    Problems with AlexaControl
    3 Posts 2 Posters 307 Views 2 Watching
    • O Offline
      oldskoolz
      Dear Magic Mirror Pros,
      I’ve encountered a problem that’s currently preventing the progress of my major project. Let me provide some background:
      Here’s my setup:
      I’m using a Windows 10 operating system.
      MagicMirror² and Alexa are installed on this Windows machine.
      I’ve also set up Fauxmo, MMM-pages, and MMM-AlexaControl modules.
      So, everything is operating well in the basic configuration of MagicMirror² on my Windows 10 system. Additionally, I have Alexa configured on the same Windows 10 device, ensuring both MagicMirror and Alexa are always on the same WiFi network. I’ve configured the Calendar and have successfully used voice commands via Alexa to create new calendar entries.
      However, I’ve hit a roadblock: I’m unable to switch pages using voice commands or the Alexa app. I am able to control the FAUXMO simulated devices, namely “Seite 1”, “Seite 2”, etc. For example, when I turn them on, they switch to 1 and to 0 when I turn them off. Despite this, I’m really struggling with page-switching—I just can’t get it to work, and I can’t identify the problem.
      To add to the confusion, there seems to be varying opinions about whether the pages module is necessary at all: some suggest it’s possible to manage without Pages, while others disagree. Lastly, I should mention that I’m not a developer—I have some basic knowledge of server and cloud services, but that’s about it.
      So, I really need your help to solve this problem. I appreciate any suggestions or guidance you can provide.
      The MM Config:
      /* MagicMirror² Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
       * You can use environment variables using a `config.js.template` file instead of `config.js`
       * which will be converted to `config.js` while starting. For more information
       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
      let config = {
      	address: "localhost",	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/",			// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
      	language: "en",
      	locale: "en-US",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
              module: 'MMM-pages',
                      modules:
                          [[ "clock", "updatenotification", "MMM-AlexaControl", "newsfeed"],
                           [ "compliments", "calendar", "MMM-AlexaControl"]],
                      fixed: ["MMM-AlexaControl"],
              module: "MMM-AlexaControl",
              position: "middle_center",
                  image: true,
                  height: 265,
                  width: 265,
                  devices: [
                          port: 11100,
                          handler: 'PAGE_CHANGED',
                          payload: function(payload) {
                              return { 'page': 0 };
                          port: 11101,
                              return { 'page': 1 };
                  startPort: 11000,
                  refresh: true,
                  restart: true,
                  stop: true,
                  reboot: false,
                  shutdown: false,
                  pm2ProcessName: "pm2",
                  monitorToggle: true,
                  vcgencmd: true,
                  usb: false
      .... and so on
      The MMM-AlexaControl JS:
       * Magic Mirror
       * Module: MMM-AlexaControl
       * By JoChef2
       * MIT Licensed.
      Module.register("MMM-AlexaControl",{
      	defaults:{
          image: true,
          height: 265,
          width: 265,
          pages: 3,
      devices: {
          "Seite 1": {
              port: 11100,
          "Seite 2": {
              port: 11101,
              notifications: [],  //  empty array for your notification devices
              commands: [],       // empty array for your command devices
              startPort: 11000,   //  the lowest used port
              refresh: true,      //  refresh your Mirror
              restart: true,      //  restart your Mirror with pm2
              stop: true,         //  stops your Mirror with pm2
              reboot: false,      //  reboot your pi
              shutdown: false,    //  shutdown your pi
              pm2ProcessName: "mm",  //  name of your pm2 process
              monitorToggle: true,   //  switch your monitor on and off
              vcgencmd: 'vcgencmd',  //  command you use for monitor toggle
              cecAddress: "0.0.0.0", //  Address for the cec-client
              usb: false          // toggle usb power of your pi
          getTranslations: function(){            // add more translations
              return {
                  en: "translations/en.json",
                  de: "translations/de.json"
          start: function(){
              Log.log('Starting module: ' + this.name);
              // send all translations to node_helper
              this.sendSocketNotification('TRANSLATIONS', {"monitor": this.translate("MONITOR"), "shutdown": this.translate("SHUTDOWN"), "reboot": this.translate("REBOOT"), "page": this.translate("PAGE"), "refresh": this.translate("REFRESH"), "restart": this.translate("RESTART"), "stop": this.translate("STOP"), "usb": this.translate("USB"), "deviceName":this.translate(this.config.deviceName)});
              this.sendSocketNotification('SET_DEVICE', this.config);  // send the config to node_helper
          getDom: function(){             // returns only an image or an empty div (necessary for MMM-Pages)
              if(this.config.image){
                  let img = document.createElement("img");
                  img.classList = "img";
                  img.src = "MMM-AlexaControl/AlexaLogoGrey.png";
                  img.height = this.config.height;
                  img.width = this.config.width;
                  return img;
              }else{
                  return document.createElement("div");
              if(notification === "PAGE_CHANGED"){              //  change pages of MMM-Pages
                  this.sendNotification("PAGE_CHANGED", payload);
              if(notification === "ACTION"){                    //  refresh the Mirror
                  if(payload === "refresh"){
                      window.location.reload(true);
              if(notification === "CUSTOM"){
                  this.sendNotification(payload[0], payload[1]);  //  send any notification to any module
              if(notification =='MONITOR_ACTION'){
                  Log.log('RECEIVE monitor NOTIFICATION='+payload)
                  this.sendNotification(notification,payload)
      Node Fauxmo index.js:
      'use strict';
      const FauxMo = require('node-fauxmo');
      let fauxMo = new FauxMo(
          devices: [
              port: 11000,
              handler: function(action) {
                  console.log('Seite 1:', action);
              port: 11001,
                  console.log('Seite 2:', action);
              port: 11002,
                  console.log('Seite 3:', action);
      And the MMM-Pages is basically untouched… so default Config entrys in there.
      Any hints what i am doing wrong?
      Best Regards
      The Noob :)
        sdetweil @oldskoolz
        @oldskoolz just got home. you don’t do anything w the fauxmo file the ac module does everything
          @oldskoolz
          rule 1… never change MagicMirror or a module source code, it breaks the ability to update. all config goes in MagicMirror/config/config.js
          you don’t add devices for pages, all you do is set the number of pages you want to navigate to … pages: 3
          this will give you devices for page 1, page 2 and page 3
          in the npm start output you should see the number of devices created
          that you can access via
          Alexa turn on page 2
          as the devices are fake outlets
          if u want a different voice command, you can use an actual alexa routine
          select voice
             go to page 2
          action
             smart home devices
            page 2
               power on
          alexa does not provide any symbolic replacement functions
          go to page {n}
          replace n with a number on execute
