies Last reply Reply Quote 3
          sdetweil @kasperb
          @kasperb said in MMM-Reddit "No valid posts to display":
          MMM-Reddit
          you are not the only one
          https://github.com/kjb085/MMM-Reddit/issues/39
          the code says it got a valid response
          with data,
          but not in the right format
                      if (response.statusCode === 200) {  // good
                          body = JSON.parse(body);
                          if (typeof body.data !== "undefined") {  // good
                              if (typeof body.data.children !== "undefined") { // oops..
          and then it sends the message you see
          my guess is the service changed, the author will have to fix (or some user that knows what to do )
          • W Offline
            Wenike @sdetweil
            @sdetweil Reddit has discontinued access to its API by Pushshift.io, so if this module uses that service, that would be the ultimate cause. But it could also just be that other changes made by the API requires the module to be updated.
              sdetweil @Wenike
              @Wenike I have no idea just quickly looked at the error handling.
              • mumblebajM Online
                  sdetweil @mumblebaj
                  @mumblebaj you could link to your repo from the issue…
                    robertybob @mumblebaj
                    @mumblebaj Thanks very much for this!
                    • K Offline
                      kasperb @mumblebaj
                      @mumblebaj said in MMM-Reddit "No valid posts to display":
                      Thanks for looking into this and making the changes. How would I be able to use your version, do I need to switch to the new fork? Thanks
                        sdetweil @kasperb
                        @kasperb you just git clone his fork, instead of the original ,
                        erase the original and then git clone his… nothing else changes
                        K 1 Reply Last reply Reply Quote 1
                        • K Offline
                          kasperb @sdetweil
                          @sdetweil Thanks :-) I didn’t realize the link had changed. All working now!
                          Thanks, @mumblebaj for the fix!
