    MMM-NOAA3 4day forcast doesn't display
    25 Posts 5 Posters 9.1k Views 5 Watching
      monark
      you have subscribe openmapweather onecall?
      • mumblebajM Offline
        mumblebaj Module Developer @monark
        @monark The module is not setup to do onecall API.
          JohnGalt @mumblebaj
          @mumblebaj - Well, perhaps I spoke too soon… After changing the provider to weatherbit, I had data for a day or so, but now have no current data nor forecast on NOAA3, while two instances of the default weather module do still work for other locations:
          mumblebajM M 2 Replies Last reply Reply Quote 0
            mumblebaj Module Developer @JohnGalt
            @JohnGalt Do you see any errors in the Developers console or in the logs? Mine seems to be running fine still without any issues.
              motdog @JohnGalt
              @JohnGalt said in MMM-NOAA3 4day forcast doesn't display:
              Same issue for me. I haven’t checked/changed provider but it’s been this way for a week or so. I’ll play around this weekend
                JohnGalt @mumblebaj
                @mumblebaj - Yes, there are errors in the logs. In addition, I notice that on both my displays and on the screenshot posted by @motdog in both cases not only is the content of the 4-day forecast missing, but the “4 Day Forecast” label box is also not displaying.
                Just for completeness, I will note I have had no response from IQAir regarding the AQI API key, nor has there been any solution suggested here on the forum.
                Log output [ignore the calendar error - it looks like the Detroit Lions killed the link to their calendar, which seems to happen yearly…] All the other errors appear to be for the MMM-NOAA3 module:
                /home/pi/.pm2/logs/MagicMirror-error.log last 25 lines:
                0|MagicMir |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1079:12)
                0|MagicMir |     at Object.onceWrapper (node:events:627:28)
                0|MagicMir |     at IncomingMessage.emit (node:events:525:35)
                0|MagicMir |     at endReadableNT (node:internal/streams/readable:1358:12)
                0|MagicMir |     at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
                0|MagicMir | [27.05.2023 15:16.35.310] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|MagicMir | [27.05.2023 15:16.35.312] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                0|MagicMir | [27.05.2023 15:16.35.345] [ERROR] Whoops! There was an uncaught exception...
                0|MagicMir | [27.05.2023 15:16.35.348] [ERROR] TypeError: Cannot read properties of undefined (reading 'pollution')
                0|MagicMir |     at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:196:36)
                0|MagicMir |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:189:27)
                0|MagicMir |     at self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                0|MagicMir |     at Request.emit (node:events:513:28)
                0|MagicMir |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1157:10)
                0|MagicMir | [27.05.2023 15:16.35.351] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|MagicMir | [27.05.2023 15:16.35.353] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                0|MagicMir | [27.05.2023 15:16.35.535] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/np78qdudrc3jui1n9mqr3pbud0%40group.calendar.google.com/public/basic.ics Error: Not Found
                0|MagicMir |     at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:119:9)
                0|MagicMir |     at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
                  @JohnGalt Not too familiar with the module. Can you get more lines from the log? I think the actual issue would be in those lines. I am thinking the issue might be key related but need to see the lines above the start line you posted. Prior to this line:
                    JohnGalt
                    @mumblebaj - Thanks for your time and attention. Following is the log output that generates this:
                    pi@mirror4:~ $ pm2 logs --lines=25
                    [TAILING] Tailing last 25 lines for [all] processes (change the value with --lines option)
                    /home/pi/.pm2/pm2.log last 25 lines:
                    PM2        | 2023-05-27T15:14:24: PM2 log: PM2 version          : 5.1.2
                    PM2        | 2023-05-27T15:14:24: PM2 log: Node.js version      : 16.19.0
                    PM2        | 2023-05-27T15:14:24: PM2 log: Current arch         : arm
                    PM2        | 2023-05-27T15:14:24: PM2 log: PM2 home             : /home/pi/.pm2
                    PM2        | 2023-05-27T15:14:24: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                    PM2        | 2023-05-27T15:14:24: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                    PM2        | 2023-05-27T15:14:24: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                    PM2        | 2023-05-27T15:14:24: PM2 log: Application log path : /home/pi/.pm2/logs
                    PM2        | 2023-05-27T15:14:24: PM2 log: Worker Interval      : 30000
                    PM2        | 2023-05-27T15:14:24: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                    PM2        | 2023-05-27T15:14:24: PM2 log: Concurrent actions   : 2
                    PM2        | 2023-05-27T15:14:24: PM2 log: SIGTERM timeout      : 1600
                    PM2        | 2023-05-27T15:14:24: PM2 log: ===============================================================================
                    PM2        | 2023-05-27T15:14:24: PM2 log: [Watch] Start watching MagicMirror
                    PM2        | 2023-05-27T15:14:24: PM2 log: App [MagicMirror:0] starting in -fork mode-
                    PM2        | 2023-05-27T15:14:25: PM2 log: App [MagicMirror:0] online
                    PM2        | 2023-05-27T15:16:20: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                    PM2        | 2023-05-27T15:16:20: PM2 log: Stopping app:MagicMirror id:0
                    PM2        | 2023-05-27T15:16:21: PM2 log: pid=635 msg=failed to kill - retrying in 100ms
                    PM2        | 2023-05-27T15:16:21: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                    PM2        | 2023-05-27T15:16:21: PM2 log: pid=635 msg=process killed
                    PM2        | 2023-05-27T15:16:21: PM2 log: App [MagicMirror:0] starting in -fork mode-
                    PM2        | 2023-05-27T15:16:21: PM2 log: App [MagicMirror:0] online
                    PM2        | 2023-05-28T15:14:42: PM2 log: [PM2] This PM2 is not UP TO DATE
                    PM2        | 2023-05-28T15:14:42: PM2 log: [PM2] Upgrade to version 5.3.0
                    /home/pi/.pm2/logs/MagicMirror-out.log last 25 lines:
                    0|MagicMir | [28.05.2023 16:09.56.814] [LOG]   NOAA3 weather updated.. next update in 1 hour
                    0|MagicMir | [28.05.2023 16:10.59.646] [LOG]   NOAA3 weather updated.. next update in 1 hour
                    0|MagicMir | [28.05.2023 16:11.27.958] [LOG]   NOAA3 weather updated.. next update in 1 hour
                    0|MagicMir | [28.05.2023 16:16.29.322] [INFO]  [MMM-DynamicWeather] Getting Weather API data
                    0|MagicMir | [28.05.2023 16:16.29.666] [INFO]  [MMM-DynamicWeather] Received successful Weather API data
                    0|MagicMir | [28.05.2023 16:16.29.957] [LOG]   NOAA3 weather updated.. next update in 1 hour
                    0|MagicMir | [28.05.2023 16:16.34.814] [LOG]   NOAA3 weather updated.. next update in 1 hour
                    0|MagicMir | [28.05.2023 16:16.57.722] [INFO]  Newsfeed-Fetcher: Broadcasting 23 items.
                    0|MagicMir | [28.05.2023 16:17.16.173] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                    0|MagicMir | [28.05.2023 16:17.46.774] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                    0|MagicMir | [28.05.2023 16:24.56.817] [LOG]   NOAA3 weather updated.. next update in 1 hour
                    0|MagicMir | [28.05.2023 16:25.59.651] [LOG]   NOAA3 weather updated.. next update in 1 hour
                    0|MagicMir | [28.05.2023 16:26.27.961] [LOG]   NOAA3 weather updated.. next update in 1 hour
                    0|MagicMir | [28.05.2023 16:26.29.322] [INFO]  [MMM-DynamicWeather] Getting Weather API data
                    0|MagicMir | [28.05.2023 16:26.29.750] [INFO]  [MMM-DynamicWeather] Received successful Weather API data
                    0|MagicMir | [28.05.2023 16:26.38.930] [INFO]  Calendar-Fetcher: Broadcasting 3 events.
                    0|MagicMir | [28.05.2023 16:26.42.175] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                    0|MagicMir | [28.05.2023 16:26.42.331] [INFO]  Calendar-Fetcher: Broadcasting 38 events.
                    0|MagicMir | [28.05.2023 16:26.52.596] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                    0|MagicMir | [28.05.2023 16:26.56.174] [INFO]  Calendar-Fetcher: Broadcasting 37 events.
                    0|MagicMir | [28.05.2023 16:26.57.975] [INFO]  Newsfeed-Fetcher: Broadcasting 23 items.
                    0|MagicMir | [28.05.2023 16:27.16.525] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                    0|MagicMir | [28.05.2023 16:27.47.201] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                    0|MagicMir | [28.05.2023 16:30.47.955] [INFO]  Calendar-Fetcher: Broadcasting 69 events.
                    0|MagicMir | [28.05.2023 16:31.29.957] [LOG]   NOAA3 weather updated.. next update in 1 hour
                    0|MagicMir | [28.05.2023 16:31.30.413] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    0|MagicMir | [28.05.2023 16:31.30.413] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    0|MagicMir | [28.05.2023 16:31.30.424] [ERROR] Whoops! There was an uncaught exception...
                    0|MagicMir | [28.05.2023 16:31.30.425] [ERROR] SyntaxError: Unexpected token 'S', "Service Unavailable" is not valid JSON
                    0|MagicMir |     at JSON.parse (<anonymous>)
                    0|MagicMir |     at Object.parseALERT (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:214:27)
                    0|MagicMir |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:209:27)
                    0|MagicMir | [28.05.2023 16:31.30.425] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    0|MagicMir | [28.05.2023 16:31.30.425] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    0|MagicMirror  | [28.05.2023 16:31.34.814] [LOG]   NOAA3 weather updated.. next update in 1 hour
                    0|MagicMirror  | [28.05.2023 16:31.35.070] [ERROR] Whoops! There was an uncaught exception...
                    0|MagicMirror  | [28.05.2023 16:31.35.071] [ERROR] SyntaxError: Unexpected token 'S', "Service Unavailable" is not valid JSON
                    0|MagicMirror  |     at JSON.parse (<anonymous>)
                    0|MagicMirror  |     at Object.parseALERT (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:214:27)
                    0|MagicMirror  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:209:27)
                    0|MagicMirror  |     at self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                    0|MagicMirror  |     at Request.emit (node:events:513:28)
                    0|MagicMirror  |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1157:10)
                    0|MagicMirror  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1079:12)
                    0|MagicMirror  |     at Object.onceWrapper (node:events:627:28)
                    0|MagicMirror  |     at IncomingMessage.emit (node:events:525:35)
                    0|MagicMirror  |     at endReadableNT (node:internal/streams/readable:1358:12)
                    0|MagicMirror  |     at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
                    0|MagicMirror  | [28.05.2023 16:31.35.072] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    0|MagicMirror  | [28.05.2023 16:31.35.073] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    0|MagicMirror  | [28.05.2023 16:31.35.096] [ERROR] Whoops! There was an uncaught exception...
                    0|MagicMirror  | [28.05.2023 16:31.35.097] [ERROR] TypeError: Cannot read properties of undefined (reading '0')
                    0|MagicMirror  |     at Object.parseResponse (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:81:36)
                    0|MagicMirror  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:74:28)
                    0|MagicMirror  | [28.05.2023 16:31.35.097] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    0|MagicMirror  | [28.05.2023 16:31.35.098] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    0|MagicMirror  | [28.05.2023 16:31.35.235] [ERROR] Whoops! There was an uncaught exception...
                    0|MagicMirror  | [28.05.2023 16:31.35.236] [ERROR] TypeError: Cannot read properties of undefined (reading 'pollution')
                    0|MagicMirror  |     at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:196:36)
                    0|MagicMirror  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/wb.js:189:27)
                    0|MagicMirror  | [28.05.2023 16:31.35.236] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    0|MagicMirror  | [28.05.2023 16:31.35.236] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      sdetweil @JohnGalt
                      : Cannot read properties of undefined (reading ‘pollution’)
                      no error recovery… once that happens, only MM restart will fix it…
                      this could be a good use of the es6 chaining operator.
                      https://forum.magicmirror.builders/topic/17677/mirror-showing-not-all-modules-on-all-devices/11?_=1683748897387
                        JohnGalt @sdetweil
                        @sdetweil - OK, I rebooted the machine and there is no change in the behavior of the module (no AQI, no 4 day forecast). Log taken shortly after reboot follows:
                        Last login: Sun May 28 21:25:39 2023
                        PM2        | 2023-05-28T21:25:27: PM2 log: [Watch] Stop watching MagicMirror
                        PM2        | 2023-05-28T21:25:27: PM2 log: Stopping app:MagicMirror id:0
                        PM2        | 2023-05-28T21:25:27: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                        PM2        | 2023-05-28T21:25:27: PM2 error: Cancelling versioning data parsing
                        PM2        | 2023-05-28T21:25:27: PM2 log: pid=14002 msg=process killed
                        PM2        | 2023-05-28T21:25:27: PM2 log: PM2 successfully stopped
                        PM2        | 2023-05-28T21:25:37: PM2 log: ===============================================================================
                        PM2        | 2023-05-28T21:25:37: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                        PM2        | 2023-05-28T21:25:37: PM2 log: Time                 : Sun May 28 2023 21:25:37 GMT-0700 (Pacific Daylight Time)
                        PM2        | 2023-05-28T21:25:37: PM2 log: PM2 version          : 5.1.2
                        PM2        | 2023-05-28T21:25:37: PM2 log: Node.js version      : 16.19.0
                        PM2        | 2023-05-28T21:25:37: PM2 log: Current arch         : arm
                        PM2        | 2023-05-28T21:25:37: PM2 log: PM2 home             : /home/pi/.pm2
                        PM2        | 2023-05-28T21:25:37: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                        PM2        | 2023-05-28T21:25:37: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                        PM2        | 2023-05-28T21:25:37: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                        PM2        | 2023-05-28T21:25:37: PM2 log: Application log path : /home/pi/.pm2/logs
                        PM2        | 2023-05-28T21:25:37: PM2 log: Worker Interval      : 30000
                        PM2        | 2023-05-28T21:25:37: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                        PM2        | 2023-05-28T21:25:37: PM2 log: Concurrent actions   : 2
                        PM2        | 2023-05-28T21:25:37: PM2 log: SIGTERM timeout      : 1600
                        PM2        | 2023-05-28T21:25:37: PM2 log: [Watch] Start watching MagicMirror
                        PM2        | 2023-05-28T21:25:37: PM2 log: App [MagicMirror:0] starting in -fork mode-
                        PM2        | 2023-05-28T21:25:37: PM2 log: App [MagicMirror:0] online
                        0|MagicMir | [28.05.2023 21:26.28.343] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        0|MagicMir | [28.05.2023 21:26.28.344] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        0|MagicMir | [28.05.2023 21:26.28.378] [ERROR] Whoops! There was an uncaught exception...
                        0|MagicMir | [28.05.2023 21:26.28.379] [ERROR] TypeError: Cannot read properties of undefined (reading 'pollution')
                        0|MagicMir | [28.05.2023 21:26.28.379] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        0|MagicMir | [28.05.2023 21:26.28.380] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        0|MagicMir | [28.05.2023 21:26.28.567] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/np78qdudrc3jui1n9mqr3pbud0%40group.calendar.google.com/public/basic.ics Error: Not Found
                        0|MagicMir | [28.05.2023 21:26.27.672] [LOG]   Use existing newsfetcher for url: http://rssfeeds.freep.com/freep/news.xml
                        0|MagicMir | [28.05.2023 21:26.27.673] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                        0|MagicMir | [28.05.2023 21:26.27.688] [LOG]   Use existing newsfetcher for url: https://www.reviewjournal.com/feed/
                        0|MagicMir | [28.05.2023 21:26.27.690] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                        0|MagicMir | [28.05.2023 21:26.27.701] [INFO]  [MMM-DynamicWeather] Getting Weather API data
                        0|MagicMir | [28.05.2023 21:26.27.914] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/xxxxx/basic.ics
                        0|MagicMir | [28.05.2023 21:26.27.915] [INFO]  Calendar-Fetcher: Broadcasting 36 events.
                        0|MagicMir | [28.05.2023 21:26.27.929] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/yyyyy/basic.ics
                        0|MagicMir | [28.05.2023 21:26.27.930] [INFO]  Calendar-Fetcher: Broadcasting 38 events.
                        0|MagicMir | [28.05.2023 21:26.27.941] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/zzzzz/public/basic.ics
                        0|MagicMir | [28.05.2023 21:26.27.942] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                        0|MagicMir | [28.05.2023 21:26.27.948] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/qqqqq/basic.ics
                        0|MagicMir | [28.05.2023 21:26.27.949] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                        0|MagicMir | [28.05.2023 21:26.27.954] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/ttttt/public/basic.ics
                        0|MagicMir | [28.05.2023 21:26.27.955] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                        0|MagicMir | [28.05.2023 21:26.28.556] [INFO]  [MMM-DynamicWeather] Received successful Weather API data
                        0|MagicMir | [28.05.2023 21:26.28.710] [INFO]  Calendar-Fetcher: Broadcasting 3 events.
                        0|MagicMir | [28.05.2023 21:26.28.853] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                        0|MagicMir | [28.05.2023 21:26.28.879] [INFO]  Newsfeed-Fetcher: Broadcasting 22 items.
                        0|MagicMir | [28.05.2023 21:26.28.886] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                        0|MagicMir | [28.05.2023 21:26.29.069] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                        0|MagicMir | [28.05.2023 21:26.29.233] [INFO]  Calendar-Fetcher: Broadcasting 38 events.
                        0|MagicMir | [28.05.2023 21:26.29.715] [INFO]  Calendar-Fetcher: Broadcasting 36 events.
                        0|MagicMir | [28.05.2023 21:26.30.188] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                        0|MagicMir | [28.05.2023 21:26.41.037] [INFO]  Calendar-Fetcher: Broadcasting 69 events.
                        0|MagicMirror  | [28.05.2023 21:31.18.295] [LOG]   Use existing calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                        0|MagicMirror  | [28.05.2023 21:31.18.296] [INFO]  Calendar-Fetcher: Broadcasting 3 events.
                        0|MagicMirror  | [28.05.2023 21:31.18.318] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/alfuller194%40gmail.com/public/basic.ics
                        0|MagicMirror  | [28.05.2023 21:31.18.318] [INFO]  Calendar-Fetcher: Broadcasting 69 events.
                        0|MagicMirror  | [28.05.2023 21:31.18.330] [LOG]   wb
                        0|MagicMirror  | [28.05.2023 21:31.18.336] [LOG]   1685334678
                        0|MagicMirror  | [28.05.2023 21:31.18.374] [LOG]   Use existing newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml
                        0|MagicMirror  | [28.05.2023 21:31.18.375] [INFO]  Newsfeed-Fetcher: Broadcasting 22 items.
                        0|MagicMirror  | [28.05.2023 21:31.18.386] [LOG]   Use existing newsfetcher for url: http://rssfeeds.freep.com/freep/news.xml
                        0|MagicMirror  | [28.05.2023 21:31.18.387] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                        0|MagicMirror  | [28.05.2023 21:31.18.405] [LOG]   Use existing newsfetcher for url: https://www.reviewjournal.com/feed/
                        0|MagicMirror  | [28.05.2023 21:31.18.406] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                        0|MagicMirror  | [28.05.2023 21:31.18.423] [INFO]  [MMM-DynamicWeather] Getting Weather API data
                        0|MagicMirror  | [28.05.2023 21:31.18.510] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/aaaaa/basic.ics
                        0|MagicMirror  | [28.05.2023 21:31.18.511] [INFO]  Calendar-Fetcher: Broadcasting 36 events.
                        0|MagicMirror  | [28.05.2023 21:31.18.526] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/bbbbb/basic.ics
                        0|MagicMirror  | [28.05.2023 21:31.18.527] [INFO]  Calendar-Fetcher: Broadcasting 38 events.
                        0|MagicMirror  | [28.05.2023 21:31.18.545] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/ccccc/basic.ics
                        0|MagicMirror  | [28.05.2023 21:31.18.546] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                        0|MagicMirror  | [28.05.2023 21:31.18.557] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/ddddd/basic.ics
                        0|MagicMirror  | [28.05.2023 21:31.18.558] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                        0|MagicMirror  | [28.05.2023 21:31.18.568] [LOG]   Use existing calendarfetcher for url: https://calendar.google.com/calendar/ical/eeeee/basic.ics
                        0|MagicMirror  | [28.05.2023 21:31.18.568] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                        0|MagicMirror  | [28.05.2023 21:31.18.952] [ERROR] Whoops! There was an uncaught exception...
                        0|MagicMirror  | [28.05.2023 21:31.18.953] [ERROR] TypeError: Cannot read properties of undefined (reading '0')
                        0|MagicMirror  | [28.05.2023 21:31.18.954] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        0|MagicMirror  | [28.05.2023 21:31.18.954] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        0|MagicMirror  | [28.05.2023 21:31.19.062] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/np78qdudrc3jui1n9mqr3pbud0%40group.calendar.google.com/public/basic.ics Error: Not Found
                        0|MagicMirror  |     at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:119:9)
                        0|MagicMirror  |     at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
                        0|MagicMirror  | [28.05.2023 21:31.19.086] [ERROR] Whoops! There was an uncaught exception...
                        0|MagicMirror  | [28.05.2023 21:31.19.089] [ERROR] TypeError: Cannot read properties of undefined (reading 'pollution')
                        0|MagicMirror  | [28.05.2023 21:31.19.091] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        0|MagicMirror  | [28.05.2023 21:31.19.092] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        0|MagicMirror  | [28.05.2023 21:31.19.208] [INFO]  Newsfeed-Fetcher: Broadcasting 22 items.
                        0|MagicMirror  | [28.05.2023 21:31.19.292] [INFO]  [MMM-DynamicWeather] Received successful Weather API data
                        0|MagicMirror  | [28.05.2023 21:31.19.397] [INFO]  Calendar-Fetcher: Broadcasting 3 events.
                        0|MagicMirror  | [28.05.2023 21:31.19.420] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                        0|MagicMirror  | [28.05.2023 21:31.19.458] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                        0|MagicMirror  | [28.05.2023 21:31.19.654] [INFO]  Calendar-Fetcher: Broadcasting 38 events.
                        0|MagicMirror  | [28.05.2023 21:31.19.809] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                        0|MagicMirror  | [28.05.2023 21:31.20.199] [INFO]  Calendar-Fetcher: Broadcasting 36 events.
                        0|MagicMirror  | [28.05.2023 21:31.20.642] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                        0|MagicMirror  | [28.05.2023 21:31.28.882] [INFO]  Calendar-Fetcher: Broadcasting 69 events.
                          sdetweil @JohnGalt
                          @JohnGalt same error. the data. is not there (pollution)
                          don’t know why
                            JohnGalt @sdetweil
                            @sdetweil -Hi Sam, thanks for your time and attention. As regards the air quality issue, I think I understand what is happening - I just don’t understand why - which is important, air quality data being the primary reason I loaded this module in the first place [though, I must say the icons and presentation are better looking than the stock module!, but I digress…]
                            My API key from IQAir was issued more than one year ago, and their website therefore shows it as having expired ~94 days ago. However, the same site dashboard shows the key as ‘active’ and [therefore?] does not offer the opportunity to renew the existing key. To further complicate matters, one is allowed only a single ‘community’ API key, so I am unable to simply create a new key! I have put in a ticket for this, but never heard back.
                            Regarding the weather forecast, I changed the provider from weatherbit [which was not working at all] back to openweathermap, resulting in retrieving the current weather but not the AQI data nor the 4 day forecast [see screenshot below]. I guess my question at this point is whether I should just give up on this module and see if I can find a different module that incorporates air quality with current and forecast weather.
                            mumblebajM 2 Replies Last reply Reply Quote 0
                              @JohnGalt The below seems to be error.
                              I am not sure why it does not work for you. It still works fine for me and I can get the 4 day forecast.
                              I am suspecting that it may well be related to Request module, I have seen same issue with Request stopping working with another module but cannot be totally sure. If you want to share you location and API key with me DM I can see if I can recreate the issue my end and possibly advise on solution?
                                @JohnGalt Also, my IQAir jey is community and still works fine although it expired almost a year ago.
