    MMM-NOAA3 4day forcast doesn't display
    25 Posts 5 Posters 7.3k Views 5 Watching
      JohnGalt @monark
      @monark - I’m unsure what you mean by prove openmapweather. Following is the relevant code from my config.js, as well as a screenshot of the result.
      0 { module: 'MMM-NOAA3',
      191    position: 'top_right',
      192    config: {
      193        provider: "openweather", // From list
      194        apiKey: "xxxxxxx",        // From one of the providers listed above
      195        airKey: "yyyyyyyyyy",
      196        css: "NOAA3",                   // THIS MUST CONTAIN A CSS STYLE NAME
      197        userlat: "36.xxx", //MUST HAVE BOTH
      198        userlon: "-115.yyy"  //MUST HAVE BOTH
      199 }
        JohnGalt @monark
        @monark - screen shot: NOAA3.png
        mumblebajM 2 Replies Last reply Reply Quote 0
        • mumblebajM Offline
          mumblebaj Module Developer @JohnGalt
          @JohnGalt Weird. I am using weatherbit as the provider and mine is displaying fine. It could be that openweather data format has changed?
            @JohnGalt It seems like the v2.5 of the API only returns the current days data and not multiple days hence the 4 day forecast is empty.
              JohnGalt @mumblebaj
              @mumblebaj - Thanks for that. I changed the provider to weatherbit and now do have the 4-day forecast. I guess the developers will need to update the module if they want people to continue to use openweather…
              As regards the AQI reporting ‘undefined’ [likely because the AirKEY expires after one year] - Does anyone know whether one is just allowed a single year AirKey, and then no more use?
                @JohnGalt It is hard to keep up with the changing API’s. One only find out that it has changed when it breaks. Just way of the world that is.
                You should be able to renew the Airkey if it has expired.
                  JohnGalt @mumblebaj
                  @mumblebaj – Yes, I would have thought I would be able to renew the key. I just checked again and do not see any way to renew, so I put in a service request at the site… Below is what I see on my personal dashboard. Note there is no way to renew. The ‘edit’ button only allows one to edit the name of the key…
                    @JohnGalt Well, looks like it is still Active.
                      JohnGalt @mumblebaj
                      @mumblebaj - Yes, good observation. I saw that too, and I do wonder why the dashboard says ‘active’ and ‘expires in 89 days ago’ at the same time.
                      Independent of what they mean by ‘active’ or ‘expired’ - I am still getting ‘undefined’ as an AQI value on the display…
                      @cowboysdude - any thoughts from the perspective as the developer or distributor of this?
                      @kurtern84 - same question…
                        monark
                        you have subscribe openmapweather onecall?
