    Install on Windows 10
    4 Posts 2 Posters 903 Views 3 Watching
      Roadrunner451
      Hi there,
      I have several MM on Raspberry (Zero W, Zero2W, 3 and 4) and was trying to install another one on a W10 tablet…
      But I can’t :D
      I followed this : https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10
      I did a npm install in MagicMirror/vendors and /fonts
      I changed the “start” : “DISPLAY="$etc…” in package.json with
      “start”: “node_modules/.bin/electron js…etc”
      But I still get ‘node_modules’ is not recognized as an internal or external command’ when I npm start in the MagicMirror folder
      I’m a bit lost with Xindows ;)
      • karsten13K Offline
        karsten13 @Roadrunner451
        @Roadrunner451
        see https://docs.magicmirror.builders/getting-started/installation.html#other-operating-systems
        There is another Problem with the current version, see this issue for more info and workaround.
          Roadrunner451 @karsten13
          @karsten13
          Thank you for your answer, I didn’t modify “start:dev”
          Now I’m stuck with the “another problem” you mentionned and I feel like a newbie as I can’t find electron.js to correct it …
          Thanks in advance !
            Roadrunner451 @Roadrunner451
            Never mind, I found it :)
            And it works, thanks again !
