    MMM-NOAA3 4day forcast doesn't display
    25 Posts 5 Posters 9.5k Views 5 Watching
    • mumblebajM
      mumblebaj Module Developer @JohnGalt
      @JohnGalt Weird. I am using weatherbit as the provider and mine is displaying fine. It could be that openweather data format has changed?
      • mumblebajM
        @JohnGalt It seems like the v2.5 of the API only returns the current days data and not multiple days hence the 4 day forecast is empty.
        J 2 Replies Last reply
          JohnGalt @mumblebaj
          @mumblebaj - Thanks for that. I changed the provider to weatherbit and now do have the 4-day forecast. I guess the developers will need to update the module if they want people to continue to use openweather…
          As regards the AQI reporting ‘undefined’ [likely because the AirKEY expires after one year] - Does anyone know whether one is just allowed a single year AirKey, and then no more use?
          mumblebajM 1 Reply Last reply
          • mumblebajM
            @JohnGalt It is hard to keep up with the changing API’s. One only find out that it has changed when it breaks. Just way of the world that is.
            You should be able to renew the Airkey if it has expired.
            J 1 Reply Last reply
              JohnGalt @mumblebaj
              @mumblebaj – Yes, I would have thought I would be able to renew the key. I just checked again and do not see any way to renew, so I put in a service request at the site… Below is what I see on my personal dashboard. Note there is no way to renew. The ‘edit’ button only allows one to edit the name of the key…
              • mumblebajM
                @JohnGalt Well, looks like it is still Active.
                  JohnGalt @mumblebaj
                  @mumblebaj - Yes, good observation. I saw that too, and I do wonder why the dashboard says ‘active’ and ‘expires in 89 days ago’ at the same time.
                  Independent of what they mean by ‘active’ or ‘expired’ - I am still getting ‘undefined’ as an AQI value on the display…
                  @cowboysdude - any thoughts from the perspective as the developer or distributor of this?
                  @kurtern84 - same question…
                    monark
                    you have subscribe openmapweather onecall?
                    • mumblebajM
                      mumblebaj Module Developer @monark
                      @monark The module is not setup to do onecall API.
                        JohnGalt @mumblebaj
                        @mumblebaj - Well, perhaps I spoke too soon… After changing the provider to weatherbit, I had data for a day or so, but now have no current data nor forecast on NOAA3, while two instances of the default weather module do still work for other locations:
                        mumblebajM M 2 Replies Last reply
                        • mumblebajM
                          @JohnGalt Do you see any errors in the Developers console or in the logs? Mine seems to be running fine still without any issues.
                            motdog @JohnGalt
                            @JohnGalt said in MMM-NOAA3 4day forcast doesn't display:
                            Same issue for me. I haven’t checked/changed provider but it’s been this way for a week or so. I’ll play around this weekend
                              JohnGalt @mumblebaj
                              @mumblebaj - Yes, there are errors in the logs. In addition, I notice that on both my displays and on the screenshot posted by @motdog in both cases not only is the content of the 4-day forecast missing, but the “4 Day Forecast” label box is also not displaying.
                              Just for completeness, I will note I have had no response from IQAir regarding the AQI API key, nor has there been any solution suggested here on the forum.
                              Log output [ignore the calendar error - it looks like the Detroit Lions killed the link to their calendar, which seems to happen yearly…] All the other errors appear to be for the MMM-NOAA3 module:
                              /home/pi/.pm2/logs/MagicMirror-error.log last 25 lines:
                              0|MagicMir |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1079:12)
                              0|MagicMir |     at Object.onceWrapper (node:events:627:28)
                              0|MagicMir |     at IncomingMessage.emit (node:events:525:35)
                              0|MagicMir |     at endReadableNT (node:internal/streams/readable:1358:12)
                              0|MagicMir |     at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
                              0|MagicMir | [27.05.2023 15:16.35.310] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              0|MagicMir | [27.05.2023 15:16.35.312] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              0|MagicMir | [27.05.2023 15:16.35.345] [ERROR] Whoops! There was an uncaught exception...
                              0|MagicMir | [27.05.2023 15:16.35.348] [ERROR] TypeError: Cannot read properties of undefined (reading 'pollution')
                              0|MagicMir |     at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:196:36)
                              0|MagicMir |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:189:27)
                              0|MagicMir |     at self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                              0|MagicMir |     at Request.emit (node:events:513:28)
                              0|MagicMir |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1157:10)
                              0|MagicMir | [27.05.2023 15:16.35.351] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              0|MagicMir | [27.05.2023 15:16.35.353] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              0|MagicMir | [27.05.2023 15:16.35.535] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/np78qdudrc3jui1n9mqr3pbud0%40group.calendar.google.com/public/basic.ics Error: Not Found
                              0|MagicMir |     at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:119:9)
                              0|MagicMir |     at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
                              • mumblebajM
                                @JohnGalt Not too familiar with the module. Can you get more lines from the log? I think the actual issue would be in those lines. I am thinking the issue might be key related but need to see the lines above the start line you posted. Prior to this line:
                                  JohnGalt
                                  @mumblebaj - Thanks for your time and attention. Following is the log output that generates this:
                                  pi@mirror4:~ $ pm2 logs --lines=25
                                  [TAILING] Tailing last 25 lines for [all] processes (change the value with --lines option)
                                  /home/pi/.pm2/pm2.log last 25 lines:
                                  PM2        | 2023-05-27T15:14:24: PM2 log: PM2 version          : 5.1.2
                                  PM2        | 2023-05-27T15:14:24: PM2 log: Node.js version      : 16.19.0
                                  PM2        | 2023-05-27T15:14:24: PM2 log: Current arch         : arm
                                  PM2        | 2023-05-27T15:14:24: PM2 log: PM2 home             : /home/pi/.pm2
                                  PM2        | 2023-05-27T15:14:24: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                                  PM2        | 2023-05-27T15:14:24: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                                  PM2        | 2023-05-27T15:14:24: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                                  PM2        | 2023-05-27T15:14:24: PM2 log: Application log path : /home/pi/.pm2/logs
                                  PM2        | 2023-05-27T15:14:24: PM2 log: Worker Interval      : 30000
                                  PM2        | 2023-05-27T15:14:24: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                                  PM2        | 2023-05-27T15:14:24: PM2 log: Concurrent actions   : 2
                                  PM2        | 2023-05-27T15:14:24: PM2 log: SIGTERM timeout      : 1600
                                  PM2        | 2023-05-27T15:14:24: PM2 log: ===============================================================================
                                  PM2        | 2023-05-27T15:14:24: PM2 log: [Watch] Start watching MagicMirror
                                  PM2        | 2023-05-27T15:14:24: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                  PM2        | 2023-05-27T15:14:25: PM2 log: App [MagicMirror:0] online
                                  PM2        | 2023-05-27T15:16:20: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                                  PM2        | 2023-05-27T15:16:20: PM2 log: Stopping app:MagicMirror id:0
                                  PM2        | 2023-05-27T15:16:21: PM2 log: pid=635 msg=failed to kill - retrying in 100ms
                                  PM2        | 2023-05-27T15:16:21: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                  PM2        | 2023-05-27T15:16:21: PM2 log: pid=635 msg=process killed
                                  PM2        | 2023-05-27T15:16:21: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                  PM2        | 2023-05-27T15:16:21: PM2 log: App [MagicMirror:0] online
                                  PM2        | 2023-05-28T15:14:42: PM2 log: [PM2] This PM2 is not UP TO DATE
                                  PM2        | 2023-05-28T15:14:42: PM2 log: [PM2] Upgrade to version 5.3.0
                                  /home/pi/.pm2/logs/MagicMirror-out.log last 25 lines:
                                  0|MagicMir | [28.05.2023 16:09.56.814] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                  0|MagicMir | [28.05.2023 16:10.59.646] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                  0|MagicMir | [28.05.2023 16:11.27.958] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                  0|MagicMir | [28.05.2023 16:16.29.322] [INFO]  [MMM-DynamicWeather] Getting Weather API data
                                  0|MagicMir | [28.05.2023 16:16.29.666] [INFO]  [MMM-DynamicWeather] Received successful Weather API data
                                  0|MagicMir | [28.05.2023 16:16.29.957] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                  0|MagicMir | [28.05.2023 16:16.34.814] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                  0|MagicMir | [28.05.2023 16:16.57.722] [INFO]  Newsfeed-Fetcher: Broadcasting 23 items.
                                  0|MagicMir | [28.05.2023 16:17.16.173] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                                  0|MagicMir | [28.05.2023 16:17.46.774] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                                  0|MagicMir | [28.05.2023 16:24.56.817] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                  0|MagicMir | [28.05.2023 16:25.59.651] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                  0|MagicMir | [28.05.2023 16:26.27.961] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                  0|MagicMir | [28.05.2023 16:26.29.322] [INFO]  [MMM-DynamicWeather] Getting Weather API data
                                  0|MagicMir | [28.05.2023 16:26.29.750] [INFO]  [MMM-DynamicWeather] Received successful Weather API data
                                  0|MagicMir | [28.05.2023 16:26.38.930] [INFO]  Calendar-Fetcher: Broadcasting 3 events.
                                  0|MagicMir | [28.05.2023 16:26.42.175] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                  0|MagicMir | [28.05.2023 16:26.42.331] [INFO]  Calendar-Fetcher: Broadcasting 38 events.
                                  0|MagicMir | [28.05.2023 16:26.52.596] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                  0|MagicMir | [28.05.2023 16:26.56.174] [INFO]  Calendar-Fetcher: Broadcasting 37 events.
                                  0|MagicMir | [28.05.2023 16:26.57.975] [INFO]  Newsfeed-Fetcher: Broadcasting 23 items.
                                  0|MagicMir | [28.05.2023 16:27.16.525] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                                  0|MagicMir | [28.05.2023 16:27.47.201] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                                  0|MagicMir | [28.05.2023 16:30.47.955] [INFO]  Calendar-Fetcher: Broadcasting 69 events.
                                  0|MagicMir | [28.05.2023 16:31.29.957] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                  0|MagicMir | [28.05.2023 16:31.30.413] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  0|MagicMir | [28.05.2023 16:31.30.413] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                  0|MagicMir | [28.05.2023 16:31.30.424] [ERROR] Whoops! There was an uncaught exception...
                                  0|MagicMir | [28.05.2023 16:31.30.425] [ERROR] SyntaxError: Unexpected token 'S', "Service Unavailable" is not valid JSON
                                  0|MagicMir |     at JSON.parse (<anonymous>)
                                  0|MagicMir |     at Object.parseALERT (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:214:27)
                                  0|MagicMir |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:209:27)
                                  0|MagicMir | [28.05.2023 16:31.30.425] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  0|MagicMir | [28.05.2023 16:31.30.425] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                  0|MagicMirror  | [28.05.2023 16:31.34.814] [LOG]   NOAA3 weather updated.. next update in 1 hour
                                  0|MagicMirror  | [28.05.2023 16:31.35.070] [ERROR] Whoops! There was an uncaught exception...
                                  0|MagicMirror  | [28.05.2023 16:31.35.071] [ERROR] SyntaxError: Unexpected token 'S', "Service Unavailable" is not valid JSON
                                  0|MagicMirror  |     at JSON.parse (<anonymous>)
                                  0|MagicMirror  |     at Object.parseALERT (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:214:27)
                                  0|MagicMirror  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:209:27)
                                  0|MagicMirror  |     at self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                                  0|MagicMirror  |     at Request.emit (node:events:513:28)
                                  0|MagicMirror  |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1157:10)
                                  0|MagicMirror  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1079:12)
                                  0|MagicMirror  |     at Object.onceWrapper (node:events:627:28)
                                  0|MagicMirror  |     at IncomingMessage.emit (node:events:525:35)
                                  0|MagicMirror  |     at endReadableNT (node:internal/streams/readable:1358:12)
                                  0|MagicMirror  |     at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
                                  0|MagicMirror  | [28.05.2023 16:31.35.072] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  0|MagicMirror  | [28.05.2023 16:31.35.073] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                  0|MagicMirror  | [28.05.2023 16:31.35.096] [ERROR] Whoops! There was an uncaught exception...
                                  0|MagicMirror  | [28.05.2023 16:31.35.097] [ERROR] TypeError: Cannot read properties of undefined (reading '0')
                                  0|MagicMirror  |     at Object.parseResponse (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:81:36)
                                  0|MagicMirror  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:74:28)
                                  0|MagicMirror  | [28.05.2023 16:31.35.097] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  0|MagicMirror  | [28.05.2023 16:31.35.098] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                  0|MagicMirror  | [28.05.2023 16:31.35.235] [ERROR] Whoops! There was an uncaught exception...
                                  0|MagicMirror  | [28.05.2023 16:31.35.236] [ERROR] TypeError: Cannot read properties of undefined (reading 'pollution')
                                  0|MagicMirror  |     at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:196:36)
                                  0|MagicMirror  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:189:27)
                                  0|MagicMirror  | [28.05.2023 16:31.35.236] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  0|MagicMirror  | [28.05.2023 16:31.35.236] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    sdetweil @JohnGalt
                                    : Cannot read properties of undefined (reading ‘pollution’)
                                    no error recovery… once that happens, only MM restart will fix it…
                                    this could be a good use of the es6 chaining operator.
                                    https://forum.magicmirror.builders/topic/17677/mirror-showing-not-all-modules-on-all-devices/11?_=1683748897387
                                      JohnGalt @sdetweil
                                      @sdetweil - OK, I rebooted the machine and there is no change in the behavior of the module (no AQI, no 4 day forecast). Log taken shortly after reboot follows:
                                      Last login: Sun May 28 21:25:39 2023
                                      PM2        | 2023-05-28T21:25:27: PM2 log: [Watch] Stop watching MagicMirror
                                      PM2        | 2023-05-28T21:25:27: PM2 log: Stopping app:MagicMirror id:0
                                      PM2        | 2023-05-28T21:25:27: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                      PM2        | 2023-05-28T21:25:27: PM2 error: Cancelling versioning data parsing
                                      PM2        | 2023-05-28T21:25:27: PM2 log: pid=14002 msg=process killed
                                      PM2        | 2023-05-28T21:25:27: PM2 log: PM2 successfully stopped
                                      PM2        | 2023-05-28T21:25:37: PM2 log: ===============================================================================
                                      PM2        | 2023-05-28T21:25:37: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                                      PM2        | 2023-05-28T21:25:37: PM2 log: Time                 : Sun May 28 2023 21:25:37 GMT-0700 (Pacific Daylight Time)
                                      PM2        | 2023-05-28T21:25:37: PM2 log: PM2 version          : 5.1.2
                                      PM2        | 2023-05-28T21:25:37: PM2 log: Node.js version      : 16.19.0
                                      PM2        | 2023-05-28T21:25:37: PM2 log: Current arch         : arm
                                      PM2        | 2023-05-28T21:25:37: PM2 log: PM2 home             : /home/pi/.pm2
                                      PM2        | 2023-05-28T21:25:37: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                                      PM2        | 2023-05-28T21:25:37: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                                      PM2        | 2023-05-28T21:25:37: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                                      PM2        | 2023-05-28T21:25:37: PM2 log: Application log path : /home/pi/.pm2/logs
                                      PM2        | 2023-05-28T21:25:37: PM2 log: Worker Interval      : 30000
                                      PM2        | 2023-05-28T21:25:37: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                                      PM2        | 2023-05-28T21:25:37: PM2 log: Concurrent actions   : 2
                                      PM2        | 2023-05-28T21:25:37: PM2 log: SIGTERM timeout      : 1600
                                      PM2        | 2023-05-28T21:25:37: PM2 log: [Watch] Start watching MagicMirror
                                      PM2        | 2023-05-28T21:25:37: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                      PM2        | 2023-05-28T21:25:37: PM2 log: App [MagicMirror:0] online
                                      0|MagicMir | [28.05.2023 21:26.28.343] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|MagicMir | [28.05.2023 21:26.28.344] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      0|MagicMir | [28.05.2023 21:26.28.378] [ERROR] Whoops! There was an uncaught exception...
                                      0|MagicMir | [28.05.2023 21:26.28.379] [ERROR] TypeError: Cannot read properties of undefined (reading 'pollution')
                                      0|MagicMir | [28.05.2023 21:26.28.379] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|MagicMir | [28.05.2023 21:26.28.380] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      0|MagicMir | [28.05.2023 21:26.28.567] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/np78qdudrc3jui1n9mqr3pbud0%40group.calendar.google.com/public/basic.ics Error: Not Found
                                      0|MagicMir | [28.05.2023 21:26.27.672] [LOG]   Use existing newsfetcher for url: http://rssfeeds.freep.com/freep/news.xml
                                      0|MagicMir | [28.05.2023 21:26.27.673] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                                      0|MagicMir | [28.05.2023 21:26.27.688] [LOG]   Use existing newsfetcher for url: https://www.reviewjournal.com/feed/
                                      0|MagicMir | [28.05.2023 21:26.27.690] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                                      0|MagicMir | [28.05.2023 21:26.27.701] [INFO]  [MMM-DynamicWeather] Getting Weather API data
                                      0|MagicMir | [28.05.2023 21:26.27.914] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/xxxxx/basic.ics
                                      0|MagicMir | [28.05.2023 21:26.27.915] [INFO]  Calendar-Fetcher: Broadcasting 36 events.
                                      0|MagicMir | [28.05.2023 21:26.27.929] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/yyyyy/basic.ics
                                      0|MagicMir | [28.05.2023 21:26.27.930] [INFO]  Calendar-Fetcher: Broadcasting 38 events.
                                      0|MagicMir | [28.05.2023 21:26.27.941] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/zzzzz/public/basic.ics
                                      0|MagicMir | [28.05.2023 21:26.27.942] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                      0|MagicMir | [28.05.2023 21:26.27.948] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/qqqqq/basic.ics
                                      0|MagicMir | [28.05.2023 21:26.27.949] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                      0|MagicMir | [28.05.2023 21:26.27.954] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/ttttt/public/basic.ics
                                      0|MagicMir | [28.05.2023 21:26.27.955] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                      0|MagicMir | [28.05.2023 21:26.28.556] [INFO]  [MMM-DynamicWeather] Received successful Weather API data
                                      0|MagicMir | [28.05.2023 21:26.28.710] [INFO]  Calendar-Fetcher: Broadcasting 3 events.
                                      0|MagicMir | [28.05.2023 21:26.28.853] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                                      0|MagicMir | [28.05.2023 21:26.28.879] [INFO]  Newsfeed-Fetcher: Broadcasting 22 items.
                                      0|MagicMir | [28.05.2023 21:26.28.886] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                                      0|MagicMir | [28.05.2023 21:26.29.069] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                      0|MagicMir | [28.05.2023 21:26.29.233] [INFO]  Calendar-Fetcher: Broadcasting 38 events.
                                      0|MagicMir | [28.05.2023 21:26.29.715] [INFO]  Calendar-Fetcher: Broadcasting 36 events.
                                      0|MagicMir | [28.05.2023 21:26.30.188] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                      0|MagicMir | [28.05.2023 21:26.41.037] [INFO]  Calendar-Fetcher: Broadcasting 69 events.
                                      0|MagicMirror  | [28.05.2023 21:31.18.295] [LOG]   Use existing calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                                      0|MagicMirror  | [28.05.2023 21:31.18.296] [INFO]  Calendar-Fetcher: Broadcasting 3 events.
                                      0|MagicMirror  | [28.05.2023 21:31.18.318] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/alfuller194%40gmail.com/public/basic.ics
                                      0|MagicMirror  | [28.05.2023 21:31.18.318] [INFO]  Calendar-Fetcher: Broadcasting 69 events.
                                      0|MagicMirror  | [28.05.2023 21:31.18.330] [LOG]   wb
                                      0|MagicMirror  | [28.05.2023 21:31.18.336] [LOG]   1685334678
                                      0|MagicMirror  | [28.05.2023 21:31.18.374] [LOG]   Use existing newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml
                                      0|MagicMirror  | [28.05.2023 21:31.18.375] [INFO]  Newsfeed-Fetcher: Broadcasting 22 items.
                                      0|MagicMirror  | [28.05.2023 21:31.18.386] [LOG]   Use existing newsfetcher for url: http://rssfeeds.freep.com/freep/news.xml
                                      0|MagicMirror  | [28.05.2023 21:31.18.387] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                                      0|MagicMirror  | [28.05.2023 21:31.18.405] [LOG]   Use existing newsfetcher for url: https://www.reviewjournal.com/feed/
                                      0|MagicMirror  | [28.05.2023 21:31.18.406] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                                      0|MagicMirror  | [28.05.2023 21:31.18.423] [INFO]  [MMM-DynamicWeather] Getting Weather API data
                                      0|MagicMirror  | [28.05.2023 21:31.18.510] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/aaaaa/basic.ics
                                      0|MagicMirror  | [28.05.2023 21:31.18.511] [INFO]  Calendar-Fetcher: Broadcasting 36 events.
                                      0|MagicMirror  | [28.05.2023 21:31.18.526] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/bbbbb/basic.ics
                                      0|MagicMirror  | [28.05.2023 21:31.18.527] [INFO]  Calendar-Fetcher: Broadcasting 38 events.
                                      0|MagicMirror  | [28.05.2023 21:31.18.545] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/ccccc/basic.ics
                                      0|MagicMirror  | [28.05.2023 21:31.18.546] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                      0|MagicMirror  | [28.05.2023 21:31.18.557] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/ddddd/basic.ics
                                      0|MagicMirror  | [28.05.2023 21:31.18.558] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                      0|MagicMirror  | [28.05.2023 21:31.18.568] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/eeeee/basic.ics
                                      0|MagicMirror  | [28.05.2023 21:31.18.568] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                      0|MagicMirror  | [28.05.2023 21:31.18.952] [ERROR] Whoops! There was an uncaught exception...
                                      0|MagicMirror  | [28.05.2023 21:31.18.953] [ERROR] TypeError: Cannot read properties of undefined (reading '0')
                                      0|MagicMirror  | [28.05.2023 21:31.18.954] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|MagicMirror  | [28.05.2023 21:31.18.954] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      0|MagicMirror  | [28.05.2023 21:31.19.062] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/np78qdudrc3jui1n9mqr3pbud0%40group.calendar.google.com/public/basic.ics Error: Not Found
                                      0|MagicMirror  |     at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:119:9)
                                      0|MagicMirror  |     at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
                                      0|MagicMirror  | [28.05.2023 21:31.19.086] [ERROR] Whoops! There was an uncaught exception...
                                      0|MagicMirror  | [28.05.2023 21:31.19.089] [ERROR] TypeError: Cannot read properties of undefined (reading 'pollution')
                                      0|MagicMirror  | [28.05.2023 21:31.19.091] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|MagicMirror  | [28.05.2023 21:31.19.092] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      0|MagicMirror  | [28.05.2023 21:31.19.208] [INFO]  Newsfeed-Fetcher: Broadcasting 22 items.
                                      0|MagicMirror  | [28.05.2023 21:31.19.292] [INFO]  [MMM-DynamicWeather] Received successful Weather API data
                                      0|MagicMirror  | [28.05.2023 21:31.19.397] [INFO]  Calendar-Fetcher: Broadcasting 3 events.
                                      0|MagicMirror  | [28.05.2023 21:31.19.420] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                                      0|MagicMirror  | [28.05.2023 21:31.19.458] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                                      0|MagicMirror  | [28.05.2023 21:31.19.654] [INFO]  Calendar-Fetcher: Broadcasting 38 events.
                                      0|MagicMirror  | [28.05.2023 21:31.19.809] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                      0|MagicMirror  | [28.05.2023 21:31.20.199] [INFO]  Calendar-Fetcher: Broadcasting 36 events.
                                      0|MagicMirror  | [28.05.2023 21:31.20.642] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                      0|MagicMirror  | [28.05.2023 21:31.28.882] [INFO]  Calendar-Fetcher: Broadcasting 69 events.
                                        sdetweil @JohnGalt
                                        @JohnGalt same error. the data. is not there (pollution)
                                        don’t know why
                                          JohnGalt @sdetweil
                                          @sdetweil -Hi Sam, thanks for your time and attention. As regards the air quality issue, I think I understand what is happening - I just don’t understand why - which is important, air quality data being the primary reason I loaded this module in the first place [though, I must say the icons and presentation are better looking than the stock module!, but I digress…]
                                          My API key from IQAir was issued more than one year ago, and their website therefore shows it as having expired ~94 days ago. However, the same site dashboard shows the key as ‘active’ and [therefore?] does not offer the opportunity to renew the existing key. To further complicate matters, one is allowed only a single ‘community’ API key, so I am unable to simply create a new key! I have put in a ticket for this, but never heard back.
                                          Regarding the weather forecast, I changed the provider from weatherbit [which was not working at all] back to openweathermap, resulting in retrieving the current weather but not the AQI data nor the 4 day forecast [see screenshot below]. I guess my question at this point is whether I should just give up on this module and see if I can find a different module that incorporates air quality with current and forecast weather.
                                          mumblebajM 2 Replies Last reply
                                          • mumblebajM
                                            @JohnGalt The below seems to be error.
                                            I am not sure why it does not work for you. It still works fine for me and I can get the 4 day forecast.
                                            I am suspecting that it may well be related to Request module, I have seen same issue with Request stopping working with another module but cannot be totally sure. If you want to share you location and API key with me DM I can see if I can recreate the issue my end and possibly advise on solution?
