    MMM-NOAA3 4day forcast doesn't display
    25 Posts 5 Posters 9.3k Views 5 Watching
      JohnGalt
      Two issues with module installation:
      [1] The 4 day forecast icons do not display. A prior response to a user with this issue suggested the fix would be to ensure all the images are in the images folder. The forecast for each of the next several days is mostly sunny, so I have verified the relevant image for ‘mostlysunny.png’ is in the images folder. I also tried deleting and reinstalling the entire module, and also ensuring this module is not inadvertently addressed in my custom.css file. No change…
      I’m not sure I should include the following in this post or create a separate post, as it feels like a separate installation issue. As such, if a moderator sees fit to separate them - that’s fine.
      [2] The AQI value displays as ‘undefined’, which I suspect is an API issue. I do have an API from airvisual - but my notes tell me it expired a few months ago. I went to the airvisual site to renew the API key. The site does show the key identifier and shows it to be expired, but the site does not appear to support renewing a key after the initial one year period. Is a free user just out of luck after one year?
        monark @JohnGalt
        @JohnGalt please prove openmapweather
          JohnGalt @monark
          @monark - I’m unsure what you mean by prove openmapweather. Following is the relevant code from my config.js, as well as a screenshot of the result.
          0 { module: 'MMM-NOAA3',
          191    position: 'top_right',
          192    config: {
          193        provider: "openweather", // From list
          194        apiKey: "xxxxxxx",        // From one of the providers listed above
          195        airKey: "yyyyyyyyyy",
          196        css: "NOAA3",                   // THIS MUST CONTAIN A CSS STYLE NAME
          197        userlat: "36.xxx", //MUST HAVE BOTH
          198        userlon: "-115.yyy"  //MUST HAVE BOTH
          199 }
            JohnGalt @monark
            @monark - screen shot: NOAA3.png
            mumblebajM 2 Replies Last reply Reply Quote 0
            • mumblebajM Offline
              mumblebaj Module Developer @JohnGalt
              @JohnGalt Weird. I am using weatherbit as the provider and mine is displaying fine. It could be that openweather data format has changed?
                @JohnGalt It seems like the v2.5 of the API only returns the current days data and not multiple days hence the 4 day forecast is empty.
                  JohnGalt @mumblebaj
                  @mumblebaj - Thanks for that. I changed the provider to weatherbit and now do have the 4-day forecast. I guess the developers will need to update the module if they want people to continue to use openweather…
                  As regards the AQI reporting ‘undefined’ [likely because the AirKEY expires after one year] - Does anyone know whether one is just allowed a single year AirKey, and then no more use?
                    @JohnGalt It is hard to keep up with the changing API’s. One only find out that it has changed when it breaks. Just way of the world that is.
                    You should be able to renew the Airkey if it has expired.
                      JohnGalt @mumblebaj
                      @mumblebaj – Yes, I would have thought I would be able to renew the key. I just checked again and do not see any way to renew, so I put in a service request at the site… Below is what I see on my personal dashboard. Note there is no way to renew. The ‘edit’ button only allows one to edit the name of the key…
                        @JohnGalt Well, looks like it is still Active.
                          JohnGalt @mumblebaj
                          @mumblebaj - Yes, good observation. I saw that too, and I do wonder why the dashboard says ‘active’ and ‘expires in 89 days ago’ at the same time.
                          Independent of what they mean by ‘active’ or ‘expired’ - I am still getting ‘undefined’ as an AQI value on the display…
                          @cowboysdude - any thoughts from the perspective as the developer or distributor of this?
                          @kurtern84 - same question…
                            monark
                            you have subscribe openmapweather onecall?
                              mumblebaj Module Developer @monark
                              @monark The module is not setup to do onecall API.
                                JohnGalt @mumblebaj
                                @mumblebaj - Well, perhaps I spoke too soon… After changing the provider to weatherbit, I had data for a day or so, but now have no current data nor forecast on NOAA3, while two instances of the default weather module do still work for other locations:
                                mumblebajM M 2 Replies Last reply Reply Quote 0
                                  @JohnGalt Do you see any errors in the Developers console or in the logs? Mine seems to be running fine still without any issues.
                                    motdog @JohnGalt
                                    @JohnGalt said in MMM-NOAA3 4day forcast doesn't display:
                                    Same issue for me. I haven’t checked/changed provider but it’s been this way for a week or so. I’ll play around this weekend
                                      JohnGalt @mumblebaj
                                      @mumblebaj - Yes, there are errors in the logs. In addition, I notice that on both my displays and on the screenshot posted by @motdog in both cases not only is the content of the 4-day forecast missing, but the “4 Day Forecast” label box is also not displaying.
                                      Just for completeness, I will note I have had no response from IQAir regarding the AQI API key, nor has there been any solution suggested here on the forum.
                                      Log output [ignore the calendar error - it looks like the Detroit Lions killed the link to their calendar, which seems to happen yearly…] All the other errors appear to be for the MMM-NOAA3 module:
                                      /home/pi/.pm2/logs/MagicMirror-error.log last 25 lines:
                                      0|MagicMir |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1079:12)
                                      0|MagicMir |     at Object.onceWrapper (node:events:627:28)
                                      0|MagicMir |     at IncomingMessage.emit (node:events:525:35)
                                      0|MagicMir |     at endReadableNT (node:internal/streams/readable:1358:12)
                                      0|MagicMir |     at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
                                      0|MagicMir | [27.05.2023 15:16.35.310] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|MagicMir | [27.05.2023 15:16.35.312] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      0|MagicMir | [27.05.2023 15:16.35.345] [ERROR] Whoops! There was an uncaught exception...
                                      0|MagicMir | [27.05.2023 15:16.35.348] [ERROR] TypeError: Cannot read properties of undefined (reading 'pollution')
                                      0|MagicMir |     at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:196:36)
                                      0|MagicMir |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:189:27)
                                      0|MagicMir |     at self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                                      0|MagicMir |     at Request.emit (node:events:513:28)
                                      0|MagicMir |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1157:10)
                                      0|MagicMir | [27.05.2023 15:16.35.351] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|MagicMir | [27.05.2023 15:16.35.353] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      0|MagicMir | [27.05.2023 15:16.35.535] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/np78qdudrc3jui1n9mqr3pbud0%40group.calendar.google.com/public/basic.ics Error: Not Found
                                      0|MagicMir |     at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:119:9)
                                      0|MagicMir |     at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
                                        @JohnGalt Not too familiar with the module. Can you get more lines from the log? I think the actual issue would be in those lines. I am thinking the issue might be key related but need to see the lines above the start line you posted. Prior to this line:
                                          JohnGalt
                                          @mumblebaj - Thanks for your time and attention. Following is the log output that generates this:
                                          pi@mirror4:~ $ pm2 logs --lines=25
                                          [TAILING] Tailing last 25 lines for [all] processes (change the value with --lines option)
                                          /home/pi/.pm2/pm2.log last 25 lines:
                                          PM2        | 2023-05-27T15:14:24: PM2 log: PM2 version          : 5.1.2
                                          PM2        | 2023-05-27T15:14:24: PM2 log: Node.js version      : 16.19.0
                                          PM2        | 2023-05-27T15:14:24: PM2 log: Current arch         : arm
                                          PM2        | 2023-05-27T15:14:24: PM2 log: PM2 home             : /home/pi/.pm2
                                          PM2        | 2023-05-27T15:14:24: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                                          PM2        | 2023-05-27T15:14:24: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                                          PM2        | 2023-05-27T15:14:24: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                                          PM2        | 2023-05-27T15:14:24: PM2 log: Application log path : /home/pi/.pm2/logs
                                          PM2        | 2023-05-27T15:14:24: PM2 log: Worker Interval      : 30000
                                          PM2        | 2023-05-27T15:14:24: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                                          PM2        | 2023-05-27T15:14:24: PM2 log: Concurrent actions   : 2
                                          PM2        | 2023-05-27T15:14:24: PM2 log: SIGTERM timeout      : 1600
                                          PM2        | 2023-05-27T15:14:24: PM2 log: ===============================================================================
                                          PM2        | 2023-05-27T15:14:24: PM2 log: [Watch] Start watching MagicMirror
                                          PM2        | 2023-05-27T15:14:24: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                          PM2        | 2023-05-27T15:14:25: PM2 log: App [MagicMirror:0] online
                                          PM2        | 2023-05-27T15:16:20: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                                          PM2        | 2023-05-27T15:16:20: PM2 log: Stopping app:MagicMirror id:0
                                          PM2        | 2023-05-27T15:16:21: PM2 log: pid=635 msg=failed to kill - retrying in 100ms
                                          PM2        | 2023-05-27T15:16:21: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                          PM2        | 2023-05-27T15:16:21: PM2 log: pid=635 msg=process killed
                                          PM2        | 2023-05-27T15:16:21: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                          PM2        | 2023-05-27T15:16:21: PM2 log: App [MagicMirror:0] online
                                          PM2        | 2023-05-28T15:14:42: PM2 log: [PM2] This PM2 is not UP TO DATE
                                          PM2        | 2023-05-28T15:14:42: PM2 log: [PM2] Upgrade to version 5.3.0
                                          /home/pi/.pm2/logs/MagicMirror-out.log last 25 lines:
                                          0|MagicMir | [28.05.2023 16:09.56.814] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                          0|MagicMir | [28.05.2023 16:10.59.646] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                          0|MagicMir | [28.05.2023 16:11.27.958] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                          0|MagicMir | [28.05.2023 16:16.29.322] [INFO]  [MMM-DynamicWeather] Getting Weather API data
                                          0|MagicMir | [28.05.2023 16:16.29.666] [INFO]  [MMM-DynamicWeather] Received successful Weather API data
                                          0|MagicMir | [28.05.2023 16:16.29.957] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                          0|MagicMir | [28.05.2023 16:16.34.814] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                          0|MagicMir | [28.05.2023 16:16.57.722] [INFO]  Newsfeed-Fetcher: Broadcasting 23 items.
                                          0|MagicMir | [28.05.2023 16:17.16.173] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                                          0|MagicMir | [28.05.2023 16:17.46.774] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                                          0|MagicMir | [28.05.2023 16:24.56.817] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                          0|MagicMir | [28.05.2023 16:25.59.651] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                          0|MagicMir | [28.05.2023 16:26.27.961] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                          0|MagicMir | [28.05.2023 16:26.29.322] [INFO]  [MMM-DynamicWeather] Getting Weather API data
                                          0|MagicMir | [28.05.2023 16:26.29.750] [INFO]  [MMM-DynamicWeather] Received successful Weather API data
                                          0|MagicMir | [28.05.2023 16:26.38.930] [INFO]  Calendar-Fetcher: Broadcasting 3 events.
                                          0|MagicMir | [28.05.2023 16:26.42.175] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                          0|MagicMir | [28.05.2023 16:26.42.331] [INFO]  Calendar-Fetcher: Broadcasting 38 events.
                                          0|MagicMir | [28.05.2023 16:26.52.596] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                          0|MagicMir | [28.05.2023 16:26.56.174] [INFO]  Calendar-Fetcher: Broadcasting 37 events.
                                          0|MagicMir | [28.05.2023 16:26.57.975] [INFO]  Newsfeed-Fetcher: Broadcasting 23 items.
                                          0|MagicMir | [28.05.2023 16:27.16.525] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                                          0|MagicMir | [28.05.2023 16:27.47.201] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                                          0|MagicMir | [28.05.2023 16:30.47.955] [INFO]  Calendar-Fetcher: Broadcasting 69 events.
                                          0|MagicMir | [28.05.2023 16:31.29.957] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                          0|MagicMir | [28.05.2023 16:31.30.413] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          0|MagicMir | [28.05.2023 16:31.30.413] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          0|MagicMir | [28.05.2023 16:31.30.424] [ERROR] Whoops! There was an uncaught exception...
                                          0|MagicMir | [28.05.2023 16:31.30.425] [ERROR] SyntaxError: Unexpected token 'S', "Service Unavailable" is not valid JSON
                                          0|MagicMir |     at JSON.parse (<anonymous>)
                                          0|MagicMir |     at Object.parseALERT (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:214:27)
                                          0|MagicMir |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:209:27)
                                          0|MagicMir | [28.05.2023 16:31.30.425] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          0|MagicMir | [28.05.2023 16:31.30.425] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          0|MagicMirror  | [28.05.2023 16:31.34.814] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                          0|MagicMirror  | [28.05.2023 16:31.35.070] [ERROR] Whoops! There was an uncaught exception...
                                          0|MagicMirror  | [28.05.2023 16:31.35.071] [ERROR] SyntaxError: Unexpected token 'S', "Service Unavailable" is not valid JSON
                                          0|MagicMirror  |     at JSON.parse (<anonymous>)
                                          0|MagicMirror  |     at Object.parseALERT (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:214:27)
                                          0|MagicMirror  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:209:27)
                                          0|MagicMirror  |     at self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                                          0|MagicMirror  |     at Request.emit (node:events:513:28)
                                          0|MagicMirror  |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1157:10)
                                          0|MagicMirror  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1079:12)
                                          0|MagicMirror  |     at Object.onceWrapper (node:events:627:28)
                                          0|MagicMirror  |     at IncomingMessage.emit (node:events:525:35)
                                          0|MagicMirror  |     at endReadableNT (node:internal/streams/readable:1358:12)
                                          0|MagicMirror  |     at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
                                          0|MagicMirror  | [28.05.2023 16:31.35.072] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          0|MagicMirror  | [28.05.2023 16:31.35.073] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          0|MagicMirror  | [28.05.2023 16:31.35.096] [ERROR] Whoops! There was an uncaught exception...
                                          0|MagicMirror  | [28.05.2023 16:31.35.097] [ERROR] TypeError: Cannot read properties of undefined (reading '0')
                                          0|MagicMirror  |     at Object.parseResponse (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:81:36)
                                          0|MagicMirror  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:74:28)
                                          0|MagicMirror  | [28.05.2023 16:31.35.097] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          0|MagicMirror  | [28.05.2023 16:31.35.098] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          0|MagicMirror  | [28.05.2023 16:31.35.235] [ERROR] Whoops! There was an uncaught exception...
                                          0|MagicMirror  | [28.05.2023 16:31.35.236] [ERROR] TypeError: Cannot read properties of undefined (reading 'pollution')
                                          0|MagicMirror  |     at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:196:36)
                                          0|MagicMirror  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:189:27)
                                          0|MagicMirror  | [28.05.2023 16:31.35.236] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          0|MagicMirror  | [28.05.2023 16:31.35.236] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                            sdetweil @JohnGalt
                                            : Cannot read properties of undefined (reading ‘pollution’)
                                            no error recovery… once that happens, only MM restart will fix it…
                                            this could be a good use of the es6 chaining operator.
                                            https://forum.magicmirror.builders/topic/17677/mirror-showing-not-all-modules-on-all-devices/11?_=1683748897387
