    MMM-MQTT - JSON Syntax
    3 Posts 2 Posters 1.2k Views 2 Watching
    • H
      Hilt
      Hi all
      I’m trying to display MQTT data from my solar system battery logger so that a simple capacity percentage will display on the MagicMirror. I’m using the MMM-MQTT module. While the module loads up fine, it doesn’t seem to interpret the data and simply displays " Loading "
      I need to retrieve a particular value within the topic. That value has a label of capacityP. The Pi running MagicMirror has a Mosquitto broker installed natively. And if I query the MQTT topic, it’s receiving data correctly. I think where I’m falling short is the syntax around retrieving the capacityP value from the topic. Any ideas ? I’ve tried so many different options. But I just can’t get it right!
      		module: 'MMM-MQTT',
      		position: 'bottom_left',
      		header: 'SolarMD Battery',
      			mqttServer: 'mqtt://localhost',
      			port: '1883',
      			label: 'Charge Level',
      			decimals: 1,
      			topic: 'solarmd/energy/outputEnergy/bank1',
      			jsonpointer: '{"solarmd": {"energy": {"outputEnergy": {"bank1": {"capacityP"}}}}}',
      			suffix: '%'*
      mumblebajM 1 Reply Last reply
      • mumblebajM
        mumblebaj Module Developer @Hilt
        @Hilt If you are using this MMM-MQTT module then your config does not look correct to me. Double check your config.
            module: 'MMM-MQTT',
            header: 'MQTT',
                mqttServers: [
                    //serverdetails goes here
                    subscriptions[{
                            topic: "",
                            label: "",
        H 1 Reply Last reply
        • H
          Hilt @mumblebaj
          @mumblebaj
          Thanks so much for the response. That syntax/config was the latest version ( of sooo many ) I tried where I just couldn’t get it to work
          I have since taken another route. I’m running Home Assistant and MQTT Docker containers on a Synology NAS. Home Assistant displays the info I need via a simple custom dashboard. I then use an iFrame on the Magic Mirror to display said data. Works a treat
